Question about Olevia MN-27LCDTV-SN 27 in. Television
TV won't turn on, please help......
1 year old Olevia 327-S12 stopped working. Blue light comes on when power cord is plugged in but no response when pushed.....nothing. Remote does nothing as well. It's a nice blue light but I would like the TV to turn on ;-(
This started to happen intermittently. Sometimes if I unplugged the TV, waited a few seconds, plugged it back in...it would work fine. Now it is stuck off with the solid blue power light shining.......doing nothing.....
There is one interesting thing I noticed as this was happening. If I plugged the TV in and the power light came on briefly, then blinked out....then back on solid a split second later....then the TV would turn on and work great. If on the other hand I plugged the TV in and the power light went straight on with no quick blink.....then it won't work.
It almost seems like it wont boot up or something? I checked for bad capacitors and visually they look ok. I tried plugging in USB cord but my computer says "The USB device connected has malfunctioned and windows does not recognize it".
Thanks for any help or words of wise consolation.
  • jazacher Apr 21, 2009
    Same problem with my Olevia LT30HV. Took it to the shop and they replaced the power supply. Worked there I tookit home. Blue screen while I put batteries in remote and then nothing since. Took it back and they said I now need a motherboard. Gave me the brush off answer about looking at the capacitors. I will let you know how it turns out.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Change your power suply
Posted on Nov 02, 2008
Sound quit on Olevia SyntaxBrillian 232-S12
A common symptom of power supply trouble is disappearing sound
Apr 01, 2013 | Olevia Televison & Video
Olevia 232-s12 not powering on
u have a bad mainboard or power supply board most likely the mainboard
Mar 02, 2013 | Olevia Televison & Video
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
Olevia 37" LCD TV will
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Aug 20, 2011 | Olevia LT32HVM 32 in. LCD Television
My Olevia 237-s12 TV won't turn on. When we push the power button, the blue power light flashes on/off repeatedly. We have unplugged the TV to reset the system but no change. Is it shot?
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps in solving the problem.....
May 07, 2011 | Olevia 237T 37 in. LCD TV
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
Tv isnt coming on but is getting power
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 18, 2010 | Olevia LT42HVi 42 in. LCD Television
My Tv, Olevia LCD HD TV 242 FHD T11, will not turn on
Same thing Just happened to me ths AM. Acting Wierd then this morning fuzzy screen and poof won't come back on.
Comcast box was resetting at the exact same time and I found this online....
http://www.my3cents.com/showReview.cgi?id=18330&s=1188
Mar 06, 2010 | Televison & Video
Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Dec 07, 2008 | Syntax LT26HVE 26 in. HD-Ready LCD...
TV tuner
Bill, did your tuner go out? I have had the same television for one year. We had a storm and our Buckeye cable went out. All the other tvs came back fine except for the room with the Olevia 232-S12. Everything works now except for the tuner. Cable came in and installed a converter box. Just wondered if you had the same problem (not the storm, but the tuner)
Jan 08, 2008 | Olevia LT32HVM 32 in. LCD Television
Olevia MN-27LCDTV-SN 27 in. Television Logo
765 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
