Question about Toshiba Satellite A135-S4467 Notebook
How do I write a cd from file. I have DVD SuperMulti drive & Vista?
I want to write a cd of a file. I would like to know how to do that. Also, if I
put files on a SanDisk Cruzer Micro USB 2.0 Flash Drive can I write a cd
from a file located on the flash drive? Thanks. I appreciate your input.
  • 488 Answers
Hi! one option is to right click on any file u want to write and use the send to option to "DVD/CD drive" and follow the steps or use a software like Nero
if the san disk shows up on your computer and you are able to browse its files then u can follow the above method to copy them on cd..
hope it helps!
please get for any help.
Posted on Nov 02, 2008
How to download a cd from a portable device into mac
Do you mean "how to burn files from a portable device to the mac" instead? You will need burning software like Nero or other software that is compatible with your mac. The process includes copying the files from the portable device to your mac hard drive then use burning software to burn the files to a dvd or cd disk. I don't know about mac but with a pc, you simple drag and drop the files from the portable device to your hard drive using Windows Explorer.
Apr 08, 2014 | LG Electronics 8x Slim External Usb Dvd...
How to change faceplate on LightScribe SuperMulti 8X DVD R/RW with Double Layer Support in hp pavilion
Why would you want to remove the faceplate?
If you have a dvd or cd stuck in the drive straighten out a gem clip (paper clip) and stick it into the hole that is on the faceplate (drive drawer that holds the cd or dvd) and push it while you press the eject button.
May 10, 2012 | HP Computers & Internet
I cannot Read and write the DVD as i'm holdin a LG SecurDisc Supermulti writer,so what should i do now
CD/DVD Drive is Corrupt or Missing (Error Codes 10, 19, 31, 32, 39, 41) Note: The solution provides requires editing of the registry.
1.To begin the process, start the Registry Editor.
  • Click Start, click Run, type regedit, and then click OK.
  • On Vista machines, Run is accessible through Accessories.
  • Click the plus sign (+) next to the following folders in the left side of the window pane:
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
2.Look for any of the following names in the right side of the window pane:
  • UpperFilters
  • LowerFilters
3.If any of the items above are listed, right-click on the item and select Delete.
4.Be sure to restart your computer after you have deleted the files in the registry.
5.Open My Computer (XP) or Computer (Vista) and check to see if your CD or DVD drives have returned.
6.In some cases, you may need to reinstall some programs such as CD or DVD burning software, iTunes, or Nero
Oct 17, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
HP PAVILION a6000n with lightscribe supermulti drive / cd writer---windows vista :: does not recognize dvd disc when inserted
If it fails to recognize and CD or DVD that's inserted you will need to reinstall the driver for your LightScribe. The factory drivers for your system can be found here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3548643
If it fails to recognize just one CD or DVD, chances are that the disc is defective.
Dec 02, 2009 | Cars & Trucks
LightScribe DVD SuperMulti Drive/CD-Writer won't read disks. It has been cleaned and passes all tests. Has read these disks before, but file will not load from disk.
check and see if there are updated drivers and install them. have you changed your Operating System via upgrade or anything.
May 26, 2009 | HP PAVILION A6230N DESKTOP PC
Dvd not reading
Clean your lens with lens cleaner cd and then try it.....
May 20, 2009 | LG SecurDisc 20x Internal Double-Layer DVD...
How to write a cd from a file on Notebook(Vista) and from a USB 2.0 FlashDrive
it is possible,theoretically,
when you'r familair with burning programs.
i personally like freeware program burnatonce.
the flash drive should be recognized by windows,
then it can be handled like any other harddisk.
install burnatonce, run it, insert a CD-R
now goto 'mastering' choose type of cd, then drag and drop the files you want to burn to the cd-project, choose 'compile' and set the burning speed to a medium, depending on what your drive supports.
now tick ' simple TOC', then 'write'.
Finished. Check if the computer can read the CD.If ok - Any other windows computer should be able to read it now.
To get the maximum of the CD-R's 700 or 800MB storage capacity, you may want to create a multi-session CD. Careful,with that option, as the CD will only be readable in the drive you created it until it is 'finished', meaning that an lead-out needs to be written.
If that is too complicated, leave that option aside, make sure' multi-session' stays unticked -and you are on the safe side.
If CD is not a give-away but just for data storage or transport,
use a CD-RW instead, which can be erased up to 10 times, this may help to keep your budget on low profile - but the one your giving it to should have a cd-rom7dvd-drive that supports CD-RWs
Want to know more? Just Post another fixya question
Nov 02, 2008 | Toshiba Satellite A135-S4467 Notebook
Lightscribe dvd supermulti drive
You can get information at the support site HERE.
Geno
Mar 10, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
LG MODEL NUMBER GSA-H42N 18X SUPERMULTI DVD BURNER NOT ABLE TO WRITE ON SONY DVD-RW DISC
in window under my computer is your DVD writer shown as DVD-RAM drive, if not then re-instal the drivers for your DVD.
If its installed as DVD-RAM then right click the DVD-RAM icon in the my computer and choose properties, under the recording tab select enable recording, try burning a cd using the windows xp based roxio by sending your files to the DVD-ROM.
If it burn a CD this way then all you neec to do is use a different CD burning application software.
Oct 22, 2007 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Toshiba Satellite A135-S4467 Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
