Question about Kenmore 57029 Side by Side Refrigerator
In door ice wont come out but water works
After a power outage the ice wont come out of the door but the water will
  • camillecaldw Nov 02, 2008
    the water comes out of the dispenser fine in the door the ice wont come out but the icemaker is working fine
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check auga motor
Posted on Apr 02, 2009
My GE Side by Side refrigerator stopped making ice and dispensing water.
Check out the solenoids and power to the water solenoids for ice maker and door water.
Aug 22, 2017 | Refrigerators
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Kenmore side by side icemaker not working after power outage, but water at door dispencer
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out. If it is not operating properly it should at least hum and vibrate. If that does not occur your problem lies elsewhere. As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
Apr 28, 2012 | Kenmore Side by Side Refrigerator
GE GTS22WCMBRCC, refrigerator and the freezer wont cool or freeze
possibly the drain tube for the condensate(water) is plugged due to ice having built up on freezer coils. Check coils to see if they are iced up. Sometimes especially in humid climates the defrost mechanism even if working gets overpowered by moisture. If so defrost coils manually and clear drain tube.
Jun 02, 2009 | GE GSF25TGW
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
Automatic ice maker quite working after 7 day power outage
Check to see if the power cable is ok. If your unit has a fuse, you may need to replace that. Looks like the power outage might have fuzzed up the power circitry. If neither of the above works, then you may need to get the machine serviced.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Dec 24, 2007 | Frigidaire FRS23KF7AB Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
116 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
