Question about IBM xSeries 346 Server
IBM server daily starting problem mess. disk boot problem
    Guru:
  • IBM Master
  • 829 Answers
Can you hold the drive in your hand while the system is on
if so does it feel like its spinning
if not it is dead
try giving it a sharp twist from right to left and or light taps on the side
I'd say it cooked and if there nothing real important invest in a new drive and windows 2000 pro OS
should run on that machine
Posted on Dec 17, 2008
While booting in recovery console it is giving no hard disk found . Server IBM eServer x3400-[797712Q]. OS: Windows 2003 STD
try other good known hard disk install it on your server, if it detect the presence of that disk then your hard disk previously installed has the problem, it going to be defective sooner or already defective
Feb 15, 2011 | IBM x3400 Server
Question: I have one server for IBM X3400. this con't booting that problem was Fatal error: controller monitor failed conterollre not started . .
I have one server for IBM X3400. this can't booting that problem was controller monitor failed controller not started
Dec 15, 2010 | IBM x3400 Server
Windows 7 installing but windows server 2003 cannot install, hard disk is not support
In order to install Windows 2003 , you need Ibm Server Gide cd . Boot from the cd and follow the wizard
You can download the software from below link
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5087263
Its a image file . So after download burn image to cd and boot from cd.
That' all
Oct 24, 2010 | IBM x3400 Server
Hard disk upgrade
I faced the same problem i asked to the ibm people they said that non ibm hdd's are not supporting x3400 servers and they are hanging when we work with non ibm hdds. when I use segate 1 TB sata hard disk the server working fine the only problem is little bit slow for booting and programme running, this not a broblem. so pls use 1 TB sata hdds with your x3400 servers.
Jan 15, 2010 | IBM x3400 Server
How to install windows server2003in ibm server x3400
The install is fairly easy. Before you begin make sure if you have SCSI adaptors installed have the drivers for them on hand. If you do not have these drivers you should download them to a 1.4MB floppy disk. When you are ready, put the Windows Server disk in the cd/dvd and reboot the IBM. Follow the instructions on screen and you shoud be fine. From start to finish it should take you about 1 1/2 hours to complete everything.
Good Luck
Franklin
C2Solutions
Jul 21, 2009 | IBM x3400 Server
New install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
May 26, 2009 | IBM x3400 Server
While installing debian on IBM Xseries 306m it can't detect HDD
Have you initialized the disk from within the BIOS ? if not when you boot the server it says there are no hard disks.
May 07, 2008 | IBM eServer xSeries 306m 8849 (8849E5U)
Server doesnt boot
First create a floppy disk with your RAID driver for W2K3 Server. Next boot the server with the W2K3 Server CD, and hit F6 when prompted, and S to add the specific driver for your RAID and using the floppy to get the driver installed.
Next boot to the recovery console of W2K3 Server. If it finds your hard disk, it will even ask for your Administrator's Password to continue. If this works, then you are probably home free.
Get to the command line of the W2K3 Server Repair console and perform some directory searches to see if the data is there and intact. You can also perform a CHKDSK from that console.
Once you have made sure your data is there and intact, type these two commands: FIXMBR and FIXBOOT
This should solve the problem and when you EXIT out of the console, it should reboot. Remove the CD and it "should" re-boot from the hard disk.
If you still have problems, let me know with how far you got with the steps above. I have another solution but need to know your RAID controller's model (ServeRAID 5i, 6i, etc).
-Chip
Apr 02, 2008 | IBM xSeries 346 Server
IBM Netfinity 5600 8664 81Y Server
The disk that comes with the machine is called the NOS in the manual. It is also known as ServerGuide 6.0.3 which will config your Netfinity up to Win2000 Server. I used ServerGuide 7.3.06 to install Windows 2003 Server. The latest version (IBM ServerGuide Setup and Installation CD v7.4.17) is on the support IBM web site:
http://tinyurl.com/5fmv5k
Sep 21, 2007 | IBM Netfinity 5600 8664 Server
IBM xSeries 346 Server Logo
126 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
