Question about Microsoft Xbox 360 Console
My controller won't connect
my xbox console seems fine, but i have a problem with my controller.
when i hold down the 'start button' the controller won't recognize a 'user' (1, 2, etc) but keeps on blinking. the console is telling my to "connect controller".
what is wrong? i've tried to change the batteries, nothing happened.
thankfull for any ideas!
regards,
karl
  • 488 Answers
Please press the connect buttons on the console(near the power button) and the controller(its a small button on the behind)
hope it helps!
Posted on Nov 02, 2008
How to Sync an Xbox Controller?
Hi Lewis,
- turn xbox on
-insert AA batteries
-turn controller on by pressing down x button
-press and release connect button on console
(small circle button located on side round from disc tray)
-with 20secs, press and hold black connect on back of controller until xbox button flashes a few times.
Oct 20, 2016 | Video Game Consoles & Games
My Xbox 360 controller appears to be having some issues: i turned the xbox on, and it is immediay prompting me to download an update from Xbox Live, however, I cannot get my controller connected to get rid...
There is a connect button on the controller as well. See this site or follow the instructions below. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/connecting-game-controllers.aspx
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  3. Press and release the connect button on the console.
  4. Within 20 seconds, press and release the connect button on the controller.
  5. When the lights surrounding the power button on the console stop flashing, the controller is connected.
Jun 30, 2011 | Microsoft Xbox 360 Controller
My xbox 360 will not sync with any controllers besides the one controller I've already had synced. I haven't had any problems with it until recently, and now it seems like the xbox won't...
If you have an xbox slim model then there is a button above the USB slots at the bottom. Press Start and Back on the controller until the center button lights up. Then press the button above the two USB solts and hold it for a couple secs.
If you have n old xbox there should be a simliar button some where.
Also if you bought one of the charging packs for the controller, use the cord that came with it.
Thank you for your time, Good luck and I hope it works.
Jun 05, 2011 | Microsoft Xbox 360 Console
My xbox turns but the image docent pop out
To reset Xbox 360 console display settings
  1. If there is a disc in the console, remove it.
  2. Turn off the console.
  3. Turn on the console by using your controller. To do this, press and hold the controller's Xbox Guide button until your console turns on.
    Note If multiple controllers are connected to your console, make sure that you use the player one controller.
  4. While the console is starting, press and hold the Y button and pull the right trigger at the same time. Continue holding the buttons when you see the Xbox 360 logo.
  5. The console will restart and you will see the Xbox 360 logo again.
    The console's display settings are now reset to the defaults.
May 21, 2011 | Microsoft Xbox 360 Console
E 71 error code
Nobody is 100% sure what causes this error but it Most likely relates to dashboard and console updates. Also, the problem appears to arise from gamers incorrectly flashing their hardware or doing botched firmware hacks which then prevent the system from functioning correctly.
Have you recently updated your Xbox 360 in anyway, or have you (or anyone else) attempted some form of firmware hack or flash? If so, this is probably the cause of the e71 code on your Xbox, however, it could also be completely random. If you call microsoft they will most likely tell you to9 just reset but that is only a temporary fix and you still have the problem of annoying freezes which will get worse and worse. Fixing the Xbox e71 is quite tricky. First try these methods,
1) switch off the console. With the console switched off, press and hold the sync button (the small white button that is used to search for wireless connections). While holding the sync button, switch on the console by pressing the power button and do not release hold of the sync button until the console is fully booted up. During the booting up of the console, any failed updates will be cleared allowing the console to run normally once again and thus eliminating the xbox 360 e71 error.
Another similar way is to
2)Hold the wireless connection button on your controller down with the 360 off. It's the little white button between the shoulder buttons. It's what you used to set up your wireless controller with your 360. While still holding the button, hit the XBOX logo on the controller to turn on the XBOX. Do not let go of the white button. After it's fully started up, you can let go. this reverts you back to your last update.
Or if nothing else seems to work you could try completely resetting your Xbox 360. To do this,
3) First enter the dashboard, go to the right-most column, go and press "Initial Set Up" then follow the instructions on screen. If you cannot access this screen due to the e71 error on your Xbox 360, you can try holding the "Y" button on your controller as you switch the console on. This will enter the same process, and restore default factory settings. However, there is still a chance that this might not work.
There are guides available online for less than $30 if you cant seem to get it fixed but make sure you get one that explains all errors as most only tell about the red ring of death.
Hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
I have an xbox 360 that pops up with the 3 red lights on the front and every now and then the e71 error. How do I fix this problem myself?
Hope this helps
Nov 29, 2010 | Microsoft Xbox 360 Console
My controllers do not connect to the console
My only guess is to hold down the button on the top of your controller it has a symbol like this ))) , hold it down for 2 seconds then let go and go over to the xbox and hold down the smallest button on it for two seconds. both the controller and the xbox lights will start to flash after that, it should be connected.
Oct 15, 2009 | Microsoft Xbox 360 Console
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
Setting up a 360 wireless controller
Turn Your Console and Controller On The Xbox® Guide button in the center of your controller puts the Xbox 360® experience at your fingertips. Press and hold the Xbox Guide button to turn your console on.
To turn on your console only, press the power button on your console. To turn on your controller only, press the Start button on your controller.
Once on, pressing the Xbox Guide button gives you immediate access to the Xbox Guide. To turn off your console, press and hold the Xbox Guide button for three seconds and then confirm your selection.
Turn Your Console and Controller Off To turn your console and controller off, press and hold the Xbox Guide button on your controller for three seconds. Then select whether you want to turn off just your controller or both your controller and your console. (Selecting the console will turn off both the console and all connected controllers.)
To turn off one controller when multiple wireless controllers are connected, press and hold for three seconds the Xbox Guide button of the controller you want to turn off, then select Turn Off Controller.
To turn off your console only, press the power button on your console
When you connect a controller to your console, it is assigned a specific quadrant, which glows green to indicate the controller's number and position. Each subsequent controller connected to the console (up to four) is assigned an additional quadrant.
If system problems should arise, the Ring of Light on the console will flash combinations of red.
I hope this solved your problem.
Happy Gaming!
Oct 17, 2008 | Microsoft Xbox 360 Wireless Controller
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
