Question about Nikon Coolpix 2100 Digital Camera
System / Lens Error
I have had my 2100 for over 3 years now...I recently downloaded the pictures; now I am getting a system error or lens error...Help please...
    Champion:
  • 217 Answers
It has defective mechanism, you have to bring the unit to the service center. But first Try to change the memory card or remove it and try shooting. I have encountered different troubles caused only by defective or corrupted memory cards
Posted on Aug 31, 2007
System Error (Focus) ...Lumix DMC-FS15 works, pauses, then results in a white error screen with the following error message:
My camera started bringing up "system error (zoom)" and it was completely inoperable. I would turn it off, but the lens wouldn't retract unless I applied slight pressure to it. I was able to FIX this problem by applying some lubricant oil to a Q-tip and swiping it around the telescoping parts of the lens, being very careful to stay away from the actual lens. I turned the camera on and off a few times so the oil could work its way into the parts, and it fixed the problem. I don't know if it will be a long term solution, but I can at least download my pictures to my computer now!
Oct 08, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
The lens will not open all the way when the camera
You may have a LENS ERROR.. Please search "LENS ERROR"
Aug 19, 2017 | Nikon Coolpix 2100 Digital Camera
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Lens error
It's effectively irrepairable. Perfect boxed examples in full working order go for an average of £15 on online auction website.
Aug 23, 2008 | Nikon Coolpix 2100 Digital Camera
LENS ERROR
My Nikon L14 Camera Is Showing Up Lens Error
Can Someone Please Help Me.
Aug 22, 2008 | Nikon Coolpix L14 Digital Camera
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
May 09, 2008 | Nikon Coolpix 4600 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Lens error/system error
I have successfully fixed the same error on a Nikon 2100 by dissasembling the camera and removing grit from the gears that drive the lens. However, if the camera has been dropped, I suspect that something has got dented or bent. It may be worth taking the camera apart to see if a gear has got dislodged.
I would warn you to be very careful not to get a shock off the flash capacitor inside the camera though. Also, it took me quite a while to put it all back together. It's not the easiest device to work on, a result of the very compact body (for its time!)
May 29, 2007 | Nikon COOLPIX Cameras
Nikon coolpix 2100
hi there is a problem in the iens operation sorry cant help this is a delicate mechanical problem contact retailer or nikon representative here are all the cotacts you need: http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?&p_faqid=238 good luck
Mar 21, 2006 | Nikon Coolpix 2100 Digital Camera
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Nikon Coolpix 2100 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
