Question about Goldstar WG5000 Air Conditioner
Wall ac unit keeps freezing up inside.
Hello, I have a Goldstar GWHD5000 wall unit.I have allways kept my filter clean. Started today entire inside coils behind filter has a full sheet of ice. I let it thaw out ran on high fan afterwards setting #1 and still froze up after 30 min.2 years old only cost $90.00 new. Is it cheaper for a new one or can i fix for under $40.00. Thanks,Gary
  • Gary
    Gary Nov 06, 2008
    Thanks for your help.Figured after 2 years i got my $90 worth. I'm in south Fl ,not many cool days,trying to save a buck.
  • 828 Answers
No! You will not likely find any service on a product which has very little value. Frosting will sometimes happen if the outside temperature is to low. The outside ambient temperature is directly related to the pressures inside the refrigerating system. The lower the outside temperature is the lower the pressures will be in the cooling end of the air conditioner. In mechanical refrigeration pressures and temperatures are directly related.
Posted on Nov 03, 2008
  • James Helmer
    James Helmer Nov 06, 2008
    Frosting of the cooling coil can be caused by ether of two conditions. With a normal operating ambient temperature such as with you location there is a possibility you unit is a little low on refrigerant charge in the system or there is possibly a restriction in the refrigerant line feeding the cooling end of the system. However it would still come down to product value and cost of repairs.
Hi my air con started to leak from the front of the unit cant find where the tank is
So, what is the question? Also what kind of AC unit is it and how old?
Jan 09, 2017 | Heating & Cooling
How do i deal with the dripping of water from my Mitsubiishi split system from inside unit? Will putting the unit on 19 and then turning it full bore clear over condensing?
NO
the water is condensation from the humidity in the air turning to water on the cold evaporator core
normally it drips into a tray and drains away outside
if it is inside ( running down the walls it indicates
the drain hole and tube is blocked or the evaporator core is covered in gunk and holding the water up and not dripping where it is designed to
Call an accredited ac specialist shop to clean the fins and drain tube
Jan 06, 2017 | Heating & Cooling
Cooloing is not coming down from room temperature
The unit needs service. Call a technician! You can:
Check your air filters
Clean outdoor coil by turning off all power at breakers and tstat, clean o.d. coil with water hose
Inspect indoor coil (if you can) for build up or debris
Other than that? May be low on freon. A service tech will cost $ BUT not having the unit service will cost more due to electrical consumption and excessive run times shortening the life of the system.
Jun 24, 2015 | Heating & Cooling
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Williams wall heater setting off co2 alarm
Then it may well need a service or check the alarm
Jan 01, 2014 | Williams (5009622) Ceramic Gas Wall...
Water dropping on air conditioner
Water is dripping on your ac from a duct? Or is the unit it self leaking Are you sure you don't need a Professional Air Duct Inspection?
If you are in the market for an Air Duct cleaning check out Air Duct Cleaning Dallas Tx.
Jun 10, 2012 | Heating & Cooling
Goldstar WG5000 Air Conditioner Logo
650 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
