2000 Mercedes-Benz S-Class Logo
karn Posted on Mar 08, 2012
Replacing all relays under backseat of 2000 mercedes S500
Does the computer or anything else on a mercedes s500 have to be reset after the relays under the backseat are replaced?
Frank Hut
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Oct 30, 2014
Frank Hut
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
9231
Points
31
Open the hood locate the fuse box on the passengers side near fire wall back feed 12 volts into to large fuse that is loose all by its self conected by 2 wires .I think its a 40 amp . By back feeding 12 volts into the system you can pop the trunk lid with the door switch.
5 Related Answers
Anonymous
  • 203 Answers
  • Posted on Jun 05, 2009
SOURCE: On a 1995 S500 Mercedes , ASR light keeps coming on
yes they can but unlikely-more likely a bad over voltage relay(powers up idle speed computer) or wire harness-your vehicle is probably a hfm type fuel injection they changed from lh that year. find out if it is lh check the fuses in the base module located in the passenger side of the engine compartment under a cover held in by 4mm allen head bolts-alot of times these control units have intermittent contact with there connectors. asr stands for acceleration slip regulation-both isc and asr communicate via can system to monitor throttle position- ea isc cc-idle speed cruise control and electronic actuater(throttle)-hopefully i have helped
Anonymous
  • 15 Answers
  • Posted on May 01, 2009
SOURCE: 2002 mercedes s500 trunk will not open
Hi there
First of all may i say i feel your pain. literally. the same thing happened to mine. here is what i did
Firstly i needed into a locked boot urgently (for wifes wheelchair)
so i cut a rectangle out of the boot put my hand in and pulled the release mechanism, that worked but left me with a hole in my boot.
I suggest that you try this instead.
remove back seat
the central locking pump is located next to the battery (black box with yellow air lines going into it.)
Unplugg the filler cap cover air line, then unplugg the boot air line and put it into the filler cap cover socket.
now when you unlock the car the boot should automatically open.
If it does not the problem it on the boot air line and you should strip the trim out of the boot to check, but you still have to get in and may have to do what i did initially.
If changing the air line worked then you will soon get tired of having to shut the boot everytime i solved this problem by routing the filler cap air line to a pnuematic switch (LEGO) This switches between the boot and the filler cap. bit naff but it works and cheaper than having to replace pump and have computer and keys re-coded total cost around £600.
op that helps
Anonymous
  • 721 Answers
  • Posted on Jun 22, 2009
SOURCE: 2000 mercedes s500 ac problem
No,unfortunately it sounds like a bad body computer.Dealer only at the moment.
Anonymous
  • 203 Answers
  • Posted on Jun 28, 2009
SOURCE: trunk qill not open
Your trunk lock actuator is probably in valet mode. Take the mechanical key out of your smart key(should have a release button on the bottom of the key which will allow you to slide the hidden mechanical key out of the plastic housing) insert it into your trunk lock actuator and turn to change your function of trunk actuator. In the valet mode the trunk does not respond to your central locking or release button commands. Your owner's manual will tell you about these features. I hope I have been helpful
Anonymous
  • 408 Answers
  • Posted on Jul 25, 2009
SOURCE: I have a 2000 Mercedes S500 (W220) with a Bose
hello,good day,yes your may check the power supply and contact,if not corrected,send your car to a dealer for proper diagnose,maybe erase fault or configuration of your system is needed,to correct the problem,ty
My 2000 S500 mercedes will not start. the key turns but the engine will not crank. it has a new battery
Does it click or do anything? If not, then the plastic gears inside the ignition that control the vehicles ACC and ON positions along with the cranking may have slipped. Have someone to pull the ignition switch panel and check and make sure the "gears" are working properly.
Where is the winshield wiper relay on 1995 mercedes s500
its in the fuse box all mercs have a relay discription on top of the fuse box telling you what each fuse and relay is for well on my c180 it does hope this helps
2002 s500 mercedes benz cool fan relay location
2003 Mercedes E320 fuse box location is in the trunk and under the hood an inside driver side Dash
2helpful
Replace headlight assembly 2000 mercedes s500
does the front bumper need to come off in order to replace head light assembly on 2003 s500?
1helpful
2000 s500 will not start,but key turn
next time you try to start the car just put the key in and turn the ignition on dont try to start it to see if your security light comes on. if any kind of security light come on or flashes call a dealer to find out how to reset the system. if u have the wireless transponder for the security the battery may have gone dead
My 2000 s500 won't start in cold winter season. i
Malfunctioning fuel system.
Fuel injector[s] leaking...check fuel pressure,more then 53psi
check fuel injector resistance / ohms/
Ignition component damp or demaged.Checks wires broken,loose or disconnected in the starting circuit.Worn, faulty spark plugs.....
1helpful
Turn signal bulb 2000 Mercedes s500
If you have a owners manual then the method is described there.
1helpful
Remover of blower motor
It is located under the cowl. You have to be sure it's the blower motor. they are expensive. Check the plugs for good contact. They have a relay/fuse you should check that too before removing.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
