Heat/AC Fan not working
When I turn on the heat or the a/c, I can hear them running, but nothing is coming out of the vents.  Even when I just turn the thermostat to "fan," nothing comes out, which leads me to believe it's the fan...why would it stop working and who is the best person to call?
    Scholar:
  • 147 Answers
You are probably right. You indoor fan is bad.They are very easy to change and anyone with mechanical knowledge can do. I would get a ac mechanic that I know and trust to check it out because there are several reason that could cause the fan not to run. The worst thing would be a bad motor and they cost about $75. A good electrician could check it.
Posted on Nov 02, 2008
What is causing my 2008 trailblazer heat/ac to blow on unexpectedly
it sounds like the fan resistor is faulty location of it will be attached to the fan structure or if not trace the red and black power wires coming from the fan it will be mounted close to the fan
Mar 16, 2016 | 2008 Chevrolet Chevrolet TrailBlazer LT
Fan will not go off and nothing else will work
If this is a gas heater, the problem is likely either a tripped flame roll out switch or limit switch. The issue here is that if the limits are tripped, there could be a very serious issue. There could be a bad switch, but there also could be a plugged flue, or a cracked heat exchanger. Either way it is definately worth getting this checked by a professional Serious safety issues could easily be the issue.
Apr 08, 2014 | Heating & Cooling
Malibu heating and ac
does the car have automatic climate control?
Apr 05, 2014 | 2005 Chevrolet Malibu
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
Coleman furnace problems
I take you mean there is a fan coming on that blows AC air thru the vents and is the same fan used to blow the heat ? If that is the case is the fan coming on when the heat comes on ? If not then that is why you are not getting the heat.
That can be from a temp sensor not working or a control board or a contactor
First see if the fan even comes on or if the same fan is used for both AC and heat
Oct 13, 2013 | Heating & Cooling
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
I have a 2003 Buick Rendezvous and when I turn on the AC or heating nothing comes out of the vents. I had it checked at Meineke and they said the fuses are fine and the blower motor is working. Do you have...
If nothing is coming out, put your hand on the blower motor under the glovebox and put the fan on high. You should hear and feel it. If not you may have to replace the blower. Dont\'t replace it till you verify it is getting power.
Jun 14, 2011 | 2003 Buick Rendezvous
Air/heat blower is not working unless it is on high.
The heater resistor is probably faulty, its located near the blower fan
May 23, 2010 | 2000 Toyota Camry
AC/heat doesn't come out front vents. Can hear
try a vaccum leak under the hood. Look and listen for any little sounds of air blowing out. Also the door switch may not be turning to vent it may be stuck on one side, like defrost!
Nov 23, 2009 | 2001 Oldsmobile Silhouette
AC Compressor running outside but no air coming out of inside vents.
Can you say, WOw, Icould've had a v-8 moment! I think you answered your own question or you are not far from the answer. (let me direct you, either the thermostat or the little door on the duct going to your room! Thank-you-very-much!
Aug 01, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
