Question about Frigidaire FRS23R4A Side by Side Refrigerator
Fridge on the Fritz
I have a side by side Frigidaire refrigerator. I purchased it 18 months ago. The bottom of the refrigerator and the freezer is cold but the upper part of the refrigerator and freezer is not. I took everything out of it and turned it on its coldest setting and it is still not working. Please help!
  • 3 more comments
  • teejewels Nov 02, 2008
    I went grocery shopping the other day and had some large pizza boxes in my freezer. I had them kinda stuffed in there. So, I'm thinking I had blocked the blower. However, I have moved the boxes and still only the bottom of the freezer and refrigerator is getting cold. I unplugged the freezer last night and let it sit overnight so that all the ice could defrost. Should I put it to the coldest setting or factory setting.
  • teejewels Nov 03, 2008
    I can't hear a fan blowing. The bottom of the freezer and the bottom of the refrigerator is getting cold. However the top on both sides are not. I hear my refrigerator is humming as normal. I can't get any ice but the water is coming out cold.I pulled the refrigerator out and I see a fan blowing. Gosh, I don't want to call a repair man!
  • teejewels Nov 04, 2008
    Thanks so much Aborcass!! I took the back panel off of my freezer and I can see that the fan is not blowing. Is this common after only 18 months? By the way , what does hte mean?
    I haven't been bale to find this part for less than $100. Do you have any suggestions?
  • teejewels Nov 11, 2008
    THANK YOU !!! THANK YOU !!!!!! THANK YOU!!!!! You were right! My evap fan had gone out. I called a local company and explained to the guy what the problem was. He told me it would cost me around $200.00 to fix. He said the part by itself was $60.00 and he sure could not sell it to me at cost. NO WAY was I going to pay that! I kindly told him to have a nice day! I went online to appliancepartspros.com and purchased the part for $31.00. That included $6.95 for shipping!!! So the part was only $24.00. Anyway, the part arrived the next day and my husband installed it within minutes! Thank You so much, I thank God for people like you who help people like me!
    President:
  • Frigidaire Master
  • 2,651 Answers
Sounds as if perhaps theres a fan in the freezer, copartment that is not spinning, circulating the cold air around, or if that fan is spinning you have adefost issue,not "self defrosting so the ice is building up preventing proper circulation
Posted on Nov 02, 2008
  • 2 more comments
  • Ron Coons
    Ron Coons Nov 03, 2008
    normal settings will restore proper cold levels, barring any problem, can you hear a fan spinninginside the freezer compartment???
  • Ron Coons
    you def sounds as if you have a faulty evap fan motor,(not circulating air into the refrig compartment)
    heres the part number for the fan, you can call frigidaire to send it to you or get it from sears.com. As long as you minimally handy this should take you no longer then 25 min to replace, part retails for under $50. yull need to unplug unit, and remove the back wall of freezer compartment( only hte center section to gain acess the evap fan assy, its probalby 4 screws and 2-3 wires, EASY repair
    part number 5304445861
  • Ron Coons
    Ron Coons Nov 04, 2008
    hte--- poorly spelled THE, not really common problem but can happen iguess.
  • Ron Coons
    1-888-APWAGNER -- part whare house i use , claims its under $50
We have a Frigidaire FRS202RG side by side fridge/freezer that is about 9 years old. In the last 3 months, it has begun frosting up in the bottom of the freezer with ice forming over the vents at the back....
Sounds like the fan behind the rear freezer panel has stopped working,therefore no air flow over evaporator coils causing ice built up and no cooling on refrigerator side. easy fix
Nov 30, 2010 | Frigidaire FRS26ZSG
I have a Frigidaire Model FRS6R5ESBF that is 3 years old but did not get installed until 4 months ago. The freezer appears to be working fine but the refrigerator side is getting warmer by the day. It...
Could be that the freezer is icing up stopping the air flow coming up into your fridge, try switching it off for at least 12 hours with the freezer door open.
Nov 02, 2010 | Frigidaire Refrigerators
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Ge profile brita 18 bm black purchased in jan/06
Having the same problem. apparently this is just a horrible fridge... unfortunately no solution for ya
Jan 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Bizarre Refrigerator Problems
If your voltage is around 117v.you are okay.Any time you lose cold air except the freezer you probably need to check your evaporator thermostat and your heater.
Sep 15, 2008 | Samsung RS2556 Side by Side Refrigerator
Fridge on fritz
Did you check the motor and/or damper mechanism that directs cold freezer air into the refrigerator portion. If that is messed up the freezer is ok but fridge is ng. Also look at door seals for proper sealing.
May 05, 2017 | Frigidaire FRS3R5EMB Side by Side...
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
155 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
