2001 Ford Focus Logo
Michael Blair Posted on Mar 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tail lights only one side works - 2001 Ford Focus
Anonymous
Level 2:
Sergeant:
  • Expert 185 Answers
  • Posted on Mar 08, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
185
Questions
Helped
48139
Points
542
Hi it may be a blown fuse, Im unsure where the fuse box is on a Ford focus (under the hood, underneath the steering wheel or down the side of dashboard at passenger side)
It will tell you which fuse is for what on the under side of the fuse cover or in your instruction manul.
Simply change the fuse with the exact same amp.
Once fuse is cahnged, check lights.
If taillight still isnt working it may be the light connector itself behind the light cluster.
Hope this helps
1helpful
2answers
2007 Uplander. The tail lights on the driver side will not come on, but they are working on the passenger side and the front. The brake light and turn signal work on the problem side and all the other...
GM doesn't have the best tail light setup. do you own a test light? You should start at the back. The turn signals and hazards use one bulb. The brake light uses another bulb. Remove the bulb and carefully test for ground and power. If it is there then it is either the bulb or related contacts. If power or ground is not there then unplug the tail light assemble and test for power or ground again. The tail light circuit board is notorious for going bad. Please start here and write back if you need further help.
Turn signal not working
TAIL LIGHT NOT WORKING
It can be faulty tail light bulb or its issue with tail light control switch or its wiring's are short.
Check the voltage at fuse slot of tail light.Do you receive 12 volt there.If not,then it says tail light switch is not receiving power supply.
There are few help links related to your problem.I suggest you refer the list and check the help links.Click the link below:-----
Turn Signal Not working
http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
Right turn signal not working on Pontiac Car?
http://schematicsdiagram.blogspot.com/2011/12/right-turn-signal-not-working-on.html
Only one side indicator light working on car?
http://schematicsdiagram.blogspot.com/2011/12/only-one-side-indicator-light-working.html
Turn signals not working on 1987 Jeep Wagoneer?
http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
SOLVE YOUR 4 WAY FLASHER RELATED PROBLEMS HERE
http://repairhelpcenter.blogspot.com/2012/11/4-way-flasherturn-signal-flashersignal.html
1994 Toyota Camry: Bypass Tail light Relay Circuit?
http://whatisbyme.blogspot.in/2012/04/1994-toyota-camry-bypass-tail-light.html
2008 Toyota RAV4: Replace Tail light Lens Cover?
http://technoanswers.blogspot.in/2012/04/2008-toyota-rav4-replace-tail-light.html
2003 Chevrolet S10 Tail light Fuse
http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
Chevrolet Parking light and Tail lamp light Wiring diagram
http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
Car Tail Lights Not Working?
http://schematicsdiagram.blogspot.com/2011/12/car-tail-lights-not-working.html
These details will help.
Thanks.
Tail light and the tag light will not work
Sounds like a problem in the wiring harness.
2helpful
The tail lights do not work. The headlights, blinkers, and brake lights work. I checked the fuses and they are all good.
1994 Toyota Camry: Bypass Tail light Relay Circuit? http://whatisbyme.blogspot.in/2012/04/1994-toyota-camry-bypass-tail-light.html
2003 Chevrolet S10 Tail light Fuse http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
--------- Chevrolet Parking light and Tail lamp light Wiring diagram http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
---------- Car Tail Lights Not Working?
Turn Signal Not working http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
---------- Right turn signal not working on Pontiac Car?
Turn signals not working on 1987 Jeep Wagoneer? http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
Thesedetails will help.
Thanks.
3answers
Dash and interior lights do not work
Dash lights are on the same fuse as the tail lights. Dash lights not working is an indication that the tail lights are not working. The first thing to check is that the tail light fuse is not blown. Most of the time replacing the tail light fuse will restore both the tail lights and the dash/interior lights. If this is not the case you may have to trace the wires and look for a broken or unplugged wire in the harness.
1helpful
How do I change a brake light bulb in a 1999 c70 volvo?
Welcome to FixYa.com
Brake Lamp Replacement
Location of the lights
The illustration shows the locations of the lights on the RH side. The LH side is the same but
mirror-reversed.
The lights have the following functions:
- 1 +1 = Parking light Fail light
- 2 = Reversing light
- 3 = Fog light LH side only (LHD cars)
- 5 = Direction indicator
- 6 = Brake light
Tail light changing bulbs
Ignition off.
Open the cover in front of the tail light
Undo the wing nut and take out the lamp holder.
Change the defective bulb.
Fit in reverse order.
Check that all bulbs lamps are intact and in working order.
Replacement of tail light cluster
Note! If a new tail light is to be fitted, the sleeves must be ground down 1.5 mm.
Open the cover in front of the tail light Undo the panel partly in front of the tail light Unplug the
connector for the tail light Undo the four nuts securing the tail light see illustration.
Pull the tail light straight out. Fit in reverse order
Note! check the sealing and fit on reassembly.
Check that all bulbs lamps are intact and in working order.Thank you for Using FixYa.comKind Regards, LeeYour FixYa Expert and Master Technician
Where is the fuse for the right side tail light?
hi if it is only the one bulb not working/tail light and the front light on same side is working along with number plate and other tail lights may i suggest you replace/check the bulb on defective light as if fuse had blown ? the front light on same side would not be working if you put ignition on and press brake your brake light shoul work ? if so change the bulb as the bulb has two elements inside tail light and a higher wattage element for brake light
2answers
Tail lights work on both sides. turn signal and
Sounds like you need to replace the drivers brake/tail light.
2005 ford focus
I just chaged my left tail light bulb, it's working.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
