Question about Kenmore 43142 Front Load Washer
Kenmore front load tumble action washer
My washing machine stopped tumbling and/or spinning, it sound as though it is trying to do something but it is not. Could it just be a belt? Thanks
  • 4 more comments
  • Stacey Alcorn Sep 24, 2006
    Yep, it looks like there is a bad fuse on the speed control board and it needs replacing.(about $153 for the part, plus tax & shipping)
    Thanks so much for the help!
  • gurvgill Sep 28, 2008
    the washer wont go into fast spin to drain
  • poopka321 Feb 21, 2009
    my basement flooded recently. about 2" of water high on washer. after the floor was dry, i tried to use my washer. the tub fills w/water, but does not spin at all. it goes through the cycles (much faster than its supposed to). it just fill w/ water and pumps it out (leaving the clothes soaking wet). is there something i can do, with out paying sears repair guy over 100.00 to show up???
  • Anonymous May 04, 2009
    how do I replace the belt on my Kenmore tumble action washer model #417?
  • Anonymous Mar 17, 2014
    kenmore tumble action washer model 417.29052991 won't agitate or spin
  • Anonymous Mar 20, 2014
    power is in gas is on it just stopped tumbling.
    President:
  • 878 Answers
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board. Catriver...post back.
Posted on Sep 24, 2006
My washer fills up with water but does not turn or agitate, i goes thru the whole cycle but never agitates. this washer is fairly new and in great condition other than this problem. Any help and advice would be much appreciated. thanks
Posted on Aug 26, 2009
My kenmore model 41748102701 tumble action washer will not dipense the fabric softener now its still in the tray . The soap does dispense.
Posted on Mar 06, 2010
Our washer, almost 6 yrs. old would pump but wouldn't spin. I took the back cover off to check the motor and discovered one of the wires in the harness (opposite of the motor plug) was broken at the plug. This was a motor winding conductor. Luckly, I was able to remove the pin from the plug, open the top crimp, strip the wire and solder it back to the pin. Don't forget to re-crimp the top of the pin over the insulation.
Posted on Dec 06, 2007
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: I have tumble action washer, Kenmore model
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Kenmore 3.5 cu ft front load quiet tumble action washer. Will not stop cycling, leaks, and shakes violently when spinning.
The shaking could be due to a defective drum support bearing. The shaking also could have caused the door seal to fail, resulting in the leak.
Jan 22, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
I bought the Whirlpool Duet to replace my old standard washer & dryer and I find that the wash time is longer than the old washer. Even the quick wash takes about 1 hour. Am I doing something wrong...
I assume from your comment that your old washer was a top loader. Yes, front loading machines typically have longer cycle times than top loaders. There are several contibuting factors... first of all, the wash action of a front load is to oscillate the drum back and forth as well as provide a slow tumbling motion whereas a top loader w/ agitator or impeller has a more aggressive action. The more aggressive action rolls and tumbles your clothes more often and therefore cleans faster. Also, because front loaders spin very fast (up to twice as fast as top loaders) to reduce the amount of moisture left in the clothes, they need to have balanced loads. They accomplish this by testing and rebalancing your load several times during each cycle before beginning to spin.
That was a long answer to your question- no, you are not doing anything wrong.
Good luck.
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My tumble action washer spins out of balance no matter if it is leaded with clothes or not
turn the tub by hand and see if it wabbles if so only one fix replace inner tub.
Sep 28, 2010 | Kenmore 43142 Front Load Washer
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Jun 24, 2009 | Kenmore 44072 Front Load Washer
Will not spin or drain
take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore 44042 - No spin cycle
The front load washers are supported by springs on the top and shocks on the bottom.  More than likely you broke a spring on the top or cracked one of the shock mounts which causes and unbalanced load all the time.  Will it go through a spin cycle with no clothes is it?
Oct 17, 2007 | Kenmore 44042 Front Load Washer
Kenmore 43142 Front Load Washer Logo
4,385 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
