Question about Car Audio & Video
Reverse gear problem
Hi
I have a audi 2.8 v6 automatic 1996. I cannot get reverse gear on the car. If I put the car in drive it holds back before it goes to the front. The gear indicators on the dashbaord are all lit up. Don't know which gear I am in. Please help. 2002 A4 1.8 Quattro. Brought the car in to Canadian Tire for them to check a mysterious oil leak. They shampooed the engine to clear the engine area for a better view (I guess) and added a dye in the oil (to locate the leak) and proceeded to run the engine for 1 hour to check for leaks. They phoned me to say there was no leak and to come and get the car. Paid $100., got in the car, put it in D, heard a small clunk and then the car would hardly move without having to push way down on the gas pedal. Tried to reverse but it would not move, PRNDS all lit up, engine light on and the engine runnig ok ( sputtering a little) What the heck is going on? Left the car there after vowing to return to speak to the manager- it was 5:45pm. Is it possible CdnTire caused this or is it coincidence? They do not have a fault code reader and admit BMW and Audi are not their strength....so why do they service them? Sure take the money and when things go wrong ...uh it's not our fault you will have to go to the dealer for that! I will have to do that and see if that is the case and sue them if they are to blame.
    Problem Solver:
  • 7 Answers
That car is full of sensors if they sprayed the motor with a hose or what ever it could trigger any or all of the sensors to read off you can take it to most any reliable mechanic shop and have them hook it up on a computer dianostic machine for some where around 30 to 60 dollors. If you just want the codes the the computer will give you a code reader on cost about 90 dollars and they work on most any vehicle from 96 and up all you have to due is plug them in and follow the instructions on the screen they are simple to opperate.
Posted on Nov 02, 2008
Audi a3 auto reverse gear doesn't move
run fault codes and look for faulty TCM and reverse servo .
Nov 29, 2013 | Audi Cars & Trucks
Audi 100 c4 with automatic transmission engine turns off when gear put on drive
stationary rpm is to low,its normal higher the handgearbox.
too keep motor running it chould be higher so engine stay running,
while put in drive.
Apr 13, 2013 | Audi 100 Cars & Trucks
I have a 1996 audi a6 with a v6 engine. One morning i went to start my car an it would not move only in reverse every sense its been sittin for like two weeks than i tried it today randomlyy an it still...
had the same problem with 1997 audi and had the neutral safty switch/multi-funtion switch replaced and has been working great sence. prices vary for switch 250. to 450. so shope around for the part.
Feb 14, 2011 | 1996 Audi A6
I have a 1996 v6 3.0 taurus and my car turns on and you can accelerate the car but it wont move and i can put it on which ever gear and it wont grab the gear. i tried putting it on neutral and drive and...
hi, if this is a manual car, with clutch, then your clutch plate is worn and needs replacing, if it is an automatic, locate the dip stick for the fluid, while the motor is running, check fluid level, if it is not showing on dip stick you need to fill it, make sure you fill it with the motor idling not off, or you will not put enough fluid into the transmission for it to work...hope this helps good luck
Sep 13, 2010 | 1996 Ford Taurus
1994 audi 100s transmission problem, cumputer, no reverse AUDI VW
how too check transmission fluid on audi 100s 1994
Mar 11, 2009 | 1994 Audi 100
Hi I also have an Audi Auto 2.8 non quottro had a simler problom and it turneed out to be one of the gear relays that are under the stering wheel on a left ****** that is.
Mar 11, 2009 | 1996 Audi A6
When I switch gear in reverse my car won't move why?
my 1996 audi a4 2.8 awd reverse gear works for a couple of second then stops moving....
Jan 13, 2009 | 1996 Audi A4
1996 Audi A4 2.8L will not shift into reverse or park
You need a new inhibitor switch on the gear selector.
Dec 13, 2008 | 1996 Audi A6
Change the Transmission filter and flush the fluid in it, I'd be willing to be the factory filter is still in these trannys and it's about clogged up, gettin worse once the fluid heats up. The pump won't build enough pressure to allow it to act properly.
Jul 31, 2008 | 1996 Audi A4
Car Audio & Video Logo
144 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
