Question about Electronics - Others
GSA-E50L - Cannot read any discs
While the drive picks up a drive letter when connected and I am able to insert a Disk into it, I am unable to read any of the information on those disks and the drive does not recognise those discs as well
  • 88 Answers
Dear please write your problem in detail.Also sent error or any kind of msg you see.
I will definatetly help you in this matter.
Regards,
Rakesh Kumar
Network Support Engineer
Posted on Nov 11, 2008
Keeps telling me to lnsert a disc even though there is a disc in the drive .model GSA-H62N
CLEAN THE DISK WITH WATER, THEN WIPE , THEN ALLOW TO DRY COMPLETELY . THEN INSERT AND TRY. SHOULD WORK.
May 18, 2011 | LG GSA H62N Super-Multi - Disk drive - DVD...
My LG DVD Writer is not reading any disk when i am inserting the disk in Drive. IT stops blinking also.
Hello Ammit,
It seems that the lens of the DVD writer is not working properly. Please try to clean the lens of the DVD writer with help of CD/DVD lens cleaner disc. The lens cleaner disc is easily available in market. After cleaning the lens try to run the CD/DVD again
May 08, 2011 | LG (GSA-H42NK) Burner
I have an LG GSA-E50L slim type DVD rewriter and Mac Snow Leopard doesn't recognize the burner? Do I need a driver from LG? What should I do?
You could try running a virtual Windows computer (using Parallels or VMWare) on your Mac. The LG site has drivers for Windows 2000, XP and Vista. There are no Mac drivers listed. Otherwise you need a different computer or burner.
I am sorry that I can't be of more help but the owner's manual indicates that this product was made for Windows systems only.
Jan 03, 2010 | LG GSA-E50L DVD-RAM Burner
My LG GSA-H55L super multi DVD rewriter seems to suddenly have a problem recognising disc. I am using the same discs as before (same batch) but now it always tells me no disc.
have you tried a cleaning disk?if not get some cleaning alchol wipe the disk leave a little on it not much,insert the disk ,this might clean the lense.
Sep 11, 2009 | LG 20x8x20 GSA-H55L Super-Multi Disk...
Hp dvd/rw does not read discs
If the CD or DVD disks you inserted work in some other reader, then your reader is the problem -- even though it is properly connected to your computer, and Windows has the correct device-drivers, it is the "hardware" that is the problem.
When you insert a disk, rotate it to some position, i.e., top-lettering goes in first, and close the drawer. Do you hear the drive start to spin the disk? Open the drawer. Is the disk in the same (non-rotated) position? If so, then the motor that spins the disk is the problem. If the disk does spin, but nothing happens, then it is the "laser" part of the mechanics that is not working.
Replace it.
Apr 21, 2009 | LG GSA-H55N DVD-RAM Burner
Amilo PA 2548: DVDRW GSA-T20N can't write discs
Go into device manager and delete that disk drive and then reboot and it should reinstall it. That will separate the drivers and put the old one back.
Jun 10, 2017 | LG GSA-T20N DVD±RW Dual Layer Burner
Dear sir, Iam unable 2 open my drive,Pls give me solution . I have changed th letter and paths of pen drive then also no use. Error:Pls insert the disc in disk drive
Are you currently using a Windows Machine? If so, press and hold the "windows button" (shaped like a flag on bottom left corner of keyboard) and press "r". Next, type the drive letter, followed by ":\". If this does not work, right click "My Computer", go to "Properties", "Hardware" tab, "Device Manager", "Disk Drives", and right click on the drive. Click "Format". If you get this far, post back...
Jan 18, 2009 | IBM (23R2567) 8x WORM Disk Storage Media...
I need the drivers for a DVD-RW drive model # GSA-T40N. didn' t know if you could help
You do not need drivers for DVD-RW especially if you are installing it in Windows Xp or Windows VIsta.
Jan 01, 2009 | Computers & Internet
Lg gsa-e50l drivers download
I have the same annoying probem... I thought as many of you that there must be some kind of driver problem for my device, and I gone mad searching for a strange inexistent driver for it, but STOP SEARCHING THIS DRIVER! there's no specific driver for this device as the man working for LG says:
"this driver is plug and play and does not need drivers, it's supposed to use drivers that come with windows."
So.. what0s the problem?? as Weeply the wiseman (a.k.a MY SAVIOR) said.. the problem is the CABLE!! (at least in my case):
"None of my computers could find the drive, until I realized, that the USB cable is loose and it gets loose easily... Try different mini-usb cable, might be a problem of all cables supplied with the drive. So far I am happy with the drive. Small, silent, works.."
Iy may seem it doesn't make any sense, but the problem is the USB cable, I tried with the one coming with my External Hard Drive And.. voilà!
Thanks to all!!
Dec 07, 2007 | Electronics - Others
LG GSA-4167B DVD Writer... PC restarts whenever any CD is inserted
What is happening is that the dvdrom firmware or the laser is failing and cannot read the disc; and because the pc is using all the system resources trying to do so; it appears that you cannot get anything to run, making it seem as if the hard drive is faulty also, though not the case. You will need to replace the drive if this is a common occurance, as the life of a dvd drive nowadays dependant on use is aprox 2 years, because as the prices come down so does the quality of the laser required to burn and read discs.
Aug 25, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
