Question about Ruud UAMB Air Conditioner
Compressor will not start.
3.5 ton Ruud M/N URGG roof package unit.
In the AC mode my unit calls for cooling cycles on the fan starts but the compressor short cycles off then starts a few minutes later.
  • 1 more comment
  • trizzotti Nov 02, 2008
    Sometime the supply fan dosen't shut off after the compresser stops.
    I have to switch the T stat manual fan switch off and on to stop it.
    Would a bad TDR cause this ?
    Unit has not been frezzing up, filters are new.
  • jack morton Apr 01, 2017
    If its a single phase supply voltage, you may check the run capacitor. Also, verify that the correct voltage is preset, and remains constant during operation. I found a compressor that would run for a couple of minutes, then stop. Try again and it would run then stop. Turns out there were a couple of wire nuts that connected the line voltage wire had lost connection and was making connection upon start up, but after a bit, would lose connection and dropping voltage.Also, monitor the compressor amperage on the common wire. A restriction in the freon circuit or high psig will cause the comp to run high amps, and quit due to internal overload. Hope this helps!
    Director Badge:
    Uploaded 100 video answers.
  • 488 Answers
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Posted on Apr 01, 2017
    Sergeant:
  • 359 Answers
BAD FAN CONTROL RELAY
Posted on Nov 30, 2008
    Scholar:
  • 147 Answers
If the unit is low on freon it will short cycle but a compressor internal overload will cause it to. Lets hope its the freon. Has it been frezzing up lately. Low freon is the cause most of the time. Make sure your filters are clean and both fans are running. Hi head can cause this to. (fans not running) How old is this unit. Maybe the coils need to be cleaned. Sound like this unit may need a check up and a good cleaning.
Posted on Nov 02, 2008
  • 1 more comment
  • butch welch Nov 02, 2008
    NO THE TDR IS NOT BAD. YOU WOULD HAVE TO RESET IT AFTER A FAILURE, (LIKE YOUR COMPRESSOR OF FLAME FAILURE.IF YOU HAVE GAS HEAT.
  • butch welch Nov 03, 2008
    I believe I would check the capacitor. Its the big one. about 40mf. They do make a kick starter somekind of device that you can buy at your supply house.
  • butch welch Nov 04, 2008
    Still would like to help you on this one. Thats what I do all day is control heating and air for 50 schools. All computers running these thing. I can rewire a RTU from my office. All wiring is virtual. I contol thousands of fans, boilers, chillers, valves.rtus. Mechanics carry very few tools or test equipment because I can trouble shoot a rtu in seconds.
Package heat pump problem.
the gauge not changing and the pipes not sweating indicates the compressor is not pumping gas
I suggest that you call in an ac specialist to properly diagnose the problem and get a quote to repair
Aug 27, 2016 | Heating & Cooling
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
Ruud 5 Ton UAKA Condensor fan running but compressor won't start. Internal thermal overload cycle.
Have you checked the wiring going to the compressor to make
sure it is not melted? Next, are you
able to put your hand on the top of the compressor? Check to see if it is hot or cold. You might have a bad run capacitor so let the
unit turn on, wait about 5 minutes, turn the unit off, and then tell me if the compressor
is hot or cold to the touch. Next, are
you comfortable with a meter?
Oct 17, 2013 | Ruud Matching Split Air Conditioner
Over Tonnage A/C
A better solution than undersizing the fan (which would decrease your airflow and probably not satisfy the household as well) would be to change the deadband in your thermostat. (Disclaimer: best solution is always to have a properly sized unit!).
Most programmable thermostats have a "deadband" that can be programmed in. This deadband is a certain number of degrees, in heating and/or cooling, where the thermostat will not call the system even though you have reached a threshold temperature. I.e. System is set to call for cooling at 76 degrees. there is a 3 degree deadband. When the Tstat reads 76 it will add the deadband (3) and not call for cooling until the room temperature is 79. This will prevent the compressor from cycling quite so much.
Adjust your setpoint temperatures (i.e.76) with the deadband in mind and you can arrive at a range that is comfortable and reduces compressor cycling.
Good Luck!
Jun 01, 2010 | Heating & Cooling
I HAVE A RUUD MODEL RSNM 2 TON UNIT WITH R-410A REFRIGERANT. WHEN THE TSTAT CALLS FOR COOLING, THE CONDENSOR FAN STARTS AND THE COMPRESSOR STARTS AND THEN ALMOST IMMEDIATLEY SHUTS DOWN. IT THEN SHORT...
I t sounds as if the run capacitor is goinmg bad. You have a start and run capacitor in the unit the start side could be good however the run side is losing voltage and wont let the compressor run at its peak causing a thermal overload shutting down the unit for safety.
Would suggest the rplacement of the capacitor first then go from there
Dave
Jan 15, 2010 | Heating & Cooling
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
Electrical Schematic for Ruud URGG-10E37JKR
just a maybe , write to RUUD AT P.O. BOX 17010 , 5600 OLD GREENWOOD ROAD ,FORT SMITH ARKANSAS, 72917-7010, OR CALL 479-646-4311 AND SEE IF THEY CAN TELL YOU WHERE TO CALL FOR SAM.
Sep 20, 2008 | Ruud UAMB Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud UAMB Air Conditioner Logo
422 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
