No picture or sound but get channel and clock on screen display
    Brigadier General:
  • 6,966 Answers
Initially, suspect would be your audio/video sources such as the DVD, Home Theater, Cable box, Satellite Receiver. Pls check the cables/wirings or how they are attached to the PTV. If the PTV is connected directly to a cable provider with the this issue, then it is either your cable provider's signal is not reaching you or the PTV's tuner section needs to be looked up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 02, 2008
My TT was imported new from Japan....Has AMAZING video and sound system unfortunateley its all Japanese to me!! The manual that comes with it is about an inch think...Its got built in Navigation system...
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
  • 0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
  • 0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
  • 0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
  • 0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
  • 0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
Channel 003: Language (Screen)
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
Channel 004: Back-Up Camera
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
Channel 011: Language (Speech Recognition)
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
Channel 069: Display Mechanism
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
Channel 070: Display Brightness
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
  • Range: 875...1080
Channel 117: Signal Test (Output)
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
Channel 136: Driver Position
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
  • RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
Jul 04, 2010 | 2007 Audi TT
Sound not picture
A few questions:
Are you using this TV directly on a cable line of do you have a cable box or satellite receiver connected?
Do you have sound and no picture on the AV inputs as well, or only on TV channels?
Is there anything on the screen or is it completely black? Has the picture collapsed to a single line across the screen? Is there a picture but it's distorted?
Does the on-screen menu and channel number display properly?
With a little more information I might be able to help you with this.
Feb 11, 2010 | Toshiba 32A33 32" TV
My mitsubishi wt-a42 had power surge now i have channel display and sound but no picture
So! You get the Channel # that is displaying on the screen and it's sound from the channel but not the video of the channel?
A/V Media Guy
Nov 22, 2009 | Televison & Video
Toshiba tube tv display doesnt show
when you unplugged it,it reset the clock.you need to set the clock.
on the remote play with the input,menu and display buttons until settings come up.one the date and time is set,probably ok.the best thing is to see if your friend has the manual.there are literally hundreds of different toshiba t.v. alone
May 22, 2009 | Toshiba Televison & Video
Panasonic dmr-eh50 Clock setting greyed out - unable to reset clock after clocks went back.
To resolve this issue follow the steps below:
(1) Remove all discs from the unit.
(2) Set the unit to DVD Mode
(3) From the front panel of the unit, open the middle door to display the up and down channel buttons
(4) Press and hold both the up and down channel buttons until the unit displays "BYE" and then flashes "12:00 A"
(5) Release the up and down channel buttons
(6) This will clear the unit and you will be prompted to reset the TV Guide Settings
(7) Setup your TV Guide according to the on screen display
(8) From your remote select "SETUP"
(9) Scroll down to "Setup", right arrow to the options on the right, and down arrow to "Clock Settings"
(10) Select "Set Clock Manually" if your TV Guide Function is not providing you with the proper time
Good luck!!!
Oct 26, 2008 | Televison & Video
I get sound but no picture on my apex at2402.
if there's a channel and volume display but no picture,the problem of your tv is ABL..it is a resistor value from 10K ohms up
Oct 10, 2008 | Apex Digital AT2402 24" TV
Sound with no picture
the problem is in the backlight try to measure the supply.and replace the inverter.
Dec 05, 2007 | Toshiba LCDTV/DVD Player 19HLV87
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
I have clear sound on the tv, but no picture
DO you get any on screen displays (voulme, channel etc)? If so then you have no video. If no on screen displays then you have a high voltage issue that needs to be checked by a technician.
Feb 27, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
