Question about HP LaserJet 4L Printer
HP Laserjet 4L - Grinding or Growling noise when job sent to printer
When I send a job to the printer the blinking green light starts, the printer starts a growling or grinding noise. The noise lasts for about 3-5 seconds and the paper light blinks and goes off and the error light comes on. When I pull the paper tray out the top sheet has lifted and advanced about a quarter of an inch. Not other paper jammed in the printer. Any help would be appreciated. Bill Reavis wnreavis@sbcglobal.net
  • Anonymous Nov 10, 2008
    i have exactly the same problem.
    Printer LAserjet III D
  • Anonymous Dec 07, 2008
    I also have the same problem.
Replaced the Drive Motor Gear. It had split open and was slipping on the splines. Runs great again
Posted on Nov 18, 2008
    Genius:
  • 1,605 Answers
Goto feedroller.com
http://www.feedroller.com/Store/index.php?cPath=1_17_86_25
purchase a maintenance kit.
replace the piper pickup roller.
since the the printer is old and lots things need to be replaced. it is easier to replace all of the necessary parts when you have the printer apart.
the job is not difficult, just time consuming.
Posted on Nov 17, 2008
Hp 4L printer won't pickup paper from tray. Sequence- green led light- motor running but with grinding- no movement from pickup roller or foot- finally a misfeed led light.
That is a very common problem with the Laserjet 4L and 4P printers. The sound you hear is caused by a broken motor drive gear. This is a small plastic gear on the drive motor shaft. They can develop a small crack which prevents the motor from turning the gears for paper pickup and toner movement. When the motor tries to turn the broken gear can not turn the other gears and makes the popping or grinding sound when the gear teeth slip. You will need to replace the motor gear, it is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
I hope this helps,
BuddyMc
Jul 16, 2012 | HP Office Equipment & Supplies
Printer hp laserjet 3005 make noise when printing
If it is growling and or grinding, check my tip (click on tip to go to it)
You may qualify for a free repair from HP.
Apr 27, 2011 | HP Laser Jet Printer P3005dn
I've got a 4L that has been an absolute workhorse and it makes a grinding noise here recently and will not print. I hate to replace it as the cartridge lasts about 10 years. I know its about 15 years...
The grinding noise is caused by a cracked motor gear. This is a very common issue on the Laserjet 4L and 4P units. It is a fairly easy repair but you will need to disassemble the printer to get to the drive motor. The gear is available here:
Feb 16, 2011 | HP LaserJet 4 plus Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
My HP LaserJet 4L printer just makes a grinding sound when I attempt to get it to print. It makes the sound for several seconds and then the Paper light starts to flash without printing
Common issue with these older 4L printers. The problem is a small plastic gear on the main drive motor has cracked. This is what causes the noise and since the machine is not "running" there is no paper feed and thus the paper jam light. Basically there is no drive to any of the printers components. May be hard to find a replacement motor these days but that is what you would need to fix the printer.
wheatlandsvcs
Aug 18, 2010 | HP LaserJet 4L Printer
My HP LaserJet 4L printer just makes a grinding sound-won't print
That printer has a gear on the motor that cracks. You can fix it with a new or used motor. Or get a different machine on craigslist. Thank you, Steven 805-520-3003
Jul 26, 2010 | HP LaserJet 4L Printer
HP Laserjet 4L just started printing black pages. After a few pages they print are normally. It all starts again when I begin another print job after some time passes after the last job. Put a new...
The image drum is not getting the correct signal at the correct time. It is time to retire the 4L and replace it with a newer, faster LaserJet. You'll be glad you did.
Nov 19, 2009 | HP LaserJet 4L Printer
Laserjet 4L - all lights on
It is easy. I used to sell hundreds of Hp 4L printers. Replace the main board. we may still have it. 1-510-265-1414 pm PST
Jan 01, 2009 | HP LaserJet 4L Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
HP laserjet 4L wont print from computer
reinstall the printer driver.
Windows operting system have the printer drivers. you don't need to download it.
if you really want to, goto HP.com>> service and support.
Oct 21, 2008 | HP LaserJet 4L Printer
HP LaserJet 4L Printer Logo
295 people viewed this question
Seeker5211
Seeker5211
