Question about ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN,
Pc reboot ramdomly or freeze after a while
i just bought a new pc containing
motherboard : asus p5qc
processor : intel q9550
memory : KINGSTON 4GB (2X2G) DDR3-1333
videocard : Zotac nVidia GeForce GTX260 896MB
power supply : 650W Cooler Master Extreme Power SLI
since i installed the OS, the pc sometime freeze just few minutes after i log on and sometimes when i can use it longer, it will simply reboot ramdomly.
ty for help
  • 4 more comments
  • Hakuya Nov 02, 2008
    sup,
    i used window xp sp2 and i tried to reinstall it but nothing changed many times
    i also switched to window xp sp3 than i borrow from a friend but it's even worse, it's doesn't freeze anymore, it's only ramdomly reboot! (not updated, formatted than install in hdd)
    the only program i installed is the lan onboard software and the graphic software nothing else
    the desktop is all empty
  • Hakuya Nov 05, 2008
    ok now the machine doesn't reboot anymore but sometime it freeze on startup
    thx ARCLIGHT1217 for your support
  • goldenlife Nov 19, 2008
    I built a custom PC using the P5QC Mother board and the Intel Q6600 Processor, Buffalo 4GB(2x2 DDR2 800) memory, Gfource 9500GT Video card and Seagate 500GB Sata HDD. Built the system and posted fine, Installed Vista Ultimate and system Hung. Updated all Drivers based on CD privided by Asus for hardware and ensured Video Card Driver was latest from GForce. Pathced OS completely. Still Hung.
    I started diagnosing,
    Removed Video card and used basic nvida PCI video card. still hung
    Reduced and swapped RAM around to determine If I had a bad DIMM. still hung
    Removed Vista Operating System and installed Windows XP SP2 from scratch. Still hung.
    At this point the only two items I can not swap out is the Processor and the Motherboard. Next step is to replace the mother board with an excact replacement. Hoping it is just a defective component, not a defective design.
  • Anonymous Feb 28, 2009
    I dont know why, but this motherboard keeps doing frezzes!!
  • psycho0170 Mar 21, 2009
    My pc reboot ramdonly, i have a q9300 a ati 4870 and the same 2x2gb kingstone ddr3
  • jeeps005 Apr 27, 2009
    im having the same problem with my pc (p5qc). It would always freeze 10-15 min after booting it. After trying a bunch of different things, i found out that it was the USB ports that were causing it to freeze. I'm now using ps/2 mouse and keyboard and my system works fine. any suggestions on how to fix my usb ports?
    jpnadeau_005@hotmail.com
    Novelist:
  • 208 Answers
HI! THE ONE QUESTION I NEED TO KNOW IS WHAT OS? JUST GENERALLY I WOULD SAY THAT YOU MIGHT TRY TO UPDATE THE OS TO THE LATEST VERSION. AGAIN, NOT KNOWING THE OS, THIS IS A FIX I WOULD TRY. YOU SAID THE PROBLEM HAPPENED AFTER YOU INSTALLED THE OS, BUT WHAT ELSE WAS INSTALLED ALSO? YOU MIGHT NEED TO LOOK AT ALL PROGRAMS TO BE SURE THAT YOU HAVE THE LATEST VERSIONS AND THAT THEY ARE COMPATIBLE WITH YOUR OS. SO, THESE ARE SOME IDEAS FOR NOW. TRY THEM AND IF NO LUCK, REPLY AND LET ME KNOW THE OS YOU ARE USING AND THE PROGRAMS INSTALLED. OK? I'LL BE GLAD TO HELP.
ARCLIGHT1217
Posted on Nov 02, 2008
  • BRIAN REISS
    BRIAN REISS Nov 02, 2008
    IS YOUR MACHINE RECEIVING AUTO UPDATES? DO YOU HAVE A BROWSER INSTALLED LIKE IE7 OR SUCH? I WAS JUST WONDERING IF A SCHEDULED TASK MIGHT BE RUNNING IN THE BACKGROUND THAT IS CAUSING THE REBOOT? SOMETIMES A VIRUS PROGRAM WILL DOWNLOAD UPDATES AND WANT TO REBOOT TO HAVE THE NEW UPDATE ACTIVE. WOW, THIS IS SOMETHING BECAUSE WIN XP IS SUCH A STABLE PROGRAM USUALLY. YOU MIGHT TRY A PHYSICAL INSPECTION INSIDE THE CASE, BECAUSE I'M THINKING THIS IS A ELECTRICAL TRIGGER OF SORTS, POSSIBLY CAUSED BY A LOOSE CONNECTION SOMEWHERES INSIDE BETWEEN A COMPONET OR ON THE MOTHERBOARD. I KNOW THIS SOUNDS GOOFY, BUT I'VE SEEN A LOOSE PLUG PLAY HAVOC WITH A SYSTEM BEFORE. THIS IS WHY I PASS THIS ALONG. LET ME KNOW. WE'LL FIND IT!
    ARCLIGHT1217
Blue sceen ASUS 3 Motherboard - M4A88TD-M EVO
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Tracey Laidler.
Yes you are quite correct BSOD or Blue Screen Of Death is normally due to a memory fault. However drivers are as big a culprit, especially seeing as though you have changed memory modules and processor.
Install all the drivers for this mainboard.
Also enter the BIOS/CMOS by tapping the Delete key during first powering on the computer.
Once in the BIOS/CMOS select the option to load defaults.
Check if that works.
If not then take it a step further by clearing the BIOS/CMOS by removing the silver button cell from the mainboard for 10seconds before reinstalling it in the correct orientation.
Take care!
Dec 15, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
Does the Intel MB DG41TX work with the Intel 7300 processor and a single 4GB memory module (Kingston KVR1333D3N9/4G)?
maximum memory for this motherboard 4 GB not sure about a single 4GB module
Max Supported Memory 4 GB
  • Supported RAM Technology DDR3 SDRAM
  • Supported RAM Integrity Check Non-ECC
  • Two 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets
  • Support for DDR3 1333(OC)/1066/800 MHz DIMMs
  • Support for up to 4 GB? of system memory
  • hope this helps
  • Sep 03, 2011 | Intel DG41TX Motherboard
    Hi , my name is Nitin and the problem i am facing with my PC is that it gets restarted after every 10 to 15 minutes while playing games and it starts disk checking everytime it restarts. This happens even...
    The following tip is not for the same model, but for the same kind of symptoms :
    http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/183116-asus-p5p800-p4-3-0ghz-random-reboots.html
    Dec 18, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
    Hi I'm having problems installing windows 7 on my computer I think it may have something dealing with my motherboard I m running a MSI P55M-GD41 mother board with intel i5-661 processor and 4GB of 2 2GB...
    One bad lead will cause your computer to shut down or continue in a cycle
    replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive
    hope this helps
    Oct 24, 2010 | MSI P55MGD41 Motherboard
    Windows 7 64bit ultimate edition Lots of ''Application Error''
    asus M2N68-AM PLUS motherboard is supports all operating system but intel is not support win 7 64bit
    May 13, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
    Asus p5qc not working
    The motherboard is dead most likely, if the cpu fan is running ? the hdd can be heard running ? the cd/dvd device is active ? then the motherboard is toasted. what is the system ?
    compdoctor2005@btinternet.com
    Nov 16, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
    Windows fail to boot
    How much power is the power supply? Could be the power supply not having enough power for your rig.
    Sep 23, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
    ASUS Asus P5QC Motherboard
    Hello edwardfuller:
    Do the same as you did, only this time remove all plug in boards and if there is anything connected to the mother board such as extra fans, speakers, and so on, remove all.
    The board will detect any shorts, or overloads or problems in cards and so on , and will not turn on.
    If it still will not work, check your memory sticks.
    Remove all memory and place one at a time in the first slot, and then proceed to turn on and test.
    By elimination, you can find the problem.
    If all fails, then something may be wrong with the mother board.
    take care, hope this will help,
    Sep 02, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
    ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN, Logo
    505 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
