Disconnect the mouse from the computer and turn it upside down. The screws to disassemble the mouse are under the pads on the bottom of the mouse. When you disassemble the mouse, you will find that the scroll wheel axle is gummed up, and the interruptor wheel is probably dirty. Use an old tooth brush and alcohol to clean the scroll wheel components, and let the components dry. You can use glue to re-attach the pads after you have reassembled the mouse.
Hello there: If you remove the battery cover you will see 2 small phillips head screws remove them and this will allow the part that goes around the wheel to be removed now make sure that there is no lint or dust build up around the wheel assembly canned air works great for cleaning these out then reassemble the cover and test Now if it still doesent work than you can assume that the controle sensor for the wheel is bad in this case if you still have the warranty i would take the mouse back and exchange it for a new one To have this repaired would cost more than what the mouse is worth ok I hope this is very helpful for you Best regards Michael
Because you don't list what model Logitech cordless mouse you have, look in this list to see if yours is on it. If it is, click on the link and download and install the driver. This
download has the latest drivers and SetPoint software for Logitech
cordless, wireless and Bluetooth pointing devices (mouse). http://www.softwarepatch.com/utilities/logisetpoint-dl.html Specifically
the mouse driver is for the following models:
Anywhere Mouse MX
Cordless Mini Optical Mouse
Cordless Optical Mouse
Cordless Optical TrackMan
Cordless TrackMan Optical
Cordless TrackMan Wheel
G1 Optical Mouse
G3 Laser Mouse
G5 Laser Mouse
G500 Gaming Mouse
G7 Laser Cordless Mouse
G9 Laser Mouse
G9x Laser Mouse
LS1
LX3
LX3 Plus Laser
LX5
LX6
LX7
LX8
M110
M205
M305
M500
M505
M555b
M705
MX 610
MX 610 Left-Hand
MX 620
MX Revolution
MX1100
Optical Mouse
Performance Mouse MX
Racer Mouse
Spot Mouse
Tiger Mouse
Trackman Marble
TrackMan Wheel
Trackman Wheel
V100
V150
V200
V220
V320
V400
V450
V470
V500
V550
VX Nano
VX Revolution
Zebra Mouse
I hope this helps and good luck! Please remember to vote and leave a testimonial.
in fact this one is one of my Favorite Combo set, change with the the fresh bettery, link the mouse again, clean the mouse wheel with the cleaner I think it'll work.
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
You should make sure that you have the LX7 Setpoint software installed to set the features you want. For the scroll button or button three if pressed, I have mine set to zoom (first selection). The scroll function of the wheel should be automatic. Go the mouse movement settings and set the scroll size to 6 lines. That should allow you to scroll your pages adequately. If this helps send a reply for others to view.
its usually for most wireless equipment, press and hold the reciever button for a few seconds then press the button underneath the mouse, for it to kick in, but have windows loaded to desktop when you try it..
All the best
John
