Question about Altec Lansing 641 Computer Speakers
My subwoofer started smoking-
I smelled a burning odor, wasnt even on the computer, found smoke coming out of the holes in the back of the subwoofer, and crackling noises throught the subwoofer speaker itself. The smoke is coming from right behind the lower speaker on the sub, and venting thru the air tubes
    Master:
  • 763 Answers
A usual problem of a subwoofer just like my old sound system. Subwoofer generates a big heat on its device unlike ordinary speakers. better to send that to a technician to change a spare parts. it must be an ic problem got damage by over using.
thank you for using fixya
CHARCOIS
Posted on Nov 02, 2008
I have a 92 blazer 4.3 vortec
Hi there:
Black smoke is caused by excess fuel that has entered the cylinder area and cannot be burned completely. Another term for excess fuel is "running rich." Poor fuel mileage is also a common complaint when black smoke comes out of the tailpipe. Black smoke out the tailpipe is the least cause for alarm. Excess fuel will usually effect engine performance, reduce fuel economy, and produce a fuel odor.
How did the fuel get into the cylinder in the first place? Some of the causes of excess fuel are a carburetor that is out of adjustment, a faulty fuel pump, a leaky fuel injector, or a faulty engine computer or computer sensor. If black smoke is present, check the engine oil as in the white smoke example to make sure excess fuel has not contaminated it. Do not start the engine if a heavy, raw fuel smell can be detected in the engine oil. Call your mechanic and advise him of what you have found.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Mar 04, 2012 | Cars & Trucks
Hi there:
Smoking out the back and burning smell inside.
check for a cracked head that smoke you see is probably antifreeze coming out of the coolant trench in the block itself or could just be a bad gasket on your head
May 06, 2010 | 2004 Mazda 6
White smoke-like stuff comes out of heater vent of my car.
sharp acidic smell would be electrical
sweet smell would be coolant.
Feb 06, 2010 | 2000 Buick LeSabre
Why do i get black smoke when i boot it hard out of the exhaust
Black smoke is caused by excess fuel that has entered the cylinder area and cannot be burned completely. Poor fuel mileage is also a common complaint when black smoke comes out of the tailpipe. Black smoke out the tailpipe is the least cause for alarm. Excess fuel will usually effect engine performance, reduce fuel economy, and produce a fuel odor. Some of the causes of excess fuel are a carburetor that is out of adjustment, a faulty fuel pump, a leaky fuel injector, or a faulty engine computer or computer sensor. If black smoke is present, check the engine oil to make sure excess fuel has not contaminated it. Do not start the engine if a heavy, raw fuel smell can be detected in the engine oil.
Aug 17, 2009 | 2005 Jaguar X-Type
White smoke and smell of eggs
White smoke in the exhaust, more so on a cold start. That's steam. Water is getting into the combustion chamber. Most likely coolant.
Put your hand in the white smoke to capture the odor. (don't burn yourself)
What does your hand smell like? Coolant (anti-freeze & water) smells sweet.
Likeliest cause = head gasket. Possible = cracked head - depending on how hot it got. Less likely = cracked intake manifold.
Maybe a blown head gasket
Apr 01, 2009 | 2006 Ford Focus
350 chevy Lost compression and engine began to smoke.
pull out your spark plugs and try cranking the motor again, see if you're spitting out coolant from the plug holes. I'm asking you to do this, cuz it sounds like you blew a head gasket.
Mar 02, 2009 | 2000 Chevrolet Blazer
Kenmore ultra self cleaning oven or top heat
I found that the 220 plug had burned out, that was where the smoke came from. The display worked because the ground "prong" was the only one burned. Had to replace the electrical 220 socked and the electrical plug on the oven.
Jan 13, 2009 | Ovens
Altec Lansing 641 Computer Speakers Logo
642 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
