Question about Nikon N65 QD 35mm SLR Camera
Slr camera's lcd screen only says i have taken 3 pictures, and keeps sayin ERROR, what could be wrong? I tried replacing the batteries and the camera still says ive only take 3 pictures, even when i out new film in.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
Try resetting the counter by pushing and holding the two rewind buttons simultaneously ( red symbols ), one on each side of the top cover. Then open and close the film door.
Posted on Nov 01, 2006
Nikon error code
This error the manual says: please contact the Nikon service centre closest to you. You could try to switch of the camera, remove the battery and replace it and then switch the camera on again, but if the error comes back you should contact Nikon.
Don't forget to check if everything on you camera is ok.
Battery charged, lens correct mounted. Memory card with enough space to save pictures )(correct format)
Dec 30, 2013 | Photography
Repair
If you are using standard or "Heavy Duty" batteries, this is not unexpected. Try Alkaline or even better, rechargeable NiMH batteries, they have a much longer life. Some of the earlier digital cameras were real power hogs.
Hope that helps,
Bax
Jun 16, 2013 | Pentax ZX-30 35mm SLR Camera
I purcahsed a new canon SLR 7D and have an error message on the LCD screen E30. instructions says to remove battery pack or turn off the camera but it seems its not working at all. i have tried so many...
According to Canon's Knowledge Base here, this error means that there is a problem with the shutter. It appears that the camera needs service. If you just purchased the camera, it should be covered by warranty.
Mar 26, 2010 | Canon Cameras
Pentax K200D NO LCD just viewfinder visual
Pentax K200D is a SLR Digital Camera..... in SLR you can the images in LCD after it has been taken.... while cliking image you need to use the Viewfinder......
Mar 24, 2009 | Pentax K200D Body only Digital Camera
LCD Malfunctions
Your camera's shutter mechanism or camera's CCD may have encountered problem.If so have a replacement if under warranty or try this:
try resetting the camera from reset switch or menu.
pull out the battery and memory card for 2 to 3 days and reinsert them after that. May your problem gets solved.I got the same problem with my nikon d80 slr trying these methods i got my problem solved hope yours also.
KAMAL GO
brijwasistudio@gmail.com
Nov 09, 2008 | Canon PowerShot S1 IS Digital Camera
Lcd screen stays on and cannot see subject
"Live View", where you can see and compose your picture on the LCD, was not available on any digital SLR before 2007 (the Rebel XTi came out in late 2006). So you need to compose your picture using the optical viewfinder, take your picture, and the picture shows up on the LCD after you've taken it.
But it's still faster than having to wait until the film is developed. :-)
Jul 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
LCD goes blank whether camera is on or off
Hey sirath,
I know you just got the camera serviced, but from how you describe the issue I would say there is a problem with the connection of the LCD to the camera (i.e. a loose wire). I am assuming that the camera will still take a picture, but you just can't see anything on the LCD screen. If this is the case I would have it looked at by an authorized service technician, and I would bring it back to whomever worked on the camera before because it is possible that the previous repair caused the problem and if that is the case this repair would most likely be free. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 23, 2008 | Canon T70 35mm SLR Camera
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D50 LCD Display does not work
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
Dec 04, 2007 | Nikon D50 Digital Camera
Problem taking pictures.
Every Camera has differnt firmware. Check your manual thoroughly then get on to Canon Technical Support.
Jun 25, 2007 | Nikon N65 35mm SLR Camera
Nikon N65 QD 35mm SLR Camera Logo
78 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Steve
Are you a Nikon Photography Expert? Answer questions, earn points and help others
