Question about Philips GoGear SA178 MP3 Player
MY GoGear button got short circuit so cant use ...
Hi, Thanks in advance. I accidently droped my Gogear in water tub while that was still playing a song. Since it came in contact with water, to avoid further damage I stopped it by pressing the button. due to water presence I think button got short circuit and when next time it boot up it navigates through it's menu continueously. If you press a button that will become still at one menu but will not execute that. then light fades out, but that does not make the gogear to stop. Battery discharges. To stop I identified the fact to connect it to the computer then that makes menu off and acts as pen drive. I am nervous now as I lost a good device. I don't have any repair store around and also not confident that the store will give me a good repairing solution. I can open that but not confident, that I will not damage this again. If any one puts a photographic idea about opening and replacing the components (As this is explained for ipod repair) then I think, I will be able to repair the button, if that is not possible then I will have to use this as pen drive. If possible please post your suggestion to my mail id achilles.hector09@gmail.com .
  • 8,596 Answers
The component parts for repair are not available for order. Call Philips and find out how to get an in-warranty replacement (or take it back to the store).
-Tha Mp3 Doctor
Posted on Jan 03, 2009
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
I listen to the music for 1 hour. I turn the lock switch off. The next day the Go gear MP3 has completely discharged. I re charge it on the pc. The screen reads 'Fully charged'. The same thing...
There are two things possible.
1) You have defective re chargeable batteries in your GoGear.
2) There is some short circuit because of which the re chargeable cells are discharging.
Either way you should get the system changed. If you want to confirm if its the battery defect or GoGear. Charge the system fully and play music continuously. If the Go Gear plays for about 4 hours with out break---- its not the battery but the charging system.
Mar 14, 2011 | Philips GoGear SA3020/37 MP3 Player
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
How To Add Videos to my gogear mp3 player
Go to www.usasupport.philips.com - download the latest version of the Philips (Arcsoft) Media Converter
Jan 14, 2009 | Philips GOGEAR SA6045 MP3 Player
MY PHILIPS MP3 PLAYER ISN'T WORKING PROPERLY
If player is off and disconnected from PC,
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
You will now be able to load the firmware upgrade by clicking on the update tab in Philips Device Manager. The firmware upgrade should resolve the issue permanently.
Mar 23, 2008 | Philips SA5125/37 MP3 Player
Wont stay turned on.
1) Make sure the usb charger is in the lock position before trying to charge.
2) Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
3) after repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
-Tha Mp3 Doctor
Feb 07, 2008 | Philips GoGear SA178 MP3 Player
Philips mp3 play isnt working
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Dec 09, 2007 | Philips GoGear SA178 MP3 Player
I synched my songs to my player, yet they won't play
-Tha Mp3 Doctor
Oct 18, 2007 | Philips PSA610 MP3 Player
Unplugged from computer by dog
First restart by pressing the volume + and play/pause button at same time.
If that fails, then:
-Tha Mp3 Doctor
Sep 27, 2007 | Philips HDD082 MP3 Player
The coby speaker accident
-Tha Mp3 Doctor
Feb 19, 2007 | Philips HDD1630 MP3 Player
Philips GoGear SA178 MP3 Player Logo
75 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
