Question about Apple Power Supply 344 Watt PowerMac G4 Quick Silver (p/n 661-2513) 344-Watt Power Supply
Problem with power supply
One day the computer went into sleep mode and never woke up. Now when I try to power it on there is just a short kick of the fan but it does not turn on. I purchased a used power supply on ebay and replaced it but I still have the same problem
The motherboard might be shot would be my guess.
Posted on Nov 07, 2008
Hello, After putting my computer, hp pavilion m7690n, to sleep last night. I woke up to see it was turned off so I went to hit the power button to start it up but it didn't show any power because the...
It's possible that your computer froze during sleep. First, unplug the power cord, (with the cord removed) press the power button for 10-20 seconds. PS: You will lose any unsaved data prior to sleep mode. Let me know if this doesn't resolve your problem, might be something major.
Jul 01, 2013 | Computers & Internet
LCD AOC 2436Swa is stuck on active-off mode
tried to unplug the unit and don,t use for a while to reset the power supply as will as the main board.
Jan 08, 2013 | AOC 2436swa 23.6" 16:9 Lcd Monitor, 5 Ms -...
My htc wont change and just fashes a red light
your power supply is overloaded, check the power supply of your phone
Jun 08, 2012 | HTC One X Android Smartphone Glamour Gray
Packard Bell F9150 desktop power supply
open your cpu cover .
Then check your power led on motherbord blink or not also reattcha ll connection to motherbord.
check your smps fan is movinh when you switch on.
May be you have to change smps it is square box from with you attch power code.
Jul 17, 2009 | Computers & Internet
Dell LCD monitor quickly goes sleep, on, off over and over
I would recommend that you try it on another computer to see if you are able to reproduce the results. If that is the case you should look at any new drivers, software or updates that have been installed. If the issue continues with another PC, it sounds as though the monitor's power supply is possibly failing. in that case I would suggest you simply replace the whole monitor. Unless you are not shy with a soldering iron. ;) good luck!
Nov 19, 2008 | Dell E197FP LCD Monitor
Computer won't stop
Hi ashbadash93,
I have had similiar issues in the past. Try powering it down by un-plugging it from the back of the pc, wait at least 2 minutes before plugging it back in. After 2 minutes, plug it back in and power on the pc. Sometimes this helps.
Jul 26, 2008 | Dell Dimension 3000 PC Desktop
Won't come out of sleep mode
Have you tried getting a second monitor ? then using it to get to the desktop and go to power options and set your monitor to never turn off? after that is done try your monitor again and see if that works.
Feb 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Dell 2001FP always in sleep mode.
I have a dell ultrasharp and at first it would not come on at all. Open it up and found loose connection on plug connectors 3 pin. Soldered and would come up but blinks in and out sometimes take longer than other times. Big Capacitor when open up Power supply was leaky. Check for bad caps
Sep 08, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Is this monitor connector to PC? is yes most probably the problem is the system is not sending signal to tell your monitor to wake up...
Aug 30, 2007 | Sharp 17" Monitor
Apple Power Supply 344 Watt PowerMac G4 Quick Silver (p/n 661-2513) 344-Watt Power Supply Logo
325 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
