Question about Toshiba TP-55H64 55 in. Rear Projection Television
Having a problem getting a picture
We have a rear projection Toshiba, with a 61" inch screen. We have a problem getting a picture. There are some channels that are perfect and with other channels we get a black screen right in the middle with only the top and bottom showing. There is sound, but we are only able to get around 12 channels that are viewable.
    Problem Solver:
  • 16 Answers
I agree W/Techman sounds like someone turned on the tex box Look in your insturction manual it will be in there how to turn it off or go to the Toshiba web sight and download the owners Manuau under Services Downloads Good luck Walter Grzybowski
Posted on Sep 23, 2006
    President:
  • 3,130 Answers
Im sorry to tell you this but it sounds like someone turned on the text feature on the closed caption? Go into the menu function, with the remote, and turn off the closed caption.
Toshiba 61 inch rear projection scrambled picture for 10 minutes after power on, then clears up.
If you are seeing lines and or noise for the first several minutes and it goes away--I think I know what the problem is.
Has the period of time before it clears up been getting longer and longer?
Reply to me with the exact model number and I will tell you what is wrong and what has to be done to fix it.
A lot of these sets have problems with what is called a HYPER board----it controls all signal inside the set--confirm Toshiba and exact model number---
I am here to help people and I do this here for free.
REGARDS, SD TECH
Oct 31, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba no picture
then your optical section has fault.
Mar 17, 2008 | Toshiba 61A61 61" Rear Projection...
RCA Projection TV not working properly
All I need to know is how to shrink the picture!
Dec 21, 2008 | RCA P61830BL 61" Rear Projection...
TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Jul 29, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
BLINKING POWER LIGHT AND TV DOES NOT POWER ON
I have a toshiba 61 inch projection tv the power light flashes with no picture any easy fixes?
Jun 24, 2008 | Toshiba TP61G90 61" Rear Projection...
Do you have instructions for replacing the outer picture screen?
I'm muziclady & I had three choices to choose for replacing the screen. The first was to purchase a new screen through Sony's parts dept. site
Secondly I found this this site that makes rear pro. screen antiglare screens: http://www.glarestopper.com/measure2.php
Also from this site, it has instructions for the removal of the screen to measure & re-install. [which is easy]. The actual screen size for the 61" is 58x30 inches, & it's referred as being a 61" Projection TV Screen Only [Lenticular Fresnel] .
My final choice was to Google for a screen replacement. I was fortunate to find a used one from an RCA television..It's the exact same size, etc.
Hope this helps... :)
Mar 03, 2008 | Sony KP-61S65 61" Rear Projection...
Toshiba Rear Projection TV Problem
Toshiba is one of the few sets that do not have a diagnosis feature built into the power light , Toshiba has to be able to light the screen to access its self diagnosis features. So you will most likely need the service manual to check the voltages in order to properly diagnose your set. You can get a service manual at the following link, and they will email it to you if you would like. here is the link.
http://servicemanuals.vstore.ca/
Feb 09, 2008 | Toshiba 61HX70 61" Rear Projection...
Jittering screen
Chassis will need to be pulled by a skilled technician.Some specific area hand-soldering is needed and the STK convergence IC's need changing w/OEM or better quality parts.You have a good set worthy of repair.
Sep 26, 2007 | Toshiba 61H70 61" Rear Projection...
Blurry
Hello, one of the possible causes can be the malfunction of the HV splitter transformer. Best regards, Arpi
Jun 23, 2007 | Toshiba 61HX70 61" Rear Projection...
61 inch proj. warped concave picture.
Josh Any chance you could send a photo... Too many ideas come to mind from what you've described. Would actually have to see the "warp" in the picture itself to see if it's one or all colors, any boarders and if the bend is actually pulling from top or bottom.. Bill premtech@willapabay.org
Jun 14, 2007 | RCA P61960 61" Rear Projection Television
Televison & Video Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
