Canon MVX25I Mini DV Digital Camcorder
Problem for Canon MVX25I Mini DV Digital Camcorder
Power failure and I need to remove tape
By ChrisRauch on Sep 23, 2006
My Canon MVX25i has a power failure. It will not recharge the battery and I have tried a fully charged battery and there is no power to the unit. I need to remove the tape but cannot do so without power.
Does anyone know how to replace the fuse or get the tape out without power?
I would prefer not to send the device to a repair centre as I need to get it fixed quickly.
Thanks
Same Problem
Aug 20, 2008
-   It appears that I have some fuse(s) have blown, from some possible dirty power. Currently, all I an getting is red inidcator light instead of the green for power. Neither the Play, Playback or Mini Tape Carriage will engage. I was looking for diagram where the fuse(s) are locatedd but can't find one, so can you help?-   jsing
Best Solution
posted on Sep 28, 2006
Very Helpful)
anexperimat
Rank: Apprentice
Rating: 96%, 3 votes
I had a similar problem, and I think I have a simpler solution. I have a Canon ZR85, and it may be similar to yours in that on the docking bay (where you attach the battery to the camera), there should be a small removable cover that holds a smaller, flatter, circular battery. Replace this. I used a CR1620 battery lying around from a watch I took apart, and now my camera powers up fine even though it requires a CR1616. I'm not sure of the cause of all of this, but I sure hope that helps. It was a definite relief for me.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 25, 2006
Somewhat Helpful)
scrajmer
Rank: Wiz
Rating: 81%, 500 votes
If you can do the repairs yourself there are two ways to fix the problem.
Dismental the camera. Try to locate the power board. have a keen look at the components near the battery connector or the power connector. there you will be able to locate 3 to 4 safety fuses. check the continuty. if found open replace it and the problem can be solved. AND
the other way is to locate the motor for tape deck loading mechanism. Remove the flex ribbion connector of the motor from the pcb, then try giving 3volt supply from an external device to the motor in both the direction. in one direction it will move the deck outward, but be carefull when the cassette is being ejected a little portion of the tape may get damaged.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Canon MVX25I Mini DV Digital
Questions and Unsolved Problems for Canon MVX25I Mini DV Digital
Do you recommend Canon MVX25I Mini DV Digital Camcorder?
Answer
Answer
my vivitar dvr850w records very dark in the house even on the brightest settings?
Answer
I am looking for info on how to use my Panasonic pv43 as a webcam.It has rca plugs.
Answer
how do I move a movie off the unit to my mac?
Answer
Hi there - how to transfer movies from the tape part of the Canon MVX25i to PC?
Answer
My video camera MVX 25i/MVX20i still work very well until last week when I plugged the adator to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon MVX25I Mini DV Digital...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
