Question about Panasonic Televison & Video
I have a panasonic DLP rear projection t.v. There are bright colored spots on the screen. the screen has ghostimages and vertical lines.
    Problem Solver:
  • 6 Answers
Ghosting is usually caused by RF interference.
I would troubleshoot the video source rather than the projection TV.
The first thing to check with interference is the tightness of all connections. If your signal is transmitted via a coaxial cable, (which I'll assume because ghosting is common with coax) use a wrench to thread each connector tighter. Not too tight, of course, just a little more than what you could do with your fingers. Check the image.
If ghosting still apears, check the connectors themselves. At any point can you easily pull the cable out of a connector? Does the cable look like a good quality cable? If the cable itself is thinner than a standard pencil, the answer is no. A lot of manufacturers turn out crappy thin coax cables that cause many, many problems.
If you're pretty certain the interference is not attributed to bad wiring, consider the environment where you watch the TV. Are there devices within range that might cause RF interference? A CB radio? cordless phone? cordless microphone? microwave oven? wireless router? If so, these devices might be resonating with the video signal, causing the unwanted equivalent of a delay in an audio signal. Try unplugging these devices one at a time and observe what difference, if any, they make on your reception.
Report back if these tips are not fixing your problem.
--Matt
Posted on Nov 02, 2008
MODEL # PT-52LCX15. GREEN AND BLUE SPOT ON SCREEN.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine.You can find it here: http://www.discount-merchant.com/PANASONIC-521A2C52-p/1177904.htm Have a blessed one!
Mar 22, 2010 | Panasonic PT-50LC13 50" Rear Projection...
LINES THROUGHOUT SCREEN AND COLOR NOT SO CLEAR AND BRIGHT. Vertical lines on screen and the color is very dull. It's not bright. Is it somehting simple to fix or forget it...? Thanks
It sounds like you are at the end of the useful life of your unit. It is a CRT projection unit and when the colors get dull, picture gets dim and especially when you have lines on the screen indicating retrace problems the CRTs are shot. Cost to replace would be more than new. I would recommend a DLP. Of all the schemes out there I think they are the best looking, least prone to breakdowns and most cost effective. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 19, 2010 | Samsung HCM4216W 42" Rear Projection...
Even with a new panasonic bulb;the picture is not as bright as when it was new.prob?
We replaced the lamp on our pr61lcx65 rear projector panasonic tv. We still have colorful spots and now it is getting darker and have yellow on bright picture and red on dark picture running through it. Please help.
Feb 10, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Vertical lines
do you have a cordless phone placed nearby?
i just had that problem, and realised it was because of the phone's frequency (scary!). i move the phone/base away from the tv, and it's fine now.
Oct 10, 2009 | Samsung HLN5065W 50" Rear Projection...
Panasonic PT-52LCX16 DLP TV color problem
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Apr 26, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Hitachi Rear Projection Model 500X18B V4F001550 has converge problem. Colors won't align correctly and colors are weak. Tv is not bright enough. The vertical line has a static line. How can I fix it and...
Most likely bad convergence integrated circuits. STK394-160 is the Hitachi upgrade components. In some cases, the supply resistors may burn as well on the convergence board, but these are easily spotted.
Mar 03, 2008 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
97 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
