Question about Sylvania SST4322 32" TV
Does not respond to Remote control (a pain, since the only useful input is via remote). At first, remote control was lost sporadically, then it failed completely. At that point, it was stuck on Video1 input, but after some effort, I was able to switch to main input. Now, can switch channels using panel buttons, or via VCR feeding in through the cable port - although VCR control was lost for a few days. Is the IR sensor dead? Can't find part number. Also, cannot input from a DVD player at present (used to be hooked up OK until remote control failed).
  • jason chairs Oct 16, 2008
    I have an older model sylvania 27 inch tv its a 2003 the model is SRT 4127FA I cant get the remote to work I think it might be the sensor does anyone know where or how I could get a parts manual for this?
    Novelist:
    Champion:
  • 275 Answers
Did you try replacing the batteries of the Remote?
Posted on Sep 25, 2006
The IR receiver part number is 782-TSOP4836. You can find it at mouser.com.
Posted on Apr 08, 2009
My Tv does the same thing, I had the cable company out twice. Called Slyvania direct. Noone can help. Is it the censor? I called a tv repair company and they said they didn't this it was. The tv is on 2 years old. He told me to try and reprobram it. HTe 2nd time usuallu takes, but I did that, as well a sthe cable guy!
Posted on Apr 17, 2007
How to return from usb mode to tv mode without remote control for sinotech LCD tv manual
No other way. You should have its remote control to select inputs. I thinks that I've answered this problem, many times before.
If you post any more, please provide the name of yours with the post, so that I do recognize you and not to respond it, and allow any other to answer you.
Here I see this problem is posted by some 'Anonymous" person.
Whatever it may be, you can't select the input to your Sinotech TV; without its remote control.
Aug 13, 2014 | Televison & Video
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
Nov 11, 2013 | Vizio VW37L 37 in. LCD HDTV
Lost remote to portable dvd player
Any universal remote will work. Just look on the back of it to make sure it supports your brand. That's the key. Just follow the directions for manual input. It will work something like this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | RCA DIRECTV Satellite Remote Control
My laptop responds to tv remote
you can turn off the IR on the laptop or put black tape over it!
Sep 19, 2009 | Microsoft Windows XP Media Center Edition...
How to make tosiba tv show the movie that is playing on a tosiba
You may need to manually switch the input on your tv via the menu on the front panel switches if your universal remote does not have an input button or it just wont respond.
Aug 25, 2009 | Toshiba 27AF43 27" TV
I have a WD62825, it lost power while watching. There is power at the plug in.
Is the grreen light on?..or can be switched on via remote? Plug it out then back in. Green light flashing? If so...you have lost input signal or the tv has reset itself to another input (non functioning). Use Remote to set input (via Net Command) to functioning signal. If the Green light NEVER comes on...it may be major system failure. Be sure remote is set to "TV"
Jun 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Jun 13, 2009 | Sylvania 6420FB 20" TV
Sony television will not respond to remote.
battery in remote.
Many times I will 'reseat' the batteries in a remote & then it will work for a while again.
Jul 27, 2008 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Lost Remote Control
wal mart sells a phillips universal plip remote that works with the unit but the code for the dvd player is not listed so you have to do a manual code serch pain in the !@# but other then that it works
May 29, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Sylvania SST4322 32" TV Logo
316 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
