Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Sony kf-60we610 washed picture
Colors from optical block look great. I have tried 2 other lamps and replaced lamp driver with a known good one , picture still looks washed. Do I need to clean optical lens and mirror. Thanks boosterman
  • 505 Answers
If everything including sony menu is unclear, yeah cleaning may help. dirt can get inside the engine too. look at a white screen, this is your answer (or a black in some cases). any dirt on mirror or lense will be uncolored distortions. colored distortions are inside the light engine.
Posted on Dec 09, 2008
How do I access the lamp on a Vega KF-60WE610?
This page shows Sony lamp location and bulb replacement.
Sony DIY Bulb Guide.
The XL2100 Lamp assembly is located behind the grill, under the front screen. Thumbscrews on left and right loosen and the panel pulls off.
Open Lamp access door by loosening the thumbscrew on the front. The lamp is behind the door and attached by two mounting screws. The mounting screws require an "Allen" or Hex key.
Never attempt to access the bulb or open the door when the bulb is hot. Allow 30 minutes to cool.
Look for specific LED indicator codes on the front of the TV. An explanation of the most likely fault is in your Sony user's manual. Links to free Sony user manuals are also on the link above. Lots of instructions regarding safety, mercury disposal, removing the lamp.
Do not buy a bulb and waste your money if any Sony TV Optical Block or Optical Engine Faults are or were visible before bulb failure.
Jan 27, 2011 | Sony XL-2100U Projector Lamp for...
Sony KF-60WE610
Some of the ICs on the power supply block are damaged. This can possibly due to high voltage or defective IC. What you can do now is to get a new PS block. If you can get me the part number i can help you find it..
Feb 23, 2008 | Sony XL-2100U Projector Lamp for...
How do I change the optical block in a sony tv
Disconnecting wiring from power supply block
This step may be optional, if power supply block must be transferred to purchased replacement optical block. Undo the blue plastic-coated wire holders to release the two wire bundles. Disconnect the connectors shown with the dotted lines in the photo below. One, which presumably provides power, is disconnected directly from the power supply block, and the other is a regular wire connector.a837b7e.jpg
moz-screenshot-2.pngDisconnecting the optical block fan wires
Disconnect the optical block fan wire connector:
Disconnecting the wiring from the optical block circuit board (C Board)
Carefully pull up on the three wire connectors directly connected to the top of the C Board:
Final wire disconnection from C Board
Remove the screw and gently pull the blue ribbon ribbon cable out of the side of the C Board:
Your optical block should now be entirely free of the TV and ready to ship. I recommend adding specific protection for the projection lens, then sealing the whole unit in a bag to prevent infiltration of dust or packing materials, then carefully packaging it with substantial padding.
Removing the projection lamp (in cases where you are installing a purchased replacement optical block)
Loosen the hex screw next to the projection lamp housing, and pull the lamp and housing outward from the metal clips.
Picture of replacement optical block for KF-60WE610 (courtesy John Setar)
Here is a picture of a replacement optical block for the KF-60WE610. Note that some parts of the old optical block need to be removed and installed on the replacement block.
Jan 25, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony TV KF-60WE610 no Picture OR sound
check the tiny fan directly above the lamp for excess dust or if it spins at all
May 07, 2009 | Sony XL-2100U Projector Lamp for...
Replace Lamp Flashing
Clean the cooling fans, specifically the lamp cooling fan located inside the rear cover, above the optical blocker. This is easily blocked with dust and causes overheating of lamps/shortened life.
Nov 07, 2008 | Sony XL-2100U Projector Lamp for...
Help for Sony XL-2100U Projector lamp
If you need XL-2100U Lamp for your Sony Grand Wega, its available on Sony Accessories and its price is approx $200
Here is bit details of required part from Sony web site...
Part Number is ... A1606034B LAMP BLOCK XL-2100U
Compatible Models
  • KDF-42WE655
  • KDF-50WE655
  • KDF-60XBR950
  • KDF-70XBR950
  • KF-42WE610
  • KF-50WE610
  • KF-60WE610
  • Need further help, let me know.
    Sep 20, 2008 | Sony XL-2100U Projector Lamp for...
    Follow below picture to get idea how to remove front panel of your tv.
    Sep 12, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
    Hi Rose Mary
    Could you please provide me with the lamp hours on this unit ?
    Also take out the lamp and check for any marks or discolouration.
    In wich case the lamp will need replacement.
    May 06, 2008 | Sony XL-2100U Projector Lamp for...
    Kf-42610 blue hue and blue dots on screen
    Hi Guys
    The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
    Sorry to have been the bearer of bad news. Good luck : )
    Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
    Sony KF50we610 blue dots and blue cloud
    Check the optical block repair at sony's warranty website...
    Could be the problem they have been covering it under a recall of sorts. $1250 for the optical block and they are only doing it until the end of the year so don't waste any time
    May 03, 2007 | Sony XL-2100U Projector Lamp for...
    Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
    166 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
