Question about T-Mobile Sidekick II
I can't take off the privacy lock and keyguard off my phone
I am having trouble taking the privacy lock and keyguard off my phone.i have tried resetting my phone and still no luck.any suggestions on what i should do.
0 characters
1 Points
To remove a privacy lock of samsung gt-E2222
turn on your phone without simcard ,if the phone display insert sim card type this in your keypad ..*2767*3855# ,your phone will reboot and the privacy lock will reset to 8 zeros (00000000)
Sep 30, 2012 | Samsung Chat 222 Plus
Treo 700w-Blank screen
You may have a faulty screen
Have you tried a HARD RESET?
Perform the following steps:
Pull the battery out. Put the battery back in while holding the RED button down and a reset screen will appear.
Push the up button on the five-way to start the reset process.
Alternate process:
Similar to the hard-reset of the Treo 650. Remove the battery cover.
Press and hold the Red radio button.
Use the stylus to depress the reset button next to the battery.
Push the up button on the five-way when you get a prompt to "Erase all data".
Replacement screens are available on ebay.
Sep 04, 2008 | Palm Treo 700w Smartphone
Cant press anything in the sim center menu in my sidekick 2008
i dont kno how buh maybe we could help each other I forgot my sidekick lx 3 digit privacy code? i try taking off my sim card but it came then when strigth to the privacy lock .. how can i reset everything idc if it remove all the contacts just want my phone back
Jul 26, 2009 | T-Mobile Sidekick
I locked my sidekick lx with a privacy lock code & forgot passwor
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
May 20, 2009 | T-Mobile Sidekick
Forgotten privacy lock password
Master reset(unlock) #*7337#
if that will not work then try
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Sep 04, 2008 | Samsung SGH-U600
Sidekick lx
i know a way that will take the unlock off the phone however it also removes everything else too. i accidently took the battery out with the phone on trying to remove the memory card. it reset the phone completely when i restarted it. i had had a privacy lock on it and that was gone too. kinda drastic if u do it make sure you save all your stuff on memory card and simcard.
Aug 13, 2008 | T-Mobile Sidekick
You should be able to reset this by turning on the phone without the SIM card inside, then entering *2767*2878# and waiting for the phone to reset. Once it starts up, the code should be gone from the phone and you should be able to get into it again.
May 12, 2008 | Samsung SGH-U600
Phone code
Goto settings
Tick Phone Privacy and any other you want
click save and enter the password for your phone
Apr 25, 2008 | Samsung SGH-U600
After sitting for a while............
I think your phone is going into to keyguard mode. Push the Red power button on the top right of the keyboard. Should come up with a keyguard lock screen at the botton of the screen. Push the center button on the 5-way navigation and you phone should function normally until it goes into to keyguard again. You will find the settings under preferences to either turn keyguard off or to adjust the time on it.
Jan 22, 2008 | Palm Treo 755p Smartphone
Sidekick II reset:
Drain your battery until your phone refuses to turn on, then charge it, the privacy lock should be off.
Press and hold the Menu key (the one with 3 lines) + the shift key and finally the "Q" key all at once.
Okay so you're at the privacy lock screen.
Okay press the Menu key and the Phone Mode key (the one with the circles) at the same time.
This should take you to emergency phone calls
Hold down the Back key (the one with the arrow) DON'T LET IT GO.
Now press MENU and PHONE MODE at the same time, now let go the BACK KEY
Then press BACK again and let go of MENU and PHONE.
Now press MENU and PHONE again and then let go of BACK.
It takes like 3 times to unlock it
but it always works.
Jan 21, 2008 | T-Mobile Sidekick II
T-Mobile Sidekick II Logo
241 people viewed this question
Top T-Mobile PDAs Experts
Martin Murray
Are you a T-Mobile PDA Expert? Answer questions, earn points and help others
