Question about ASUS K8V-MX Motherboard
Plugging in the front cover plugs
Speaker plug, reset plug, hd led plug
  • yoshiya2 Nov 07, 2008
    My Mother board number M810D V 7.5
    Problem Solver:
  • 18 Answers
Download the manual from www.asus.com
Posted on Nov 05, 2008
HOW TO HOOK IT UP WIREING THE LITTLE PLUG UP FRONT HD LED PW RESET ETC
Here is a few pictures that shows you how to connect your cables:
I am not sure which one it is, but these are the most common ones.
Hope this was helpfull.
Mar 17, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I touched my speaker and felt a static electric shock, the unit powered down, although it powers up, I hear the cooling fan but no sound or front power LED now. what happened and how do I fix it?
Did you have this speaker AND the device that drives it connected to the same power source? If run by a mixer you MUST run a power extension from the same place your powered speakers are powered to the mixer. Ground bounce due to wiring in a building can destroy input circuits due to ground faults and static discharges. ALWAYS use balanced lines either XLR or TRS cables to interconnect the audio.
Also verify your power receptacle is properly wired. Carry one of those plugs with the indicators showing receptacle is wired correctly. Don't plug anything in until you verify it. Some venues are noted as having bad electical service.
Let your speaker sit for a minute and repower it... sometimes they have a lockout that takes time to reset.
Mar 03, 2011 | Mackie HD1531 3-Way 15" HD Powered PA...
Setup wiring led,hd
you can find it here...
this a manual...
the sequence of the wires are power button,reset butoon, power led hdd led..
it is located on the lower right potrion of your motherboard...
try to short ifrst the pins to make sure where is the power button..if you already found it just follow the sequence i said...
Feb 10, 2010 | Intel D850MV Motherboard
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Wiring info
Most Mobo's have printing next to the places that are jumpered or pluged into. The ones you need sould be close to the edge of the mobo, that is close to the front {power button} side.
May 30, 2008 | E-Machines (308714) Motherboard
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
Motherboard pin config
All motherboards have a print beside the pins, Speaker= "speak", "pwr s" =powerswitch, "HDDled" red light on front, rst = reset switch [not allways used] "pwr led" Green led, the case wires are usualy marked on the plug ends with the same , "hdd" "reset" and so on. The power switch will work both way's around however the led lights wont. You will not hurt anything if they are the wrong way around, they just wont work so if you dont get lights just reverse the polarity. If by chance the case wires do not have labels the just trace them to the case front panel and plug them into the corresponding board pins. Regards mistyman
Aug 28, 2007 | Systemax Ascent PC Desktop
IBM NetVisat 02R4084 Mainboard
With the power on cross the pins with a slide on connector. When it fires on you know which one is the sw. When you cross the reset it will restart. When you try the HD the light will come on during HD activity. And the power light will work when you have the power light plugged. It isn't to hard. Just be careful.
Sep 27, 2006 | IBM (02R4084) Motherboard
ASUS K8V-MX Motherboard Logo
80 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
