Question about Home
Installing an Aqualux (Desiree) whirlpool bathtub
I purchased a floor model of an Aqualux Whirlpool bathtub and of course it came without installation instructions. I've searched the internet but so far have been unable to locate instructions or the technical specifications. Any idea on where to find them?
  • Anonymous Jan 15, 2009
    need insallation instructions for aqualux whirlpool bath tub
  • jesimon May 22, 2009
    We have our bathtub installed , but need to know if there is a specific start up procedure.
Call the manufacturer Asteria Bath Company at1-800-288-4002 and they can send it to your email address.
Posted on Dec 05, 2008
I have a copy of the installtion and operating instructions if you still need it, you can reach me at lunatic_40@yahoo.com
Posted on Feb 14, 2009
Looking for a manual for a Aqualux whirlpool tub
Try Googling (Aqualux)(model)(manual) without parens.
Sep 20, 2017 | Pool & Spa
The push,turn on control has become very difficult to push on and off what can i do?
Disconnect power from the system. 2. Purchase a can of www.ultra-lube.com (This type f lubricant will not cause breakdown of rubber, silicone or plastic seals) multi purpose lube. HomeDepot sells it. Black green and silver spray can. 3. Remove the knob using the right size Allen wrench. 4. Spray lube into the neck of the actuator. 5. Wipe off any lube from the knob shaft. 6. Re install the knob and push pull a few times to distribute the lubricant. 7. Restore power and test system.
If this does not solve the problem then there may be a mechanical failure in progress. Go online at the manufactures website to order a new switch.
Mar 04, 2015 | Whirlpool Home
Aqualux whirlpool tub how do I clean jets?
Try and blow the lines out with air, sounds like something is stuffing the water jet. Drain system and turn off power first.
Nov 02, 2012 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Installing a bathtub on concrete floor
Other than chopping out more concrete.elevating the tub is probably your only other solution. I would think 2" would be adequate.
Hope this helps.
Bob
Feb 08, 2012 | Crane & Co Crane Plumbing 2430W Whirlpool...
I have an aqualux whirlpool tub w/ cracked jet housing
yes i can do it call me 301 659 9968 rick
Oct 15, 2009 | Home
Is Aqualux a Good Brand for the money???
well i never heard of this brand and if you cant find info on line it would make me wonder.a bathroom is a big expense i dont think i would take the chance
Apr 15, 2009 | Home
Need to replace casing around one jet
Go to Guillens.com and look at the picures of jets.
Apr 04, 2009 | Home
Need instructions for aqualux x260 m7242S
To answer this, I'm going to need more info. The unit you are stating isn't listed as a brand. I can't find any info about this at all anywhere. The name sounds more like a model but not the brand name of the unit. If you can answer with a brand, I might be able to get more information.
Apr 01, 2009 | Whirlpool Home
Whirlpool Tub Access
Hi garyv47,
I'm Harvey the Master Plumber.
Your question is: Your daughter just purchased a new condo with an AquaLux whirlpool tub installed in the bathroom. The front side is removable for access to the mechanicals and is held in place on the lower side by velcro. When you pull the velcro loose the side begins to tilt up, but then stops as it hits the upper edge of the tub. You tried pulling down, but it appear to be held by something. You don't want to pull too hard and break something. Any ideas on how to remove it?
It has been my expirience that the top of these access panals are 'tongue and grove' type construction and are not connected to anything. Usually disconnecting the bottom and pulling the bottom out works. If you are concerned about breakage then it migt be wise to consider the Repair Directory to find a reparman. Or you could talk to the condo maintenance guy. You'll find these guys are a wealth of info.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 16, 2008 | Home
Home Logo
1,741 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
