Question about Goodman GMS90703BXA Heater
Mounting and securing a cased coil on a Goodmam upflow furnace
Hi, how do you secure a cased coil onto Goodman Gmv950704cx furnace ?
  • 1hotwire Nov 02, 2008
    Hi, I 'm intsalling a Goodman mv950704cx and a cased coil for a 3 ton a/c ssx14 .
    the cased coil sets on top of the furnace, how do you secure it in place ? it looks like wou would just put screws in the side and and run them into the flanges sticking up .
    Do you put cauking around the top of the furnac before setting the cased on it?
    Thanks, 1hotwire
    Problem Solver:
  • 22 Answers
Yes you use sheet metal screws and than use Foil tape, works better than caulk imho.
Posted on Nov 03, 2008
Condensation water drips from top of unit
I WOULD CHECK THAT YOUR PVC PIPING IS SEALED PROPERLY.
Feb 22, 2015 | Goodman Manufacturing GMVC951155DX 95%...
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
Where are the filters located
THIS MODEL NUMBER IS FOR THE CONDENSOR ONLY. THERE A COIL CABINET INSIDE YOUR HOUSE. IT IS NORMALLY MOUNTED ON THE TOP OR BOTTOM OF YOUR FURNACE. LOOK FOR THE INSULATED PIPES CONNECTED TO IT. THE FILTER WOULD BE DIRECTLY BELOW OR DIRECTLY ABOVE THIS DEPENDING ON YOUR SYSTEM BEING UPFLOW OR DOWNFLOW.
Jul 14, 2014 | Goodman Manufacturing GSC130301 Central...
Updraft evaporator pan cracked and leaked at male hose bib
Yes its possible to break it. Takes alot of force usually only happens during shipping due to hard fall.
Aug 29, 2012 | Goodman Manufacturing CAPF Cased...
I need piture of my a/c coil to find access panal location to clean evap coil.
It really depends on what system you have, i.e. model number and manufacturer. Most of the time though, you will have the furnace sitting on top of the coil, or the coil sitting on top of the furnace, depending on if you have an upflow or downflow system. Sometimes you will have a horizontal unit that lays on it's side, either way, the coil is the smaller box that is separated from the furnace and has copper running into it. If you have a air handler, then the coil and furnace are built inside the same cabinet. On pretty much all these systems, after you take off the front panels, you will either see the coil, (upflow, downflow, horizontal), or see the panels that cover the coil, (air handler). Cleaning them can be tricky sometimes, and if you have a downflow, you will be able to clean the top of the coil, unfortunately on a upflow, you have to remove a piece of metal that holds the coil together to access underneath it. The best way to clean these for a d.i.y., is a small brass or metal brush, brushing with the fins on the coil and not side to side. Make sure the system is off, otherwise you will get a face full of nasty stuff. On another note, if you happen to be talking about cleaning the coils on the outside unit, you don't have to remove anything, just get a water hose with a sprayer and start at the top of the unit and work your way down, being careful not to use to much pressure that you could damage the fins. People don't realize how much money and problems they could save by doing this. Considering I don't have a lot of information on your equipment, I hope I pointed you in the right direction. Good luck!
Mar 13, 2010 | Heating & Cooling
Can I change airflow direction with Goodman GMS8?
I would probably use a furnace for the correct application. However some motors do have a reverse speed connection. Besides the blower speed taps,
capacitor wires and the nuetral wire. There are two wire sets that you can switch that can do this if your blower motor is equipped.
You might experience some airflow problems, probably a lack of airflow, if the furnace was installed
as an upflow model instead of a counterflow.
Feb 17, 2010 | Goodman GMS90703BXA Heater
Change blower to down draft
I dont think you can change a gas furnace from horz/upflow to downdraft,the inducer motor would never prove the pressure switch, the drainpan would upside down,you can order a downdraft unit, i dont believe this unit is made for that
Sep 30, 2009 | Goodman GMS90703BXA Heater
Furnace is leaking water
This is not a lot to go on.
I assume since you called it a furnace, you have hot air heat and central air conditioning. If so, the only way a furnace/AC unit can generate water is by condensing moisture from the air. This is common to all air conditioning and removes humidity from your home. If so, this water, called condensate, must drain. The condensate is collected at the AC cooling coil that is typically located on top of a vertical upflow furnace or downstream of a horizontal furnace. If the drain is clogged, it will overflow and create a mess in and around the furnace. If this is your problem, cleaning and clearing debris may solve the issue. I suggest starting with the easiest accessable part of the drain path. You may need to open the panels enclosing the AC coil and clean the small pans at the bottom of the coil and clear openings from above that look similar to a laundry tub drain. If you get that far and find rust holes in the pan, repairs are needed. If you have an electric condensate pump that may also be the cuprit and require cleaning. Check and clear all drain lines from the coil connection to the final dicharge - sump pit or outside.
Oct 05, 2008 | Goodman Heating & Cooling
A/c works but fishy smell coming through vents
Is this an upflow or downflow unit? (vents in the floor or ceilings?) If an upflow, the coils needs cleannings and disefectant added. (mold-- bacteria--slime-- gooks---darkness plus moisture = bacteria growth.
Jun 05, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman GMS90703BXA Heater Logo
116 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
