Question about Dishwashers
Dishlex global 300 seems to be shorting out mid way through a cycle and tripping the fuse at power box what could this be?
    President:
  • 1,952 Answers
Check the fuse in the console and also the door switches for continuity.
The door switches will stop power if they are not being depressed because the door isn't shutting perfectly or one of the switches has failed. I would be looking in the latch assembly, if you have a meter you can test the door switches
Posted on Nov 02, 2008
  • Dishwashers Master
  • 13,433 Answers
Possibly a problem with wiring possibly a shortcircuit, hows your warranty? I would have it looked at.
I have a Dishlex Global 300 DW. The Mains safety switch trips on Rinse cycle. Heating element has continuity and works on wash cycle. There are no leaks.
call an electrician to check the insulation for ground leakage and breaker capacity for current use
it will most likely be tripping from moisture across the active and neutral wires somewhere
Dec 05, 2016 | Dishwashers
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
My dishlex dishwasher tripped the fuse what could be wrong
reset the circuit and try again.but it sounds like you got a short.
Jan 03, 2015 | Washing Machines
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwasher power overload
Check heating element in DW and all parts associated with it located on the inside of DW under the spray arm. It could also be a problem with the control panel,Call technician.
Dec 09, 2007 | Dishwashers
Tank is leaking
Is it the tank or just the door seals? Ours was leaking recently, there was an obvious tear in the door seal. Once fixed no probs.
Nov 02, 2007 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
