Question about Philips DIRECTV H20 DTV Receiver
DTV H20-600 How would I go about testing the voltages? Are there pin outs I would use a volt meter to do the tests? I am pretty sure it is not the power supply since that was the first thing I swapped out between the two units. Also is there a diagnostics mode? I ask because this may or may not be related to the problem. The weird booting procedure is required even if I had the receiver unplugged over night. If I plug the receiver in it will continuously keep cycling the lights. I press reset then it performs a complete cycle and locks and the receiver gets extremely hot. To get it to function I use the procedure that I mentioned in my earlier post.
  • rjrusek Nov 07, 2008
    The receiver does have a ECO 2.0 sticker on it. Does that mean my receiver is a refurb? I would like to try to locate the IC and the transistor so I can test it. It would be great if it was a easy fix.
    Thank you,
    Rob.
  • 2,334 Answers
Before we get into measuring any voltage. Read the info from this link and see if that applies to the receiver that is acting up on you.
Posted on Nov 03, 2008
Voltage regulator
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Jan 28, 2014 | Harley Davidson Motorcycles
Charging system failure low voltage
Jan 07, 2014 | 2011 Harley Davidson FLHTK Electra Glide...
Battery not charging
Jan 03, 2014 | Harley Davidson Motorcycles
Find charging dyna super glide 1450 cc
Nov 28, 2013 | Harley Davidson FXD Dyna Super Glide...
Low RNG
Nov 14, 2013 | 2011 Harley Davidson FLSTF Fat Boy
Battery keeps going dead
Nov 02, 2013 | Harley Davidson FXST Softail Standard...
2002 Harley ultra high voltage
Sep 23, 2013 | 2000 Harley Davidson FLHTCUI Electra Glide...
Intermittent alternator
Hi Denny, perform the following tests:
Sep 09, 2013 | Harley Davidson FLHTCUI Electra Glide...
2000 hd flhtcu doesnt charge battery when running
Apr 10, 2013 | 2007 Harley Davidson FLHTCU Ultra Classic...
Engine light and battery light
Hi Kellyafurlon, perform the following tests:
Jun 30, 2012 | 2007 Harley Davidson XL 883 Sportster
Philips DIRECTV H20 DTV Receiver Logo
413 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
