Question about Sony Ericsson Walkman W810i Cellular Phone
P168 keypad out or control
My p168 keypad is out of control, sometimes makes mistakes because the number that I press not corresponding with the number that I reed on the screen, and I have to do a pen calibration several times and after this it works right again but only for some call, after that I have to repeat the pen calibration. Sometimes I press the numer and looks like blocked, no numers appear on screen.
  • 94 Answers
Rafaelantoni hello,
I suggest you try resetting the phone through the settings menu.
IF that does not work, try turning it off, removing the battery and SIM card for a minute or two, and then putting everything back in.
If that doesn't work either, perhaps they keypad has moved slightly inside the phone cradle, thus making the phenomena you've described. In that case, I suggest taking it to a lab, where it will be opened, be placed back to its correct position - or they keypad itself might be faulty, thus replaced.
Posted on Nov 02, 2008
No number lock or schroll lock Keys
Your laptop computer may have a numeric keypad integrated into the
keyboard. The keypad corresponds to the keypad of an extended keyboard.
• To type a number or symbol, press and hold <Fn> and press the desired
key.
• To enable the numeric keypad, press <Num Lk>. The 9 light indicates
that the keypad is active.
• To disable the numeric keypad, press <Num Lk> again.
numeric keypadSource(s): http://support.dell.com/support/edocs/systems/xlob/dtg/en/en_dtg.pdf
Feb 25, 2012 | Dell Inspiron 1545 Notebook
How do I change the name and fax number on the top of my outgoing faxes
The software that came with the printer will have a "setup" or "settings" icon. You can change it there.
If you can't find it or never installed it you can delete the printer software and re-install it and you can start from scratch with the new information you want.
Jan 27, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How do I change the language on my new J4580 machine
Hello
Thank you for using FixYa for your problem.
Try this;
Changing the language on the HP All-in-One displayFollow these steps to change the language on the All-in-One display.
  1. Press the Setup button (c01361401.gif).
  2. Use the arrow buttons (c01185108.jpgc01185072.jpg) to select Basic Settings, and then press OK.
  3. Use the arrow buttons (c01185108.jpgc01185072.jpg) to select Set Language, and then press OK.
  4. Use the arrow buttons (c01185108.jpgc01185072.jpg) to scroll through the language options until the preferred language is displayed.
  5. Press the numbers on the numeric keypad that correspond to the appropriate language displayed on the control panel display.
    NOTE: Ifa selection is not made within five seconds, the display automaticallychanges to show the next language. If a selection is not made withintwo minutes the setup menu exits and the language/region remainsunchanged.
  6. Confirm the language choice.
    • Press the number corresponding to Yes to confirm the selected language.
    • Press the number corresponding to No to select a different language.
  7. Aftera language is selected, a screen is displayed for region selection.Press the numbers on the numeric keypad that correspond to theappropriate region.
    NOTE: Ifa selection is not made within five seconds, the display automaticallychanges to show the next region. If a selection is not made within twominutes the setup menu exits and the language/region remains unchanged.
  8. Confirm the region choice.
    • Press the number corresponding to Yes to confirm the selected region.
    • Press the number corresponding to No to select a different region.
Please Rate my solution or reply for another answer if still not going
Thanks
Richard Scott
Technical Support
Nov 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
My keyboard asks like a number pad. How do i
Hit the Num Lk key and that should allow your keyboard to act normal.
If you have the Num Lk on then that means the letter keys that correspond with the numbers on a keypad will act like a keypad.
Make sure the Num Lk symbol is turned off by pressing the Num Lk key.
Aug 09, 2009 | IBM ThinkPad G41 Notebook
Speed dial
go to your phone book select the person...now go to options and add to speed dial (slots 2 thru 9)...
to speed dial..go to phone and press the number on keypad then press phone...you can also speed dial 11 thru 250...by pressing the number then #....come just for the fun of it...go to phone and the keypad (act like we making a call) now press 19# (who came up)...try 15# and so on (this also depends on how many is in you contact....if you only have a fave 5...19 & 15# will not work,,,
feel free to rate the help
Jun 16, 2009 | Dual Electronics CECT P168 Cellular Phone
Resetting the name of company and telephone number on fax sheet
Welcome to FixYa! I'm the expert that chose your issue to resolve. Now let's get started. Office machines, for whatever reason, seem to be a lot more complicated than the ones you use at home. But, this should be an easy problem to fix. The process of putting in your required and company information is known as "registration" To complete your registration do the following:
  1. Press Function, then
  2. Data Registration, then
  3. Press set three (3) times. Your current settings will be displayed.
  4. Use the numeric keypad to enter the correct month, day, year and time in the following order: Year (enter only the last two digits), Time (use 24 hour time format i.e. 13:00 vs. 1:00, precede single digits with a zero (0) i.e 01:00) If you make a mistake press clear. Also, you can use the left/right arrows to move the cursor under just one digit and use the number keypad to change it.
  5. Press set two times. The display will show UNIT TELEPHONE, the TEL=
  6. Use the number keypad to enter your fax/telephone number (max 20 digits including spaces) If you want to enter spaces, press function, then space. If you make a mistake, press clear and reenter the number. You can also use the right arrow key to delete the rightmost digit and re-enter the number.
  7. Press Set twice. Unit will display UNIT NAME on 1st Press, then on the 2nd press a blank screen (not totally blank, it will have a cursor on the left and a A: on the right.
  8. Use the numeric pad (corresponding to letters printed on keys) to enter the company name (max 24 characters including spaces).
  9. Press Set (Unit will display TX TERMINAL ID)
  10. Press Stop/Reset to return to the standby mode.
Note: if you want to check that what you put in is what you want, you can print user data list. Here's how:
  1. Press function, then:
  2. Press report (unit will display ACTIVITY REPORT)
  3. Use up/down arrows to select USER DATA LIST.
  4. Press Set once, the list will be printed.
(information above from Canon)
That's about it....I imagine that in a busy office, it's hard to find time to read through a book just to do this stuff, but I have the time.
Thanks for using FixYa.com!
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further. I am at your service.
Jan 20, 2009 | Canon FAXPHONE L80 Laser
Difficulty texting with the CECT P168 mini cell phone
The keypad is fixed. You can try to recalibrate the screen to make it more accurate. Go settings->pen calibrate
Nov 29, 2008 | Dual Electronics CECT P168 Cellular Phone
Keypad I9 cect
When making a call there are three items above the pictures on the bottom of the screen, one is to choose options, the other is H-Free on the right. You want to hit the middle one which is a green telephone button which will bring you to the keypad to punch in ext and voivemail info
Nov 11, 2008 | Dual Electronics CECT P168 Cellular Phone
KEYPAD ON MY CECT P168
To view the keypad while talking on your CECT P168, at the bottom of the screen there will be an icon in the middle, you'll need to touch the icon and the keypad will be displayed.
Sep 02, 2008 | Dual Electronics CECT P168 Cellular Phone
Need to change name and number
Press the MENU button and press 7, then 2 on the numbers keypad. You can then use the keypad to change the fax header. Press the keypad numbers corresponding to the letters you need. It will cycle through lower case first, then upper case. Press the RIGHT arrow button to advance one space between letters.
Jul 18, 2008 | HP 920 Plain Paper Fax
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
