Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Can't connect to default network.
I have a D-link DI-624 that has been running for a few years. Recently, the desktop commputer will no longer connect to the default connection. It can see the default in the view wireless networks window, but when I try to connect, it states not connected. I have two laptops in the house and they are able to connect with no problem. I have already tried a re-installation of the GL-G250 Desktop adapter drivers. The D-link Icon in the toolbar is green, so I am assuming the card and ant. are working. An attempt at the repair newtork right-click option does nothing, but this is probably because I am not connected to begin with. What should I do?
I cannot connect to my local mail server ; but i have internet service with the same server. All of my setting are properly set according to the server , who says my router needs to be rechanneled to c.2 or c10????
Posted on Nov 10, 2008
    Genius:
  • 1,269 Answers
Try to power cycle your router. Unplug the power for 30 seconds then plug it back in. If that doesn't work, try to change the channel of the router. That should do it. If it still not working, there's a problem with wireless adapter's driver. You need to use update one.
Posted on Nov 02, 2008
Seting router d-link airplus g+ tm 624
You can set up for that dlink router.Do this step.
Click start>open internet explorer and the address URL type http://192.168.0.1 press enter.
Username admin
password leave blank
For setting details click this link to download user manual guide http://www.dlink.com/products/?tab=3&pid=DI-624&rev=DI-624
Hope can help you.
Thanks using fixya.
Jul 11, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
We reset the d-link di-624 wireless router and now it will not let us sign back on without the username and password which we do not remember. how do i factory reset the router?
Hi, when you reset your router the password is reset to default, and that default is admin admin. And to reset it, at the rear is a small hole in the hole is a button, remove from the power, and depress the button for a few seconds, then connect the power and try to logon again with your browser using the default settings.
It is also all explained in your user manual link below...
http://www.retrevo.com/support/D-link-DI-624-Wireless-Routers-manual/id/420ci368/t/2/
Aug 18, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Network is "Hidden"
Try a router reboot.
1. Unplug the Router
2. Shut down and restart the laptops, unplug the XBOX for 20 secondes even though its working.
3. Replug the router.
If this doesnt work you can try resetting the router to the factory settings.
Follow the link below for step by step resetting procedure.
http://www.geckoandfly.com/5890/reset-d-link-router-factory-settings-and-default-password/
Jun 13, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
hold the reset button for 10 seconds then let it sit till the lights stop flashing. then you'll be able to log into the router w/ the default user/password which I believe is admin/password. the ip should be reset to 192.168.1.1 so type http://192.168.1.1 in your browser to log in.
Jun 12, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Re-installing DI-624
Access the configuration page of your router by default its 192.168.0.1, Login to the Dlink page by default the Username is Admin and Password is Blank and then reconfigure your router for Internet connection.
Dec 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
I need to configure my d-link for wow downloader
To configure D-Link DI-624 Wi-Fi access point to work with BitTorrent you have several options. One of them is to use trigger ports.
Steps to follow:
  1. Open web control panel of D-Link DI-624 by connecting to http://192.168.0.1 (this is default direction, which can be changed by administrator).
  2. Enter login and password for administrator. Default login for administrator is admin.
  3. Go to Advanced, select Applications.
  4. In Applications screen:
    1. Check Enabled.
    2. Fill BitTorrent in Name.
    3. In Trigger Port put 6881 and 6999.
    4. In Trigger Type select TCP.
    5. In Public Port put 6881-6999.
    6. In Public Type select TCP.
    7. Press Apply.
  5. The DI-624 will reboot.
Now you can use BitTorrent from any computer on both LAN and WLAN local networks in automatic way.
BitTornado Setup If you use latest experimental BitTornado client you can give a good use toUniversal Plug and Play (UPnP). You just need to enable UPnP on D-Link DI-624 and BitTornado will work on any computer in your local network without any requiered intervention from your part.
In BitTornado:
  1. Run BitTornado
  2. Click on Prefs
  3. Locate UPnP Port Forwarding and select type1 (fast)
In DI-624:
  1. Log in as administrator
  2. Open Tools (main menu)
  3. Select Misc. on the left
  4. Locate UPNP Settings and select Enabled
Jun 30, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Internet Connection
try a cross cable between di-624 and westell dsl router.
Jan 12, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-link DI-624 wireless router connectivity problems (DNS suffix)
Might I suggest that you reset the router to its default configuration by pressing and holding the reset button until it reboots. This way you will be dealing with the default configuration. Then try to use it. Remember the default login ID is admin and the password is Password or admin. Lets hope this helps
Sep 04, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
167 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
