Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
KV27TS29 27" Sony Trinitron 1993
While watching tv we heard a loud zap, then it shutdown. unplugged tv and noticed the plug prongs were burt. No lightning or power surge as other equipment was on and remained working. Curious of the cost to fix, as I have a friend with 1994 model with same issue. I have had lots of luck with minor solder repairs in the past with receivers so I have opened up and found power throughout the power supply, and have not seen any leaking capacitors or noticeable damage to the board. It is an older tv, but everthing new I look at is more than I can spend.
  • Anonymous Mar 21, 2008
    Ckeck fuse okey ,no sounds,picture,no power
Sparks light to extinguish
Posted on Oct 25, 2010
    Novelist:
    Champion:
  • 275 Answers
If you state that the contacts of the Mains Plug were 'burnt', I suggest that you once clean them with Emery Paper and try again. Loose contact in the Mains causes the 'burning', and the Plug contacts become carbonised. Could be other reasons also, but just try this first.
Posted on Sep 23, 2006
I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Feb 23, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Screen blank
Sounds like a cap or fuse has blown in the set, you will need to take the back cover of and have a look, check on the power board for any blown caps, you will notice them straight away if one has poped, also check any fuses that may have blown they will also need to be replaced.
Feb 18, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Power supply
Check your board on power supply if you can find broken tracks.I might cause the problem
Aug 06, 2017 | Sony FD Trinitron WEGA KV-30HS420 30" TV
KV-32XBR37
Could be a failing power supply
Oct 16, 2017 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Cannot see TV through digital box on my sony trinitron
If there is no audio as well then this suggest that the digital box is at fault. The fact that you can watch DVD's proves this fact. Unplug the digital box for 2 minutes and then re-try. Good luck.
Jan 07, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
SONY TRINITRON TV 36"
I think you had an arc in the high voltage circuit which zapped the blue drive circuit to the picture tube. This could have been caused by the high temperatures the your set was subjected to. Stargazer
Aug 08, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
667 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
