Question about Maytag MDG2706A Gas Dryer
Flame shuts off after five seconds
The igniter turns on, then the flame goes on for about three seconds and shuts off. After around fifteen seconds, the flame goes on again and again shuts off, and so on and so on.
  • Anonymous Dec 05, 2008
    I replaced my thermocoupler but still not working, flame won't stay lit. do you know y?
  • Anonymous Mar 22, 2009
    Flame dont start at all
    Novelist:
  • 208 Answers
HI! I BELIEVE THE PROBLEM YOU ARE HAVING IS CAUSED BY A PART CALLED THE THERMOCOUPLER. THIS IS A SAFETY DEVICE THAT SHUTS OFF THE GAS IF THE FLAME GOES OUT, BUT IT NEEDS HEAT TO MAINTAIN THE PROPER CIRCUIT. THIS MEANS THAT THE THERMOCOUPLER IS BAD AND NOT HOLDING THE GAS VALVE OPEN AS IT SHOULD. IT IS A SMALL THIN ROD TYPE THING THAT WILL BE VERY CLOSE TO THE PILOT OR IGNITER AND IT HAS TO FUNCTION PROPERLY TO ALLOW THE GAS TO CONTINUE TO FLOW. WHAT IT IS DOING IS GETTING JUST WARM ENOUGH TO OPEN THE GAS VALVE, BUT THEN THE IGNITER STOPS AND THE BAD THERMOCOUPLER COOLS AND TURNS YOUR GAS OFF. YOU NEED TO REPLACE THE THERMOCOUPLER AND YOU SHOULD BE BACK TO WARM CLOTHES IN NO TIME. HOPE THIS HELPS YOU. ANY QUESTIONS, JUST REPLY AND I'LL HELP MORE.
ARCLIGHT1217
Posted on Nov 02, 2008
Igniter comes on and flame comes on. Igniter goes off and 40 seconds later, flame goes out. About 40 seconds later, igniter comes back on and then flame comes back on. About 40 seconds later, flame goes...
It sounds like the sensor that determines that a flame is present is not working. Find this sensor by looking for a device that is exposed to the flame and has wires going to it. Check this sensor and replace if necessary.
Sep 12, 2013 | Dryers
Luxaire by York Furnace,Model# G8T10012UHB11A,8 Red LED Flashes = Ignition lockout due to recycles,Has flame for a few seconds then goes off; does it around three times,Fan is working; blowing cold air
It sounds like you have a dirty or bad Flame Sensor. They sometimes get a white coating on them. It's not detecting a flame so it shuts off. Sometimes you can clean them and they will work.
Nov 06, 2012 | Coleman Heating & Cooling
Igniter goes on blower runs for 30 seconds main heater flame ignites and burns for approx 30 seconds then it shuts down for approx 10 seconds and repeats the same sequence 3 times, then shuts down...
there should be a flame detector sensor. it is in the flame. this will need to be cleaned with a wire brush or scrapped with something to get the carbon build up off of it.
you will see something that in in the flame area that is kind of charred and black with a wire coming out of it.
this is designed to tell the unit that there is a flame present and if that flame is not there after serveral attempts it will shut it down. because it there was no flame there you would get gas fumes pumped into you house.
you could change it out or usually you can just clean it and it will work fine.
hope this helps
rick
Jul 15, 2011 | Kitchen Ranges
I have a goodman propane furnace, model # GMPN080-4 that lights for about five seconds and then cuts off. It does this three times and then stops all together. Tried lightly sanding the flame sensor and it...
The goodman furnace will try and light three time before it faults out for safety reasons. Adjust the flame sensor so that it is closer to the flame or actually in the pilot flame. If the flame sensor is inside the pilot flame and still does not stay lit, your flame sensor is probably defective and should be replaced. You can get one at Ferguson's counter sales.
Dec 12, 2010 | Heating & Cooling
Furnace will start and sequence fine run for five minutes or so then the flame cuts out....miller type furnace put a new board in last year so now it cycles three times and goes into soft lockout.....
Clean the flame sensor.
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 19, 2010 | Heating & Cooling
My Rheem Ruud 25M01A water heater flame goes out before the thermostat is satisfied. The igniter goes into a ignition sequence from here on trying to get the flame to ignite for ever. If i turn the unit...
Check the air lines going to air pressure switch for cracks or splits. I know that will affect the gas valve but not sure if that is your problem.
May 07, 2010 | Heating & Cooling
The heat turns off after 3 seconds of flame.
There is a flame sensor failure.
Here is the ignition sequence for a furnace. This will help you understand what is happening/not happening.
Thermostat2.gif calls for heat.
draft inducer motor (DIM) starts drawing draft through heat exchanger.
Pressure switch detects proper operation of DIM, and sends signal to board to begin ignition.
(it detects negative pressure)
Ignitor starts ignition attempt and gas valve sends gas to burners.
Upon ignition, flame sensor detects flame and sends signal to board stopping ignition sequence and continuing gas flow for heat mode operation until thermostat is satisfied.
During this sequence the blower motor is brought on, and by using a series of temperature limit switches, the system assures that the unit is operating properly.
(If the blower is not operating, or the airflow is inadequate, the heat exchanger will overheat and trip one or more temp limit switches.)
There is also a "rollout" switch that detects improper flame pattern "rolling out" into the controls compartment.
Now, to apply that to your situation.
If the flame sensor does not sense flame, it shuts down the furnace to prevent a dangerouse gas build up.
With most modern glow coil ignition systems you have one of two failures.
1) the flame sensor is bad and needs to be replaced.
2) the control board is not proccesing the signal from the flame sensor and shuts the system down. In that case the board would need to be replaced.
There is a possibility that a temperature limit or roll out switch is breaking the curcuit, but that would be quite unusual to happen consistantly at three seconds.
Unless you have the ability and tools to test the snesor and board, the next step would be to replace the sensor first, and then the board if that does not fix it.
Oct 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Hvac
dirty flame sensor
Oct 28, 2008 | Goodman Heating & Cooling
Honeywell Gas Furnace
A Make and Model number of the furnace not the thermostat will help but I can walk you thru the operation of a typical furnace. It sounds to me that the burners are igniting properly but the flame sensor is not sensing the flame and shutting down the system. You will need to find the sensor and clean it and check the wire from it to the control board. Typically, the flame sensor is found at one side or the other of the burner box. It is a small probe that the flame hits. Depending upon your model it may have a small wire attached to it leading back to the control. Or it may be part of your auto-pilot assembly. ? At any rate, you will need to get to it and very delicately brush it off. Then inspect the flame channel. This is a trough area where the flame travels to ignite all burners. Over time, they tend to fill with rust and debris. Take a small screwdriver and run the blade down the trough. Inspect the wire that goes from the flame sensor to the control board. Make sure it is not frayed or broken or shorting out and that the connection at the board is good.
Beyond that, it's time for a technician to come.
Let us know the Make and Model of the furnace (found inside the furnace cabinet) and maybe we can help you further.
Nov 19, 2007 | Heating & Cooling
Maytag MDG2706A Gas Dryer Logo
398 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
