Question about Acer Computers & Internet
Laptop battery - Acer Computers & Internet
  • Acer Master
  • 1,183 Answers
could you be more specific , with the problem that you are facing with the laptop battery.
Thanks
proton
Posted on Nov 02, 2008
How to remove the battery of inspiron 2200
1. Turn your Dell 2200 laptop over.
2. Find the laptop battery release button lock for your Dell 2200 laptop.
3. Now that your Dell 2200 laptop battery is unlocked, find the battery release button down.
4. Holding the laptop battery release button, gently pull your battery away from the laptop.
5. Now that your Dell 2200 battery is removed, grab your replacement Dell 2200 battery for installation.
6. Insert the battery into the slot. Push the Dell 2200 battery towards the laptop and secure it in place.
Jul 04, 2016 | Dell Computers & Internet
Tip
How to take Care of Your Laptop Battery
BATTERY 101 PART 1
What really makes the Laptop or Notebook really portable is its Battery. Remove the Battery then you are indirectly removing the Laptops portability. As human beings we need energy to survive which is form of the food we eat. Similarly a Laptop needs energy to survive. The energy a Laptop needs to survive comes from the Battery which is made up of chemical juice (Lithium Ions). This chemical juice operates optimally at particular conditions. Hence we need to take care of it. Now if you take away the battery of a Laptop, you are taking away the life of the Laptop. We can then understand that it is the battery of the Laptop that keeps it alive.
Since Battery = Life of Laptop it simply means that No battery = Death of Laptop. Because batteries are so important in the existence of a Laptop we definitely have to take care of our Laptop battery.
HOW TO TAKE CARE OF YOUR LAPTOP BATTERY
I observed that many Laptop owners do not really care for their Laptop batteries. You might wonder why? It is simply Lack of information. So i am going to be giving you several tips on how to take care of your Laptop battery. I am going to cover two tips in this Part of the article and continue in subsequent parts. So watch out for Part 2.
TIPS
1) NEVER ALLOW BATTERY TO DRAIN COMPLETELY
Lithium ion battery is the technology used in modern Laptops. Squeezing every drop of its juice (chemical) weakens and strains the battery. Hence cumulative drain of the battery will shorten the life of the battery and eventually kill the battery.
2) NEVER ALOW THE TEMPERATURE OF THE BATTERY TO BE TOO HIGH OR TOO LOW
High temperature breaks down the battery and reduces its overall life expectancy. Always make sure the vents are unblocked and also never work with a Laptop on the cushion because if you do so you will be blocking the vents in the Laptop. If you are wondering how to check the temperature of your battery you could get a software to do that.
on Sep 11, 2010 | Computers & Internet
Tip
How long will my battery last?
Your laptop batteries will deteriorate over time whether you use it or not. Although the Li-Ion industry does not publicize this fact, your laptop battery’s clock began ticking the moment it was assembled. The elements inside your laptop batteries slowly react with each other, eventually rendering the battery unable to supply the required power to your notebook. In addition, your laptop batteries are rated to last between 300 and 800 charge/recharge cycles. It will gradually lose charge capacity rather than abruptly fail to power your notebook.
The general consensus is that laptop batteries last one to three years. While you can slow the laptop battery’s aging and loss of capacity, you cannot stop either decline. The temperature of the battery, combined with the amount and nature of its usage contribute significantly to your battery’s lifespan. You can ease the aging process with some care and maintenance.
Temperature Lower temperatures slow down the self-discharge (loss of charge while disconnected) and aging process of the elements within your laptop batteries. Therefore it follows that higher temperatures shorten the life of your laptop batteries. Leaving your battery connected while on AC power causes the internal temperature of the battery to rise. Removing your laptop batteries and storing it in a cool, dry place will help to slow the aging process. Keeping your notebook in a hot environment is also detrimental to your battery.
Amount of Usage The Lithium-Ion batteries used in notebooks are rated to handle between 300 and 800 charge/discharge cycles. Some of these cycles are used when you leave your laptop batteries connected to your notebook while on AC power. On AC power, the notebook will routinely “top-off” the battery when its charge reaches predetermined levels (i.e. 95%). Removing your laptop batteries and storing it in a cool, dry place will help to preserve some of these cycles.
Nature of Usage Li-Ion batteries do not suffer from the memory-effect (requiring complete discharge before recharging to avoid loss of capacity) like older rechargeable batteries. Regular full discharge/recharge cycles result in an increased loss of capacity per cycle. A series of partial discharge cycles are better for Li-Ion batteries than a single full discharge. You should, however, calibrate your laptop batteries routinely. Tell No One You Can Save up to 35% 3323.jpg
Dell TC030 Laptop Battery
Today's Price:AU $94.55 3711.jpg
Dell 312-0460 Battery
Today's Price:AU $106.31 3770.jpg
Dell GK479 Laptop Battery
Today's Price:AU $92.93 4214.jpg
HP HSTNN-OB81 Laptop Battery
Today's Price:AU $65.72 inspiron8600.jpg
Dell 01X284 Laptop Battery
Today's Price:AU $82.01 1797.jpg
Dell Inspiron 9100 Laptop Battery
Today's Price:AU $115 75uyf.jpg
Dell 1691P Laptop Battery
Today's Price:AU $79.38 4834t.jpg
Dell 2834T Laptop Battery
Today's Price:AU $74.08 bat-30il.jpg
Dell 2941E Laptop Battery
Today's Price:AU $61.34
on Jun 01, 2010 | Computers & Internet
My dell vostro 3300 laptop battery not charging since i re installed windows 7
Laptop battery problems are quite common among owners of all brands of notebooks. On average, laptop batteries last one to three years. Their exact lifespan depends on several factors, such as how much you use the batteries, the number of charge-discharge cycles and the quality of the batteries. Lithium-ion batteries begin to lose the ability to hold a charge over time. Before you replace a laptop battery, consider that there may be other reasons that the laptop is not working properly. You may be able to recharge the battery instead.
1.Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
2. Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
3. Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
4. Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5. Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.I hope you find it very helpful. Best regards.
Dec 09, 2012 | Dell Vostro 3300 Notebook
Laptop won't charge battery
Dec 05, 2012 | Lenovo Computers & Internet
Tip
Hp dv9000 battery
DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Chemistry : Li-ion
Voltage : 14.8V
Capacity : 4400mAh
Corlor : Black
Original Price: US $85.63
Special Price: US $65.63
warranty.jpg * 1.One year warranty, 30 days Money Back.
* 2.Brand new, 100% Q.C. of every battery.
* 3. Highest quality Japanese battery cells.
* 4. Guaranteed to meet original specifications.
* 5. 100% secure and safe.
  • Shipping: Our laptop batteries are shipped by USPS.
    The battery have a good compatibility with many original laptop batteries for many laptops, even diffenent brands.
  • Descriptions of Hp DV9000 DV9700 DV9600 HSTNN-IB33 Battery 1. 100% new high quality Replacement DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Compatible Li-ion Batteries.
    2. This Hp DV9000 DV9700 DV9600 HSTNN-IB33 battery can be used for the other models and battery part No.
    3. 30-Day Money Back,1 Year Extended Warranty for Hp DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery.
    4. Great After-sales Service Department for laptop battery, fast respond to your request!
    5. Fast delivery if you order the Hp laptop battery.
    6. Need any assistance on DV9000 DV9700 DV9600 HSTNN-IB33 Laptop Battery, please feel free to email us!
  • on Dec 11, 2009 | Computers & Internet
    Battery doesnt charge when plugged in
    Aug 17, 2011 | Gateway MX7122 Notebook
    Where is the cmos battery on a toshiba laptop 2801-s301
    cmos battery is situated in the motherboard..
    Jun 10, 2009 | Computers & Internet
    How about this Pavilion dv8000 Battery for HP Laptop Battery?
    You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
    http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
    http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
    Jun 02, 2009 | HP Computers & Internet
    Computers & Internet Logo
    21 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
