Question about Sharp DVHR300U 109-Hours Video Recorder
I got a big problem with my tv..
The technician declared that flyback transformer is defective because when the tv is turned on, the picture is not clear(it is something like the picture is distorted with a chirping sound). i can hear the voices of the characters in the tv but it's distorted.. as i opened the tv, i heared the flyback sounds(something like theres air coming out).. but wen i went to test it with a flyback tester,it's good.. what can you suggest? please help me.. thanks.. armel
    Sergeant:
  • 337 Answers
Did the technician said what was wrong with the transformer?(leaky)?,It might sound like air but is High voltage leaking from the top ,be very careful when proving around there and just get it change because is not repairable and dont use it or it will damage other components.
Posted on Sep 25, 2006
SOURCE:
Standby mode 7 red brinks Check with sears ,estimate $218.00 board replacement, Tech charge $105.00 to tell me whats wrong, labor extra. Chucks repair estiment $400.00 . I have repaired TVs years ago....
turn (only by 2 degrees ) all the knobs on flyback transformer in clockwise direction & then switch on tv .............you will get picture atleast for 1 or 2 mins ............ this confirms only flyback transformer is defective ........ so it has to be replaced by new one .................otherwise transistor (big in size fixed near flyback with its back clamped or screewed to aluminium metal ) has to be checked ......if that is also fine then complete main board has to be checked ...... but flyback replacement is a must ........in your case iam 100 % sure only flyback is deffective ...........vishnuswamy_22.jpg
Aug 24, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I have a Panasonic CT-36hL43G TV that just turned offf while watching it and now the led by the power button blinks one time. Can anyone tell me what this code means or what the problem might be?
i hope your tv is more than 4years old ....... in all CRT TV's or CRT monitors after 4years a component called flyback transformer (see picture ) becomes weak - its work is to supply voltage to tube............. then following are the signs ...
(1) in some TV's only front LED's blinks - no picture no sound.... (2) in some TV's picture comes slowly after few seconds or after few mins or after few hours......... (3) in some TV's suddenly picture & sound goes temporarly & after some time again it appears ...... etc in case of (2) & (3) only flyback transformer needs to be replaced .....100% GUARANTEE again TV works normallyBUT in case of (1)... --------------- YOUR CASE (a) either only flyback transformer gets deffective or (b) flyback transformer & another component called transister ( will be near flyback transformer & its back portion is attached to aluminium metal ) gets defective or (c) along with flyback & transistor -- 3 or 4 more components (resistors, diodes, some times ICs ) gets deffective so replacing flyback transistor is a must .. & to find whether any other component is deffective or not completemainboard has to be checked ....... so if you are a technical person & having expierence in servicing line then you can do it yourself otherwise approach good tv service engineer ........... your TV is really very good one ... so don't think of buying new TV .... just goahead for repairing it it is worth & it works for atleast 2 more yrs....... try this & tell me what happened switch off your TV ... remove power cord from socket ,,,,.ware some mat or chapples to your feet ..... remove your TV's back side cover ......... observe carefully for any physically damaged components .... if you find then don't do anything ... close tv cover & approach tv service engineer ............. but if no physically damaged components are visible then take a suitable screew driver & rotate 2 (or 3) Knobs on flyback transformer in clockwise or anticlockwise direction - very little ( 4 or 5 degrees ) - you have to do this without touching any cable or any part of your tv .......... then fix..... back side TV cover ........connect power cord - stay at a distance & switch on your tv ......... if you get picture atleast for few seconds then in your case only flyback transformer needs to be replaced otherwise complete mainboard has to be checked. to find other deffective component ............. so your tv problem is a harware problem - it cannot be solved using remote control or any buttons on your tv ..... if you are finding difficult to get it repaired then you can remove your tv mainboard with the help of some technician & send to me ...... i will replace deffective components .... & send back to you ....you only have to bare the shipping charges .....it will take maximum 12days (5days - to recieve + 2 days servicing + 5 days to send back to you )....
Aug 16, 2011 | Panasonic CT-36HL43 36" TV
I have a 1993 36 inch RCA, model # P46151WK. TV was on and suddenly heard something pop and it started to smell like something burned inside. It wont turn on anymore.
You may have a fried horizontal output transistor and a defective flyback transformer. If indeed this set is 17 years old.......cheaper to replace him...sorry!
Mar 01, 2010 | RCA F32650 32" TV
Flyback transformer
A flyback transformer is one of the more expensive components in a projection TV. If there is no clear reason, such as a known power surge, you could well replace the flyback transformer again soon because the root problem was elsewhere.
An OEM transformer is not necessary but you might have trouble convincing an authorized factory service technician to use anything but the original manufacturer's parts.
As with many of today's electronic devices, if it is more than a year or two old, you will find the new products cheaper and with more features. The next generation of projection TVs will use lasers and scanning will be done with optically controlled micro-mirrors - no flyback transformer required.
Oct 07, 2009 | Toshiba Televison & Video
Rca tv won't power on
it may need a Flyback Transformer or a burnt capasitor and resistors. there are many posts with this same problem. Some a little different. Check the fuse just inside where the power supply cord goes in . if the fuse is blown you will have to find the reason it burned . But maybe you will be lucky and replace the fuse. And it will turn on. but I think that only a TV technician can fix the problem.I have a background on TV repair and I think it's the Flyback transformer. sometimes you canresolder them and they stay.
Nov 23, 2008 | RCA P52926 52" Rear Projection Television
Could I possibly have a bad flyback transformer
I would try resoldering the flyback connections on the Circuit board. if the flyback was defective it would operate and you usually get 3 blinks on the LED indicator. Sounds more like a solder issue.
Jun 15, 2008 | RCA R52WM24 52" HDTV Projection Television
FLYBACK Transformer for APex 32'' Model #PF3230 Flat Part #BSC 70Y
Its not worth the repair if you still want to go ahead i need to know two things:
Are you going to have a qualified electronics technician fit it?
If you are planning to fit it yourself are you a qualified electronics technician?
If you answered no to both of these questions i cannot tell you where to get one or how to fit it due to the massive amounts of danger involved.
Feb 25, 2008 | Apex Digital PF3230 32" TV
Tv will turn on
leadfoot,
i believe the problem is the flyback transformer. try cleaning by using a small aerosal can. this will either correct the problem or you might have to replace it.
flyback transformer stores energy so i would suggest hiring a professional technician.
Nov 20, 2007 | RCA D52W19 52" Rear Projection Television
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
Pincushion problem
My thoughts would be, was it a Sony OEM transformer or a generic type? If the latter, that is probably a likely suspect. Another thing would be misplaced wires or switches that could have been accidently moved while replacing the transformer. I have had some of these sets that had no high voltage, and all it turned out to be was a broken solder connection on one of the pins going to the flyback transformer. Usually, if the flyback is bad, the Horizontal output transistor would be also defective. It's also possible that in the process of removing the old flyback (fun job wasn't it?) you may have cracked one or more of the circuit traces in that area of the PC board.
Jan 01, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sharp DVHR300U 109-Hours Video Recorder Logo
259 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
