Question about Kenwood Radio TK 260 360 270 370 2100 3100 Compatible Battery
I need a owner's manal for my tk-260.
When i put the battery on the charger it dont light up.
    Brigadier General:
  • 6,966 Answers
It wold seem that you have two (2) concerns:
  • user's manual;
  • battery charging - pls check output voltage of adapter/charger; pls check battery terminals.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 02, 2008
I canot get the tranceiver top transmit. When you push the traansmit button it justs beeps once. Signed Randy
This can sometimes be the sign of a low or bad battery. Try swapping your battery with a known good unit and see if the problem persists. If you do find swapping batteries solves the problem, then you will need to troubleshoot if it is the battery or the charger which needs attention. Clean your contacts on the battery and charger with a pencil eraser to ensure good contact, and always have the radio turned off when charging. Batteries typically last approx. 18-24 months before needing replaced.
Sep 07, 2015 | Kenwood KNB-15AM,...
Can't transmit signal. Only get a 2 second beep when I push the transmit button
You have a poorly charged or bad battery. It takes more power to transmit than to receive. Usually the first thing you lose with a low, bad or poorly charged battery is transmit.
Try a known good battery in the radio. This should solve the problem. If not, check your battery contacts, as you may have one which is bad or not making good contact.
Clean your contacts with a pencil eraser to assure good connection with the charger.
Best regards.
Mar 18, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
Kenwood KSC-37 why does red light blink
In the manual, it states that if the LED is Blinking Red "The battery pack is defective or the battery pack contacts
are not properly mated with those of the charger" Below is a link to the manual.
http://www.buytwowayradios.com/products/resources/Kenwood/KSC-37-Owners-Manual-1.pdf
Apr 04, 2013 | Kenwood KSC-37 Replacement Charger for...
I have a TK-280 and when i put it on the charger the red charging light comes on the starts flashing red after about a min. I am on the fire dept. where i live and kinda need it charged up. I wanted to...
  • Couple things this could be.
  1. First thing is to make sure the radio is seated properly in the charger and that all the contacts are making contact and not dirty.
  2. The other thing this could be is that the battery is bad. Or in the least the capacity for the battery is extremely bad and not reliable.
  3. If the contacts look good and it's sitting on the charger proper than you will need to get another battery pack. Sorry.
  • Hope this helps and thank you for using FixYa.
Regards, Tonyu
Jul 14, 2011 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
I have an older kenwood tk 270 radio. im having trouble puting it in programming mode. iv followed the instuctions to hold the light and dial buttons while turninging radio on but nothing happens got any...
These radios can be programmed via the keypad. However, this option must be enabled through the software, and must have a component removed from the circuit board. If you have a radio that will not go into self-programming mode when you use the proper key combination (light button+dial button while turning the radio on), your radio has not been enabled for this option.
programming instructions:
http://www.repeater-builder.com/kenwood/field-programming-tk-x70.html
Feb 15, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
Disconnected battery in my 1998 Plymouth Voyager and now my radio is locked, need code to unlock radio.
It will be with your owners documentation. If you don't have that, then you can check your local dealer and they should be able to get it by your VIN.
Sep 12, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
I need to program Kenwood TK - 3100. I do not
I may be able to help. Where are u at? You can contact me at zkudlacek@hotmail.com with your info.
S.
Apr 20, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
I need programming software for a Kenwood TK360. I have cable. Where do I find?
I still might have the CD with software for the TK-360 don't know how to use it but I have CD
jnpj@comcast .net
respond with TK-360 in subject line so I don't think email is spam
Feb 26, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
Flashing light
the problem may be the batteries. When the batteries get old and won't charge or if a battery needs recharging the kenwood radios TX/RX LED will flash untill the problem is resolved.
Oct 20, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
Kenwood Radio TK 260 360 270 370 2100 3100 Compatible Battery Logo
101 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
