Question about Northgate STAC2217L (Bundle) PC Desktop
Outlook Express I am trying to put my OE files in a backkup folder. I have XP with ser.pack 2. In the store location dialog box, I have highlighted the store location and hit CTRL plus C to copy it. and then closed out the dialog box. My problem occurs when I try to copy the contents to the store folder by start, run, CTRL plus V then OK. I don't know what is supposed to show up in the run box when I hit the CTRL plus V but it just picks out an email and highlights it in the run box. When I click on the edit it menu to select all and then copy, it tells me it cannot find the file. Do I I have a file missing or is it something I've done or not done? Thanks for your help.
  • franklin33 Nov 02, 2008
    I have worked thru it to the point where I have done the control V and then can go to the edit menu and select all. After I have selected all, then I again click on the edit menu and need to click on copy and copy will not be highlighted for me.
  • franklin33 Jan 21, 2009
    I now have my OE files saved to a CD. Thanks, you folks on Fixya for this and other answers!
Go to each of your OE folders. Press CTRL and A to select all in that folder. Go to your backup folder for example email inbox backup, and pres CTRL and V. This will paste all teh selected files into the backup folder. You can also use drag and drop. Repeat for each OE folder. I hope I have understood what you want to do properly. I have assumed by OE files you mean all your mail. You can also create a backup by exporting your files.
Posted on Jan 19, 2009
Tip
Duplicate emails in Outlook Express?
When Outlook Express is configured for POP3 mail access it uses a file called pop3uidl.dbx to keep track of which message have been downloaded so that it can download only new messages. Sometimes this file becomes corrupted which results in the same messages getting downloaded again. So we will need a different copy of this file. Please do the following to recreate it:
- In Outlook Express click on Tools and Options.
- Click on maintenance tab.
- Click on Store folder button.
- It will open a small window with a path to the store folder.
- Copy the whole path.
- Click on start and Run.
- Click inside the run box and press Ctrl+V, it will paste the whole path we copied.
- Click on OK. It will open the store location.
- Close Outlook Express.
- In the folder that was opened, locate the pop3uidl.dbx file and right click on it and select rename.
- Rename that to pop3uidlold.dbx.
- Open Outlook Express and you will no longer receive any duplicate messages.
If you are using IMAP account, that can happen if your IMAP account is the default mail account and OE is configured to both open directly to the Inbox (which downloads headers automatically) and check for new messages when starting (which also downloads headers automatically). To stop the duplicates, simply choose one option or the other, but not both:
In Outlook Express click Tools > Options, then
1. Remove the check mark for When starting, go directly to my ‘Inbox’ folder
OR
2. Remove the check mark for Send and receive messages at startup.
If you already have duplicates showing, click Tools > Synchronize Account or Synchronize All.
on Nov 18, 2008 | Microsoft Outlook Express
Tip
How to back up Outlook Express items
Step 1: Copy message files to a backup folder
Step A: Locate the Store folder
1. Start Outlook Express.
2. Click Tools, and then click Options.
3. On the Maintenance tab, click Store Folder.
4. In the Store Location dialog box, copy the store location. To do this, follow these steps:
a. Put the mouse pointer at one end of the box under the Your personal message store is located in the following folder box.
b. Press and hold the left mouse button, and then drag the mouse pointer across the Your personal message store is located in the following folder box.
c. Press CTRL+C to copy the location.
5. Click Cancel, and then click Cancel again to close the dialog box.
Step B: Copy the contents of the Store folder
1. Click Start, click Run, press CTRL+V, and then click OK.
2. On the Edit menu, click Select All.
3. On the Edit menu, click Copy, and then close the window.
Step C: Create a backup folder
1. Right-click any empty area on your desktop, click New, and then click Folder.
2. Type Mail Backup for the folder name, and then press ENTER.
Step D: Paste the contents of the Store folder into the backup folder
1. Double-click the Mail Backup folder to open it.
2. Right-click inside the Mail Backup folder window, and then click Paste.
Step 2: Export the Address Book to a .csv file
Important Make sure that you follow this step if you use multiple identities in Outlook Express.
Microsoft Outlook Express 5.x and Microsoft Outlook Express 6.0 use a Windows Address Book (.wab) file to store Address Book data. The individual data for each identity is stored in a folder by user name within the .wab file that is used.
The only way to separate the Address Book data for different identities is to export the data to a .csv file while you are logged in as a specific identity. If the .wab file becomes dissociated from the user identities, the data can be exported only as one total. In this case, the data cannot be exported folder by folder.
There is another reason to export the .wab file to a .csv file. If the .wab file not exported to a .csv file, but the .wab file is shared with Microsoft Outlook, the addresses are stored in the personal folders (.pst) file in Outlook. When you export the file to a .csv file by using the File menu in Outlook Express, the correct contacts are exported. However, if the Address Book is shared with Outlook, you cannot use the File menu option to export from the Address Book. This option is unavailable.
To export the Address Book to a .csv file, follow these steps:
1. On the File menu, click Export, and then click Address Book.
2. Click Text File (Comma Separated Values), and then click Export.
3. Click Browse.
4. Select the Mail Backup folder that you created.
5. In the File Name box, type address book backup, and then click Save.
6. Click Next.
7. Click to select the check boxes for the fields that you want to export, and then click Finish.
8. Click OK, and then click Close.
Step 3: Export the mail account to a file
1. On the Tools menu, click Accounts.
2. On the Mail tab, click the mail account that you want to export, and then click Export.
3. In the Save In box, select the Mail Backup folder, and then click Save.
4. Repeat these steps for each mail account that you want to export.
5. Click Close.
Step 4: Export the newsgroup account to a file
2. On the News tab, click the news account that you want to export, and then click Export.
4. Repeat these steps for each news account that you want to export.
5. Click Close.
Back to the top
How to restore Outlook Express items
Note To restore items when you use multiple identities in Outlook Express, you may have to re-create the identities before you follow these steps. Repeat each step as needed for each identity.
Step 1: Import messages from the backup folder
1.
On the File menu, point to Import, and then click Messages.
2. In the Select an e-mail program to import from box, click Microsoft Outlook Express 5 or Microsoft Outlook Express 6, and then click Next.
3. Click Import mail from an OE5 store directory or Import mail from an OE6 store directory, and then click OK.
4. Click Browse, and then click the Mail Backup folder.
5. Click OK, and then click Next.
6. Click All folders, click Next, and then click Finish.
Step 2: Import the Address Book file
1.
On the File menu, click Import, and then click Other Address Book.
2. Click Text File (Comma Separated Values), and then click Import.
3. Click Browse.
4. Select the Mail Backup folder, click the address book backup.csv file, and then click Open.
5. Click Next, and then click Finish.
6. Click OK, and then click Close.
Step 3: Import the mail account file
1.
2. On the Mail tab, click Import.
3. In the Look In box, select the Mail Backup folder.
4. Click the mail account that you want to import, and then click Open.
5. Repeat these steps for each mail account that you want to import.
6. Click Close.
Step 4: Import the newsgroup account file
1.
2. On the News tab, click Import.
4. Click the news account that you want to import, and then click Open.
5. Repeat these steps for each news account that you want to import.
6. Click Close.
Thanks and Regard
Dilip Bagdi - johny_inmexico@yahoo.co.in
on May 10, 2008 | Microsoft Windows XP Professional
Recover Outlook Express e-mails which are not displayed anymore in INBOX
Try this first:
Note To restore items when you use multiple identities in Outlook Express, you may have to re-create the identities before you follow these steps. Repeat each step as needed for each identity. Step 1: Import messages from the backup folder
  1. On the File menu, point to Import, and then click Messages.
  1. On the File menu, click Import, and then click Other Address Book.
  3. Click Browse.
  6. Click Close.
  6. Click Close.
How to preserve the Blocked Senders list and other e-mail rules
For more information about how to preserve the blocked senders list and other e-mail rules, click the following article number to view the article in the Microsoft Knowledge Base: 276511 How to back up and restore Outlook Express Blocked Senders list and other mail rules.
If not try this:OE-Mail Recovery (download) is a tool for repairing Outlook Express folders if they are damaged or corrupted. OE-Mail Recovery (Outlook Express mail recovery tool) extracts and saves e-mails from .dbx files in which Microsoft Outlook Express stores messages and folders on the local drive. The DBX Recovery tool will help you avoid troubles with Outlook Express folders, fix the problems with Outlook Express folders that you can't open or recover .dbx of Outlook Express.
Mar 01, 2015 | Microsoft Outlook Express
I wish to download windows outlook express to my new computer. I would like to transfer all the data including email addresses from my office PC onto this new Toshiba laptop
  1. Open Outlook Explorer.
  2. Right-click on the Folder at the top of the left pane, and, from the context menu that appears, select Properties (see Figure 1 below). If you are using Outlook 6, you need to expand the Folders and right-click on the Inbox (see Figure 2 below).
  3. When you select the Properties option, you are presented with a dialog box with the location of the Outlook folders (see Figure 3 below). The full path is displayed as a label in Outlook 6 and as a text box under the Advanced tab in Outlook XP or 2000.
  4. Select the entire path from "C:\" to "\Outlook Express". Do not copy the filename given after "\Outlook Express." For example, if the path is C:\Documents and Settings\USER\Local Settings\Application Data\Identities\{B7ABE5FE}\Microsoft\Outlook Express\Inbox.dbx, you need only the C:\Documents and Settings\Arun\Local Settings\Application Data\Identities\{B7ABE5FE}\Microsoft\Outlook Express.
  5. Copy, paste, and save this path in a text file.
  6. Open a Windows Explorer window, and paste the path into the address bar and press Enter.
  7. Before proceeding to copy the folders to a CD or flash drive, you need to check if there are any hidden files or folders in the Outlook Express folder. To check this, check the Show Hidden Files and Folders in the View tab of the dialog box that you get when you select Folder Options in the Tools menu.
  8. The next step is to select all the files and folders in the Outlook folder. If you are using a version previous to Windows XP, you will need some CD burning software to copy the files to the CD. Otherwise, you can simply paste the files to the CD or flash drive. Do not forget to copy the text file containing the path in both cases.
  9. You now have all the emails, calendars, tasks, and other important things from Outlook, but you may also want to copy the address book. To copy the address book, use the Export option in the File menu of the Outlook Express. Once exported, use the method described above to copy it to the flash drive or to the CD. Now you are all set to move your Outlook messages to the new computer.
  10. Boot the new computer. Use the path you stored in the text file to open the Outlook Folder on the new computer. To do this, copy the path from the text file, open a Windows Explorer window, paste the path into the address bar, and hit Enter.
  11. Copy all the files from the CD or flash drive to the Outlook Express folder. When you are prompted to overwrite the files and folders, select Yes to All.
Read more: http://www.brighthub.com/computing/windows-platform/articles/45168.aspx#ixzz1FV6xRlBl
Mar 03, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Outlook Express. Can not delete items from the inbox?
Open OE and save or move any messages you want in the Inbox.
Click on Tools>Options>Maintenance tab>Store Folder.
On the Store Location box, highlight the address by pressing the Tab key on your keyboard.
Press Control+C (both at the same time) to copy the address to the clipboard.
Click Cancel on all boxes and close OE.
Click on Start>Run.
Press Control+V (both at the same time) to paste the address into the command line and click OK.
The store folder containing all the DBX files should open.
Find the one named Inbox and delete it. When you next open OE a new Inbox will be created and hopefully that will solve the problem.
Feb 28, 2010 | Computers & Internet
File with extension *.dbx
DBX files (files with *.dbx extension) are the files where Outlook Express stores email messages.They can be found in so-called Outlook Express Store Folder named"Inbox.dbx," "Sent Items.dbx," etc. To determine Store Folder locationclick Store Folder button at Tools>Options>Maintenance in OutlookExpress. DBX files may be copied to another folder in order to backup e-mail messages.
How to open and edit DBX files
To open Outlook Express dbx files you just should select a file anddouble-click on it. The software will be open a .dbx file, scan dbxfile and visualize e-mails.
How to extract emails from DBX files
It is almost impossible to extract DBX files manually. However,there are tons of DBX extracting software over the Internet, such as DBX to EML.
Open DBX file on Windows
Oct 12, 2009 | Microsoft Windows XP Professional
Hi, I need to Import Outlook Express Emails (that were on another PC - and the Maintenance / Store location from express has been backed up to an external hard drive) and import the mail and contacts into...
You ought to copy the Ms Outlook Data file that is usually stored in your computer containing all your outlook data.
To locate it:
  • open my computer on the current computer that has the addresses and files.
NB: Make sure that you have enabled viewing of hidden files in your computer. Do this by going to the
  • Tools on the Menu bar --------- Folder Options----------Click on the View Tab ---------on the Advanced settings ------File and Folders -----Turn on Show Hidden files and Folder on the Hidden Files and Folders Menu.
Open Drive on Drive C:
  • On C: follow this sequence to open the file
  • C:/-----Documents and Settings--------Click on the User Account-----Local settings-------Application Data------Microsoft-----------Outlook.
When you are here you will see the Outlook Office Data File.
  • Copy this Outlook Office Data File in a removable media e.g Memory Stick.
Now you have copied the E-Mail and Addresses File.
  • Go to the computer you wish to copy the E-Mails, Settings and Addresses.
  • Open Microsoft Outlook Program
  • Under the File Menu Click on the Import and Export submenu.
An Import and Export Wizard dailog box opens up.
  • From the Action to perform choose
  • Import Internet Mails and Addresses and click next.
  • The Outlook Import tool dialog opens.
  • Select the Internet Mail Application to Import from: Choose on Outlook Express 4.X, 5.X, 6.X making sure that the Import Mail, Import Address Book , Import rules Options are turned on.
  • Click next
  • Address Dialog Box Opens up
  • choose on the option accordingly and click finish
  • Browse for Folder dialog box opens up.
  • Select the location of your saved Ms Outlook Data file
  • Click OK
  • Starts to import all your E-mail files and Addresses to the new computer.
Thats it. I guess you have your mails and Addresses.
Incase of any queries please dont hesitate to ask.
Kind Regards,
Picofly
Sep 10, 2009 | Microsoft Outlook Express
Outlook express
hi,
Error 0x800c0133 when you are retrieving email with your Outlook Express (OE) is because of currupted Inbox file.
To remedy please follow these steps:
  1. Open OE, on the left pane, right click "Local Folders", select "New Folder...", specify a name for your new folder as "Temp".
  2. If you are still able to access "Inbox", move all mails in "Inbox" to the new "Temp" folder.
  3. Go to menu "Tools" -> "Options" -> "Maintenance" tab -> "Store Folder" button. It will show the location of your Inbox file, please remember this location.
  4. Close OE, go to the location mentioned above, delete the file "inbox.dbx".
  5. Restart OE, the "Inbox" folder should be auto recreated. Move back your mails to the new "Inbox", remove the "Temp" folder.
or
Another solution
Error Number:0x800c0133
Error Number: 0x800C0133 = a corrupt Inbox.
Move any mail you wish to save to a local folder you create. Then:
Tools | Options | Maintenance | Store Folder will reveal the location of
your Outlook Express files. Press the Tab key to highlight the folder
location, then Ctrl+C. Close OE, then Start | Run | Ctrl+V will put the
location in the box - Click OK and you'll see the OE files. Otherwise, write
the location down and navigate to it in Windows Explorer.
In WinXP, Win2K & Win2K3 the OE user files (DBX and WAB) are by default
marked as hidden. To view these files in Windows Explorer, you must enable
Show Hidden Files and Folders under Start | Control Panel | Folder Options |
View.
With OE closed, find the DBX file for the folder in question {Inbox.dbx} and
delete it. A new one will be created automatically when you open OE.
General precautions for Outlook Express:
Do not archive mail in default OE folders. They will eventually become
corrupt. Create your own user defined folders for storing mail and move your
mail to them. Empty Deleted Items folder regularly. Keep user created
folders under 100MB, and Default folders as empty as is feasible.
After you are done, follow up by compacting your folders manually while
working *offline* and do it often.
Click on Outlook Express at the top of the folder tree so no folders are
open. Then: File | Work Offline (or double click Working Online in the
Status Bar). File | Folder | Compact all folders. Don't touch anything until
the compacting is completed.
Turn off e-mail scanning in your anti-virus program. It is a redundant layer
of protection that eats up CPUs and causes a multitude of problems such as
time-outs and account setting changes. Your up-to-date A/V program will
continue to protect you sufficiently. For more, see:
http://www.oehelp.com/OETips.aspx#3
In Tools | Options | Maintenance: Uncheck Compact messages in background and
leave it unchecked.
Apr 16, 2009 | Microsoft Windows XP Home Edition
I want to learn to download my email addresses and Favorites info to my flash drive before mailing computer to HP for repair
How to back up Outlook Express items loadTOCNode(2, 'moreinformation'); Step 1: Copy message files to a backup folder loadTOCNode(3, 'moreinformation');Step A: Locate the Store folder 1. Start Outlook Express. 2. Click Tools, and then click Options. 3. On the Maintenance tab, click Store Folder. 4. In the Store Location dialog box, copy the store location. To do this, follow these steps: a. Put the mouse pointer at one end of the box under the Your personal message store is located in the following folder box. b. Press and hold the left mouse button, and then drag the mouse pointer across the Your personal message store is located in the following folder box. c. Press CTRL+C to copy the location. 5. Click Cancel, and then click Cancel again to close the dialog box. Step B: Copy the contents of the Store folder 1. Click Start, click Run, press CTRL+V, and then click OK. 2. On the Edit menu, click Select All. 3. On the Edit menu, click Copy, and then close the window.Step C: Create a backup folder 1. Right-click any empty area on your desktop, click New, and then click Folder. 2. Type Mail Backup for the folder name, and then press ENTER.
Aug 05, 2008 | HP Computers & Internet
Northgate STAC2217L (Bundle) PC Desktop Logo
56 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Abhinandan  Patil
Abhinandan Patil
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
