Question about Roper RAX4232KQ Top Load Washer
Roper top load washing machine
It doesn't spin or wash.It will fill up with water and drain that is all it will do. My machine will fill up with water but then do nothing afterward. It just sits there.
  • VtwinQueen Nov 03, 2008
    Yes! We realized that the arm on the lid switch just gave way when pressed down. We took the machine apart and discovered that the casing for the switch had come unglued. We glued it back together and now the machines works great. Thanks for your response! : )
    President:
  • Roper Master
  • 2,651 Answers
You may have a bad lid switch,or the lid is not making contact withthe switch . not recognizing the door being down the machine , for safeety reasons, will not advance any furhter
Posted on Nov 02, 2008
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Where is the reset button on Roper washing machine top load water fills but nothing else happens
try to turn the timer dial to rinse and spin, and then see if the water will drain
Jul 07, 2011 | Roper RAS8445KQ Top Load Washer
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
My Roper washing machine will not drain the water after the wash cycle.
heatman101
Apr 17, 2011 | Roper Washing Machines
My washing machine will not spin the water out after washing
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 30, 2010 | Roper RTW4100SQ Top Load Washer
Water will drain out but tub will not spin
heatman101
Aug 29, 2010 | Roper RAX4233PQ Top Load Washer
Washer does not drain and spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Roper RAX4232KQ Top Load Washer
I have a Roper washer. It filled with water to wash, but when it came to draining the water to rinse, it just stops. It will add water on rinse cycle, but it will not drain or spin.
Sounds like the lidswitch. As a safety, the tub will not spin if the door is up (open). In turn, it will not drain if it wont spin. This is a common problem with whirlpool washers. You can go to searspartsdirect.com to get the breakdown and order the part.
Feb 17, 2010 | Roper RTW4300SQ Top Load Washer
Washing machine wont spin
It broke the drive motor to transmission coupling go to www.repairclinic.com enter model number and look for this part. It's easy to change if you know a mechanically inclined individual.
Dec 23, 2008 | Roper RAS8445KQ Top Load Washer
Roper RAX4232KQ Top Load Washer Logo
141 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
