Question about Onkyo HT-S580 System
Channel Levels The other day i changed the channel levels for the 580 and was getting much better cound. What is the optimal settings for the channels levels(ie. leave it at 0db or increase it) Should the surround and the front spekers be at the same levels.
    President:
  • 3,130 Answers
You should adjustb it to what sounds good to you, as industry standards with a sound pressure meter says to start out at 0 db level. You should read this link and others at this other site. http://www.techlore.com/article/10037/
Posted on Sep 23, 2006
SOURCE:
Channel 4 is 10 times louder than other channels why? all gains ect set the same nearly blew my speakers
Try swapping the input with another channel and see if the problem moves. Be sure to set the levels down or you may get your speakers this time. If the problem moves the source is the bad guy. If not check the gain setting, not the slider. The gain is normally the top know on the channel.
Jun 02, 2014 | Behringer DX2000USB Pro 7-Channel DJ Mixer...
Audio problems
Click the link below for manual pages I mention to make changes:
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/AVR1700_OM_EN.pdf
Most dialog sound comes from the center channel / speaker. If not working correctly, it make become difficult to hear people talking especially if there is a lot of other sound going on in movies and some music, too.
Check and adjust the volume level for the center channel or speaker. Check page 8 of the manual to learn how to use the remote to change the volume level of individual channels or speakers.
If you want, you may find it is a good idea to check page 17 to esablish correct volume levels for each channel by runnijng the set up with the microphone. This will allow the system to be "calibrated" for the room. This is a very important step in "getting the sound right".
If none of these suggestions work, you may have a problem with the center speaker itself - or with the amplifier for the center channel.
I hope this helps & good luck!
Check the speaker connections for the center channel. Page 6 shows the location on the rear of the amplifier - but check the speaker itself first as it is easier to get to and the rear of the amp is less likely to be distrubed and have a poor connection.
Dec 13, 2012 | Harmon Kardon Harman Kardon - Avr 1700...
HI WHEN DOWNLOADING MY RECORDINGS TO MY DELL 1720 PC THE DOWN LOADED PRODUCT HAS HARDLY ANY VOLUME. THIS DOES NOT HAPPEN WITH PRE-RECORDED MUSIC THAT I DOWNLOAD. WHAT AM I DOING WRONG?
Ensure your Master output volume is at an acceptable level when recording. The machine will only save audio at the levels which it is recorded.
Also be sure to adjust levels accordingly when bouncing tracks down to one channel. I ussually prefer to set the EQ for these tracks to flat (or zero), as you will have much better results doing the EQ in final mix.
Jan 07, 2011 | Fostex MR8-MKII - 8 -Rack Portable Compact...
Can you adjust the sound levels even tho the unit doesnt have visible bass and treble features?
Just go on the menu and adjust levels of each channel . The menu has specific settings for its channels.
Aug 10, 2010 | Denon AVR-1603 Receiver
Background sounds louder than voices
get the graphical user interface up on the TV,and adjust your sound levels.some amps also have supplied microphones for setting up their sound levels.you want about +8 DB on centre channel
Jul 05, 2010 | Yamaha RX-V663 Receiver
My hotel tv turns on to 66, how do i get it to turn on to channel 3
Most hotel sets have a master remote for setting up channels, volume levels, picture settings, etc. You will have to get a master remote for this adjustment. Thanks for using fixya.
Nov 14, 2009 | Televison & Video
My CT17 has a bad right channel. It plays ok for
change the part connected to the heatsink that you are spraying.
Sep 19, 2009 | Audio Players & Recorders
Problem with Yamaha Amplifier 361
volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Firmware Upgrade
Where did you get the firmware upgrade? Please provide link.
Mar 05, 2008 | Yamaha RX-V2700 Receiver
Onkyo HT-S580 System Logo
124 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
