Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Ice maker drips water
Amana ice maker IC-6 drips water
  • 59 Answers
In most of theses cases the dripping is caused by the molding in the ice maker cracking and the water is wicked out. On some ice makers you can replace the complete molding but its usually easier to just replace the ice maker.
Posted on Nov 02, 2008
Amana drs2663bw ice maker drips water into the back of the ice bin forming an ice build up
Make sure your refrigerator is level. also check that the ice maker inside the refrigerator is level after leveling the fridge.
Jul 20, 2012 | Amana ARS9266BS Side by Side Refrigerator
Ice Maker drips water at head end
There is a small set screw that you can adjust to control the inlet valve. Take off the front cover and look for the adjusting screw on the side panel. It usually has arrows indicating it if for adjusting. There is a picture here:
Have a look at this : http://www.davesrepair.com/DIYhelp/DIYicemakertips.htm
Jun 02, 2010 | Amana Refrigerators
Water is dripping into ice recepticle and causing ice to freeze together. seems to be dripping near the front. the model number on my amana is DRS 246 2B or(RB) orDRS266312 those are the numbers on the...
sounds like u have a bad ice maker or a bad water solenoid in the back of fridge just not shutting off all the way and letting water continiously drip into ice trap
Feb 24, 2010 | Amana ASD2622HR Side by Side Refrigerator
Ice maker overflowing
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | Amana SXD524VW Side by Side Refrigerator
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana ARS2665AW side by side ice maker not filling
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Amana ARB224RCW ice maker
Aug 16, 2009 | Amana ARB224RCW Bottom Freezer...
Freezer Ice Maker Won't stop filling with water
The water solenoid at the back where the water line attaches to the fridge has failed
Jun 29, 2009 | Refrigerators
Amana fridge ice maker not working
need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
Jun 21, 2009 | Amana Refrigerators
Ice Maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
ghhjd
Jan 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
447 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
