Question about Toshiba MD20FN1 20 in. TV/DVD Combo
Tv won't stay
My tv won't stay on for more than 5 sec., it started by turning it's self off........help
    President:
  • 3,130 Answers
Most likly started out as a bad solder connection, but now mosy likly grew into whats called a bad regulator IC. Sorry you didnt have the set looked at in the past when it would have most likly cost you hafe of what it will now. sorry to tell you, the regulator IC is most of the time what causes this problem or symptom.
Posted on Sep 23, 2006
SOURCE:
Volume problem
I would try going into the settings and seeing if any Audio Limitations are set.
Sometimes this cannot be controlled due to the devices connected to the TV set.
Also try to cold boot the TV by unplugging for 5/10 secs and plugging it back it.
Apr 28, 2012 | Televison & Video
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
TV won"t stay on turns off in 3 seconds WS 55807
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
Let me know what error code you find and I will tell you what it means.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55807 TV
My red and blue crt go out and the green stays on
One or more of the CRT colors guns it dead,must be replaced.
Nov 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Tv goes on for 5-10 seconds then turns off
OUR TV AT WORK TURNS ON OK THAN IT TURNS OFF AFTER ABOUT 10 SEC SOLVE THIS FOR US THANK YOU fghigliotty @ niece lumber.com
May 08, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Can somebody tell me how to program a RCA 312w universal remote control to a emerson tv I have the intruction but I can not understand them thak you.
This will work with any devise and the rca remote.
1. turn on the device you want manually
2.press and hold the devise key, while holding the devise key press and hold the on off key till it stays lit.
3. point it at the devise and press PLAY for 5 sec. until it goes off. If it doesnt turn off after 5 secs. press and hold play again for 5 secs. repeat till unit turns off.
4. After unit turns off press and hold Reverse for 2 secs. until unit turns back on.
5. After it turns on hit STOP. and your done. Hope this helps.
Feb 25, 2009 | RCA Universal Remote Control
My Go Video 32" flat screen HDTV will stay on for 5 to 10 seconds then shuts off!
I have the same exact problem with my Go Video 32" HDTV. Yesterday the power stayed on for several hours, now it wont stay on for more than 5 - 8 minutes.
Please someone help!
TJ@streetkidssoftball.com
Sep 28, 2008 | Televison & Video
Tv does not stay on.
Your most likely having a problem with your power supply. I would say check the capacitors for obvious signs of swelling and all fuses first. Next I would check your low voltage regulators.Have you tried pushing the menu and imput buttons together and holding them for 5 seconds to access the self diagnosis feature? If you cant initiate the self diagnosis feature its probaly the capacitors or Regulators.
Jan 03, 2008 | Mitsubishi WS-65807 65" Rear Projection...
HELP
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Oct 20, 2007 | Mitsubishi WS-55807 TV
Toshiba MD20FN1 20 in. TV/DVD Combo Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
