Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Canon sd630 I have the SD630 and it just stopped in th emiddle of taking pictures and the lens is out. No signs of power. The batter is fully charged and I did check the door switch by manually depressing it while pressing power button -no success. What would it cost to get this fixed?
  • microsyskl Nov 02, 2008
    I also have a Canon Rebel that stopped working because of a CF bent pin which caused a "no power" condition (when it rains it pours!). I believe it happened when my wife bought a Lexar 2gb flash card. It happened right after she started usign that (I read others had similar bouts with these cards). I wonder if there is any recourse with them on this problem??
    ANyways, can you repair this camera as well? How much do you think that would cost? I would like a min/max for both. If it is acceptable - I will send them out for repair ASAP.
  • microsyskl Nov 05, 2008
    Believeit or not - I had let the camera sit for a couple days without the battery or memory card. I was just getting ready to send it in for repairs and inserted the battery to include in the package when the camera powered on!
    WHY would this happen? The camera seems to operate normally now again. It wasn't bumped or "persuaded" it all. Can someone explain?
  • 489 Answers
Hi
Sounds like it would need the fuse replaced, about $35 if we can do it.. some of them are very hard to get at or solder. If that doesnt work it would need a new mainboard, $85 if I can get one used.
sales AT darntoothysam DOT com
Thomas
darntoothysam com
Posted on Nov 02, 2008
Powershot sd630 digital elph busy can not reset and says busy when deleting one picture
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
My canon power shot sd630 fell down and the lens does not function.it says lens error, restart camera.where shall I take it for repair and how much it costs to repair
You could try you local electrical or photo retailer but I'd get a quote first. I don't intend to be rude but its likely the repair could cost more than the camera is worth.
Mar 14, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 turn off itself AND could not turn on again
since its been two years you have bought the cam either your battery is down or you might have dropped your cam down which had damaged the lens array!!!
try replacing the battery and if it works its an happy ending of the problem.but if it still doesn't work then you have to replace the lens array!
any way i suggest you to take your cam to a "pro" since only physical examination has the best analysis of the problem
Sep 13, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon sd630 dead
Lens is defective, change the lens
Nov 01, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
I need HELP
Dear ashlyw:
A lens error due to impact damage most often requires service.
If you get an E18 message or a "lens error restart camera" message on your LCD screen and you restart the camera several times to no avail, you will almost certainly need to call Canon Tech Support at 1-800-828-4040 and have it sent in for service as there is little or nothing you can do to resolve the issue.
Hope this helps.
Sincerely,
HeavyDLB
Jun 02, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon Power Shot 630 Digital Camera
Hey kara M,
Before you take it in for service I would try taking the batteries out for a while and then putting them back in. Often this resets the camera and resolves the issue.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 30, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Apr 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Fuzzy, cloudy pictures
As basic as it sounds, is the lens dirty? The tiny surfaces of digital cameras' lenses really affect image quality. Also check the image quality setting to ensure you're shooting at a high quality setting.
Dec 31, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
