Question about Daewoo KOR-6115 Microwave Oven
Panasonic NN-S252 Microwave
There are no instructions in the manual describing how to remove it from its mounting. Can you help with this?
The real problem with the microwave is the controls are frozen and unplugging it (at both the wall and the internal connections) doesn't re-set it.
Any suggestions?
Thanks tons,
Gord
  • GLGray1970 Nov 22, 2008
    Thanks very much, I'll have to order the part from Canada. Sounds appropriate, hope a new board works. I'll let you know.
    Thanks again for your help!
    Cheers,
    Gord
  • Daewoo Master
  • 9,098 Answers
This will be a damaged control panel. We have several of these on order now.
The best bet is to call or e-mail us so we can discuss this. If we're unable to answer, please leave your phone number and model number.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
What happens is the cooktop lights blow or short and it causes serious damage to the board. Replacing the board is the best option.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 09, 2008
  • William Miller
    William Miller Nov 23, 2008
    Glad we were able to provide you with the solution.
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Where is the fuse on Panasonic NN-S252
You may have to remove the cover on the microwave to find a fuse. It may not be either in a fuse holder or soldered into a the circuit board. be sure it is not plug up when you check.
if you find it be sure and replace with the fuse with same current rating.
Aug 01, 2014 | Panasonic NN-S252WF Microwave Oven
Panasonic NN-S252 Microwave was in use. It stopped, control panel was dead (as if a fuse blew) and there was an odor of burning rubber. There is power to the outlet. Is there an internal circuit breaker?...
if your smelling burning from your microwave its well past its sell by date,, dont even think of getting it fixed just dump it and buy a new one,
there is a hight chance the capacitor has just blown up on you and there not that cheap to fix anyhow so buying new one is your best bet
Jan 08, 2010 | Daewoo KOR-6115 Microwave Oven
INSTRUCTION MANUAL FOR PANASONIC INVERTER NN-SD376S
Desperately need
INSTRUCTION MANUAL FOR PANASONIC INVERTER NN-K593MF. please help
Jul 20, 2009 | Microwave Ovens
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic NN-S254 additional installation instructions
I just removed mine. There should be two long screws coming down from above into the unit. Remove them completely and then lift the microwave up towards the cabinet and slide forward. Sometimes some jiggling will help.
Leave the hanger assembly on the wall. It has the two prongs that go into the "insert" slots
Jun 05, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic NN-H664 1200 Watts Microwave
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job.
It's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
To order Panasonic parts see http://www.pasc.panasonic.com/epartr ; To download a Panasonic manual see
http://service.us.panasonic.com/operman ; to find an authorized Panasonic servicer, see
http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 ; For FAQs, see http://service.us.panasonic.com/faq/faq.aspx
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Panasonic NN-H664 Microwave Oven
Daewoo KOR-6115 Microwave Oven Logo
197 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
