Sharper Image SU502 World Clock Setting Location
I am able to push the East and West buttons to change the clock through various time zones, but am unable to make it stick on Los Angeles -- it always wants to revert to London.
Press the "MEMS" button
Posted on May 20, 2009
Can not change time zone on sharper image model lm521 projection clock
I got to liking the Sharper Image LM521 Digital Clock so much that I finally took the time to figure out how to manually set it-it was that or toss it! The instructions are as follows:
AFTER installing fresh batteries, or removing and reinstalling the batteries:
Successively pressing the "SET" button results in steps 1.) to 11.) below, each of which describes the particular/specific LM521 clock function you you can manually set.
HOWEVER, pressing the "SET" button after the clock had been previous set and running, will start the manual clock settings from step "2.)," "SET Offset Hours..." To start from step 1.), remove and reinstall the batteries.
After inserting the batteries:
The whole LCD screen lights up showing the different settings, etc.
After several seconds, the LCD screen clears and displays:
A flashing antenna
Upper left hand side of the LCD display. USA Time Zone Map
Middle right side of the LCD display (if necessary, to see, remove and reinsert batteries).
A flashing antenna
> This indicates the clock is trying to auto set the time according to the WWVB radio/satellite time signal. Set on windowsill for best chance of success.
If it can't detect the signal, mannual setting is required, starting with the time zone.
> Manually set time ONLY if you are absolutely certain the WWVB signal cannot be found. Otherwise any manual time setting will be auto set to the WWVB time when its signal is detected, which may be many hours later.
SET USA Time Zone
1.) Press "SET" -- US time zone
> press "MODE" repeatedly until the desired time zone is reached.
5 = Eastern standard time (default setting)
6 = Central standard time
7 = Mountain standard time
8 = Pacific standard time
9 = Alaskan standard time
SET Offset Hours to Compensate for Satellite Signal
2.) After step 1.) above, press "SET"
A flashing "-7h" (minus 7 hours, default) and flashing USA Time Zone map appear.
This default setting worked just fine in New Mexico, MST, and may also work for your time zone as well.
> Press "MODE" to set from "-0" to "-12h" (minus 0 to 12 hours).
> Set to "-0h" if the satellite time signal set your clock to the correct time for the US time zone you live in.
> Set from "-1h" to "-12" to offset the time set by the satellite signal in case it does not match the time in your time zone. (E.g., 3pm -1h = 2pm.)
> NOTE: The default setting is -7h. If the satellite signal resets the time, say to 9pm, the time displayed will be 2pm (9pm-7h)--but if it should display 5pm instead to match your time zone, then set offset to -4h. Hence, the need to correctly set the offset hours if the -7h default value does not work for you.
SET Daylight Savings Time (DST)
3.) Press "SET" -- DST (Daylight Savings Time)
> Press "MODE" to set ON/OFF
SET Time
4.) Press "SET" (5no = seconds)
"5no" displays, plus flashing bars for seconds (not minutes as it falsely seems).
> Press "MODE" to set from 0 to 60 seconds
5.) Press "SET" (set hours)
> hour bars flash > press "MODE" to set hours
6.) Press "SET" (set minutes)
> minute bars flash > press "MODE" to set minutes
SET Date
7.) Press "SET"
> press "MODE" set year
8.) Press "SET"
> press "MODE" set month
9.) Press "SET"
> press "MODE" set day
SET Week Day
10.) Press "SET"
> press "MODE" set week day, Mom through Sun (Mo is default)
SET Standard (12) / Military (24) Time
11.) Press "SET"
> Press "MODE" set 12/24
SET/ROTATE Ceiling Projected Time/Temp Position
12.) Repeatedly press button with four tiny arrows pointing opposite each other (rightside of "DSPL" button) until the Time/Temperature display on the ceiling is oriented how you want it.
SET Ceiling Projection Brightness, or turn off
13.) Pressing button with sun symbol (leftside of "DSPL" button) cycles ceiling display from off, to brightness levels 1, 2, and 3.
SELECT between Ceiling Projected Time, Temp or Both
14.) Pressing "DISPL" repeatedly cycles between M0 (time), M1 (temperature), M2 (time & temperature auto switch every second or so).
Jan 23, 2012 | Audio Players & Recorders
I have an OREGON SCIENTIFIC MODEL 323A travel alarm clock. I want to set it to East Coast time. It's presently on West Coast time and nothing I do to the front panel buttons will allow me to change the...
The following is from a manual I found online. Step 1. and 2. worked to solve the same problem you're having for my sister-in-law. Hope it works for you too--good luck! JLC
1. Press and hold [MODE] button for 2 seconds.
2. Using the [UP]/[DOWN] button to scroll through the 4 U.S.
time-zones (Pacific, Mountain, Central or Eastern) or non-U.S.
cities. Press [MODE] to confirm.
3. If non-U.S. city is selected, the world time city will be flashing.
Use [UP]/[DOWN] to select the city (for city names abbreviation,
please refer to the section “Selecting the World Time”). Press
[MODE] to confirm.
4. Repeat the same procedures to set the hours, minutes, year, month,
day, language of day-of-week and hourly-chime on/off by using
[UP]/[DOWN] button.
Jul 11, 2009 | Oregon Scientific RM323A Travel Alarm...
I need to change time zone on atomic clock to EST
I need help setting the time zone on the sharp atomic clock model #spc364.
Apr 18, 2009 | Bose Wave Radio
SHARPER IMAGE -- M1600 / M1601 Swivel world time clock .
Push the mode button until the top window says 'Alarm', push the up or down button to shut off the alarm, push the Set button to set it.
Mar 05, 2009 | Watches
Time zone setting on Medion atomic clock
Re: Median MD10954 time zone setting.
Press the MODE button but do not hold it in.
repeatedly pressing the MODE button will alternately display the DAY OF THE WEEK or the SECONDS next to the time.
With the DAY OF THE WEEK displayed, press and hold the UP button for up to 5 seconds. Each 5 second press of the UP button will move the time zone by one.
When finished, you may press the MODE once again to revert to SECONDS display.
Good luck,
ACTION from Cincinnati
Feb 22, 2009 | Medion md40298 Notebook
Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
Dec 12, 2008 | Sharper Image SI785 Clock Radio
Clock time always goes back one hour after setting it.
Check on the general set up/ clock, what zone is set and put east, mis or west deppending where are you located, turn on the automatic clock or select a news channel where the decices will check the update time.
Nov 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Sharper Image Weatherproof Atomic Clock Model OQ007
Press and hold the "Mode" button for a few seconds until the display flashes. The briefly press the Mode button to cycle through each setting. When you get to the "Zone" setting, press the up button to advance the time zone. Press the mode button repeatedly to finish cycling through the settings.
Nov 03, 2008 | Audio Players & Recorders
Skyscan Atomic Clock WWVB
figure out where yu are north south west east zones on your map from where yu are , then pull battery again it should stop at for eight or twelve push time zone then set in a window facing your zone it should automatically pick it up shortly in awhile
sw i think it may stop at four also but then wait
Oct 14, 2008 | SkyScan 86709 Atomic Wall Clock
Set the clock
The D3 is set automatically to West Coast (PST) Time. Only when you reset the D3 can you change the time. Hit the reset button and you'll start setting up the settings. It will bring you to the clock feature. Depending on where you are in the country you will need to hit the [+] button one click for each time zone east (i.e. East Coast (EST) is three clicks). Then you need to hit the "Summer Time" button becasue of Daylight Savings Time.
As for the Phone Book I don't use that feature so can't help you there
May 16, 2008 | Pioneer AVIC-D3 Car DVD Player
853 people viewed this question
