Question about Barco Personal Calibrator V 21 in.CRT Conventional Monitor
Barco pcd321 dont start up ,stay in stanby
When i try to start my barco it wil not starting up can some one tell me how to fix this barco wil repair this but 400 euro is to much
0 characters
1 Points
I have a SyncMaster 225bw, approx 3 years old but havnt used it much in the last year and a half. it started having a problem starting back up it seems. if i can get it to stay "lit up" it will...
This type of monitor problem is usually cause by a failure of the capacitors in the power supply board. What is happening is the power supply is not starting up correctly so the back lights are not coming up to full brightness. Here is a link to a repair guide that will show you how to dis-assemble the unit and repair the power supply board.
If you can do a little soldering then you can do the repair yourself.
Apr 15, 2011 | Samsung 225BW LCD Monitor
I have a Neovo F-419 LCD Monitor that keeps switching off and going blank times it flaches on and off without me touching it, at other times it stays on for a long period of time (over 1/2 hr) and...
Thank you for your query
The fault you are explaining can be either the monitor or possibly even the VGA card
To rule out one or the other please try try the following
1) Plug the monitor in another PC, if the monitor works fine then the VGA card may need to be replaced
2) If it still occurs then the monitor is at fault and wil need to be replaced/repaired
I hope this helps
Mar 08, 2010 | Neovo F-419 19" LCD Monitor
LG1917S-BN Access to power supply - Rear cover removing
You need to use flat thin blade screw driver to crack open the case, starting at the bottom edge of the case first, you may need two screw drivers, when it starting to come apart, leave one screw driver in the partially opening section so it not snap back together while you tackle another section of the case. Most monitors cases these day do not have small slot to show where you should crack open the case at, they just do not want you to fix it.
Feb 23, 2010 | LG L1917S-BN 19" LCD Monitor
My samsung syncmaster won't start. It stays black (the light on the power on button is green). If I try to power it off and on again, I can see my desktop for a few seconds then it beeps and die.
You have a problem with the power supply that is built into the monitor. These are not easily repaired, as the cost exceeds the value of the monitor.
Nov 04, 2009 | Samsung SyncMaster 920NW Monitor
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check or
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
Monitor turns on then shuts off in seconds.
check your video card connections. make sure that your monitor cable is attached firmly in place.Also make sure the video card is fully pushed into the slot on the motherboard. Sometimes because of heat the card can pop out of the slot. Sometime this is just enough to barely work and then stop.
Jan 30, 2009 | CTX S762A 17" LCD Monitor
PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Sure, you can fixed by replaced the backlight inverter or repaired it.
Oct 31, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Calibrator talk doesn't see monitor on mac
did you verify that the USB port is active and the cable is working? Check under the Apple menu for "about this mac" then click on more info. Click on USB to see a list of active USP devices. If the Barco is connecting it will show up in the list. May not say Barco, it may say unknown device but it lets you see that the cable and port are working. If not replace them or try it on another computer. If they are working then the Calibrator Talk software may be configured wrong, have you contacted Barco? They have a troubleshooting area on the web site.
Mar 28, 2008 | Barco Personal Calibrator V 21 in.CRT...
On Pwr up logo appears then LCD returns to stanby Black screen
I will assume the monitor is staying on during the boot process all the way until Windows loads.
If that is the case, then...
  • Start the computer
  • wait until the initial bios/logo screens for your motherboard go away.
  • Press F8 to get the Windows recovery boot menu
  • If you see the Windows Logo you would normally see then press rest and try again.
  • In the recovery screen, select SAFE MODE
  • Boot into Windows and uninstall your video card.
  • Reboot the computer the normal way through the start menu.
  • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
Let me know how you go =)
Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
Barco Personal Calibrator V 21 in.CRT Conventional Monitor Logo
37 people viewed this question
Top Barco Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Barco Computer Monitor Expert? Answer questions, earn points and help others
